Question about Jet Health & Beauty
JET 3 DL 5.2i EMI-RF TRYING TO FIND WHERE FUSE HOLDER IS AND FUSE SIZE BATTERY IS FULLY CHARGED CURCIT BREAKER IS WORKING ?
Posted by Jimmie Keene on
5 Related Answers
Anonymous
  • 21 Answers
SOURCE: Power Supply Plugged In And Battery Fully Charged No Power
has it gone into hibernation? ... try holding the power button down for 10 seconds
Posted on Sep 23, 2008
Anonymous
  • 32 Answers
SOURCE: the battery on my jet 3 will not charge
you need to replace both batteries, their called U1 batteries (35 AMP-Hour)
Posted on Jul 13, 2009
HoverTech
Donna Angelo
  • 232 Answers
SOURCE: Merits DL 52 i electric wheel chair, all leds flash 3 times.
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
ViscamTech
Piyal Perera
  • 528 Answers
SOURCE: My jet 3 power chair
Hi! I need some clarification before helping you.
How long have you been using this power chair?
Didn't you charge it even once before?
Posted on Jul 25, 2011
mmb_safe
Mark Brown
  • 168 Answers
SOURCE: New batteries, fully charged, still wont work
I will ask but don't take offence, so many people overlook the obvious, have you checked the free wheel lever/s are not set to free wheel (if it is the scooter will be relatively easy to push forward or backward) if set to free wheel then move lever/s to drive position
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Sonic_om.pdf
this is a link for the sonic scooter user guide, not 100% sure that it is the exact one or not but it should show you were to find the free wheel lock on your scooter it is in this guide and I would be surprised if it is not the same as yours. Hope that helps. Mark.
Posted on Mar 08, 2014
My hot tub has an issue. Only half the display is working, there's no heat and the jets wont turn on. If I trip the curcit, I can get the hot tub jets for 10-30 seconds and that's it. HELp
Almost all hot tubs use 230 volt AC power which comes from the power company in two power wires plus one common common wire. You get common 115 volts between a common and either other wire. "Half way" working could well be an attempt to run on only one of the wires. There is also likely to be a ground fault circuit breaker in the wiring which makes sure current going out to the tub is all returned via the wires and not through someone's legs to ground. If you're comfortable with an AC voltmeter check some voltages but understand that 230 volts is way into the killing range. Two people present and well insulated probes are important.
Apr 15, 2016 | Pool & Spa
My sonic 3 wheel scooter will not go status light blinks 3 times the 1 time,3 times then 1 time ect, batteries fully charged unit is in gear what is wrong
Pride Mobility Products Corp. - Product Owners Manuals ...
www.pridemobility.com > Resource Center
Pride MobilityProduct Owners Manuals & Specification Sheets ... Jazzy Elite ES PortableSpecifications ... I 02/03. Jet 3 Ultra ... Travel Scooter Throttle Control Lever OperationProduct Insert .... Brochures · Owners Manuals · Basic Operating Instructions · BasicTroubleshooting Instructions · EMI / RFI Information · Warranty Information.
Sep 25, 2015 | Pride Sonic 3 Wheel Portable Scooter
I changed the batteries in the jet 3 ultra. Chair will work but batteries will not charge
Wall outlet bad? Charger not turned on/plugged in right? Something disconnected? Bad battery connection? Blown fuse in chair or charger? Bad battery or batteries?
Aug 09, 2014 | Jet 3 Ultra Power Chair
Pride Jet 3 Ultra 4500 rpm, unit is completely dead, am I missing an auxiliary charger or is it built into the unit?
I suggest that you start with determining the condition of your batteries and work outwards from there. Dead batteries just don't want to take a charge. Test your batteries with a meter before you start part swapping. The internal charger is only about 4 amps so it will take many hours to charge a 24volt system.
May 06, 2013 | Jet 3 Ultra Power Chair
How do I charge the batteries
Check circuit breaker or fuse, battery connections, controller connected to power base and for dead battery. .
Mar 16, 2013 | Jet 3 Ultra Power Chair
Fuel line routing
Instructions
Fine tune your motorcycle before rejetting your carburetor. If it's still running too lean, you can replace the pilot jet as a first step
Remove the bowl at the base of the carburetor by unscrewing the screws holding it in place. Unscrew the pilot jet inside, but be careful not to strip it. The jet size will be on top.
5 Year/ unlimited mile warranty No up front core charge
www.Cylinder-Heads.com
Use a screwdriver to remove the main jet from the brass jet needle holder, which is also called the emulsion tube.
Put in a pilot jet that is one size larger. Replacing it with a jet two sizes larger will make your mixture too rich.
5
Tune the slow/idle settings before replacing the main jet. Replace the main jet with one size larger. The sizes are in increments of 5.
6
Put the bowl back on, and align the accelerator pump shaft and rubber boot.
7
Reinstall the carburetor on the motorcycle and retune it to finish the rejet procedure.
Jan 11, 2013 | 1998 Honda VT 600 C Shadow
I have a blue jet 3 ultra n i just put 2 new batterys on it and all it will do is flash a red light in the top left corner of the battery light on the joy stick and the horn works but will not move what...
Check your battery wiring on the Jet the wires from the circuit breaker need to connect the positive of the front battery to the negative of the rear battery and the other wires connected to the positive of the rear battery and negative of the front battery putting the batteries in series to generate 24+ volts. If you have a voltmeter before you check the wiring set it to 200 volts dc and plug the leads into the 2 outter holes of the charger port located under the front of the joystick. If your batteries are wired correctly you should be reading 27+ volts without the charger plugged in and your batteries fully charged. If you are only reading 12 volts then the wiring is wrong and needs to be fixed. Leaving the voltmeter in the charger port plug in your charger and you should be reading 27 -30+ volts at the charger port anything less than 24 volts indicates your charger is not charging Hope this helps
May 22, 2011 | Jet 3 Ultra Power Chair
Not sure if jet 3 is charging
Does all your lights on the joystick come on after charging? If you can have someone look behind your chair while still plugged in for charging, the green light on the charger will be lit if the batteries are fully charged. They will have to kneel and look under the shroud to locate the charger they will see the light if it is on. Also check the meter on the rear of the chair the meter should read zero when the chair is plugged in and fully charged. I fyour chrger is working then if the chair does not stay with power for what was normal then new batteries are probably needed
Aug 21, 2010 | Jet 3 Ultra Power Chair
My samsung jet keeps on going off and coming on. what should i do
try these trouble shooting.
1. check your battery if it's charging well
2. check your charger if it's giving the right capacity to work with the battery. sometimes it says fully charge but sometimes it was not really charge.
3. plug the usb cable to your computer where your NPS is installed and check if will goes on and off while being charged by the computer.
if somehow all of the above gives you the same issue,
then, ask the help from samsung service centers nearest in you.
Feb 08, 2010 | Samsung Jet S8000 Cell Phone
AM/FM radio on boat,
First thing i'd do here would be to investigate if the electromagnetic interference is coming in through the supply feed. I would bring another battery on board (Charged fully), one that isnt connected to the boats electrical system and see if the emi still afflicts reception. If it stops or reduces to a permissible level one can attack the problem with emi suppressors and filters. A good place to start would be the alternator, try suppressing the emi at source.
The second path the emi takes to pollute reception would be via air straight to the units antenna.
The solution sought here might not be a single remedy but a total of 3 or 4 tweaks, each leading to a percentage improvement. try shifting the antenna too, maybe shielding might contribute some.
Jango
May 26, 2008 | Car Audio & Video
Health & Beauty Logo
159 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
