The AC works fine but when Heat is turned on the unit will not start and the control board in flashing a code 20. this is a single unit.
Check control board make sure no wiring is on twin on board or touching it. If so remove it to correct location. If no wiring there, board replacement.
Posted on Nov 02, 2020
SOURCE: No heat from unit. Hear ignitors start but no airflow in house
well i need to know if the fan comes on at all if not then it could be a bad motor or board which is not uncommon but if the fan does come on and then flames go out and fan stays running could be high limit check to make sure in the bower compartment there are no wires disconnected from the blower sometimes when changing the filter it is possible to knock the wire off the board
Posted on May 19, 2009
SOURCE: I have a goodman furnace and ac unit the fan and
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
Posted on Jul 07, 2009
SOURCE: rg(bu)h-07eauer have replaced the control board will not heat
read wiring and make sure flame sensor is clean and make sure you have good ground
Posted on Oct 17, 2009
SOURCE: 5 amp fuse continues to blow on control board for
You have a short on the 24 volt side of the unit. Check the thermostat wire for signs of pinching or direct short.
SOURCE: I have a suburban lp furnace and duotherm air/heat
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Posted on Feb 16, 2010
Apr 22, 2015 | Heating & Cooling
Dec 01, 2010 | Heating & Cooling
Feb 22, 2010 | Heating & Cooling
Nov 10, 2009 | Heating & Cooling
Sep 12, 2009 | Heating & Cooling
Jul 02, 2009 | Ruud UBHC Air Conditioner
Feb 11, 2009 | Ruud Central System Air Conditioner
May 30, 2008 | Heating & Cooling
Jan 19, 2021 | Heating & Cooling
255 people viewed this question
What was your outcome?
Can also be a 24volt phasing issue and a ground issue.
