Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
Posted by blakebannon on
Charles T Nevin
  • 4,070 Answers
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Posted on Sep 17, 2009
How to find out if there is a leak on the top of the freezer compartment of my whirlpool french door fridge there seems to be an icicle ?????
Most likely your freezer door or fridge door is not closing properly. Poor rubber seal (door gasket)???
Most likely moist room air gets inside through a door leak
Sep 17, 2014 | Whirlpool Refrigerators
My icemaker 106-626636 is making ice but it is also making icicles and dripping in the bucket to where i have chunks of ice melted together. the icicle is where the black part of the icemaker meets the...
The problem is not the icemaker. It is the solenoid water fill valve in the back of the unit. You make have to use a hair dryer to defrost the water fill tube just behind the icemaker AFTER you replace the water valve. I just worked on my own and have have done in home appliance repair for over 30 years. If it is making icicles the diaphram in the water valve is shot. It is not a difficult or expensive part IF you order it on the net. Walk in replacement part prices have nearly a 100% mark up.
Thanks for choosing FixYa.
Kelly
Aug 18, 2010 | Refrigerators
Our refrigerator just suddenly started to make this loud grinding sound..it appears to be coming from the freezer side. I turned off the ice make and reduced the freezer temperature but it still keeps...
This could be a failure of the evaporator fan. Also maybe some ice has formed from water dripping from the ice maker and had now produced an icicle which could be hitting the fan blade of the evaporator motor. Remove back cover to the freezer/fan and check the fan operation while it is running.
Mar 29, 2010 | KitchenAid Refrigerators
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Sep 17, 2009 | Kenmore 53542 / 53544 Side by Side...
Ice maker is dripping and forming an icicle at the front right of the ice maker
you need to defrost the drain hole and clean it out... sounds like it is frozen
May 23, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water runing down back side of icemaker and forming icicle.
If it is running down the back of the icmeaker then you need to make sure the inlet tube is properly installed into the fill cup on the icemaker. If the tube is in the right place then your icemaker fill level needs to be adjusted.
Dec 07, 2008 | Refrigerators
Kenmore 51564 Side by Side Icemaker Won't Quit
Ice maker has to be replaced. The linning is peeling and it is freezing into your ice.
Dec 16, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker leaking
what brand refrigerator?
Nov 27, 2007 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
418 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
