Question about Kenwood Car Audio & Video
I got a CD player Kenwood kdc-x789 I need to know what wires gos to 2006 sartun vue
Posted by Senad on
2 Related Answers
oprime78
  • 96 Answers
SOURCE: need to know what the wiring diagram for kdc-x789
well if you mean how to wire it up to ur car buy a radio adapter from best buy and color match all wires
Posted on Aug 31, 2009
emissionwiz
Marvin
  • 85239 Answers
SOURCE: trying to wire in a Kenwood KDC-X789
this is the info, do this for free ask that you rate my help a fixya! thanks
2001 Chevrolet Venture Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Bl
Posted on Sep 07, 2009
Security code
If you never set the code and forgot it, with most stuff the code put in by the factory is 0000. Same goes with anything bluetooth most of the time.
Nov 28, 2010 | Kenwood Excelon KDC-X789 CD Player
What is error 5?
rom can't read information
Mar 31, 2010 | Kenwood Excelon KDC-X789 CD Player
Trying to hook up last few wires and not sure what they are
Hello jtracer,
Here's a link to the Kenwood manual at Crutchfield.
Here's a link to the color code for the 2000 Dodge Durango.
If you are splicing directly into the vehicle wiring, just match up the wires from your Kenwood to the appropriate vehicle wire by function, not color. If you are using an aftermarket vehicle specific wiring harness, such as the Metra 70-1817, the colors should match up with the Kenwood wires.
Hope this helps.
Aug 31, 2009 | Kenwood Excelon KDC-X789 CD Player
Need to know what the wiring diagram for kdc-x789
I need the wires connector
ebay is a good place to search.
if that doesnt turn up 1 try any audio visual store or a kenwood approved retailer will be able to order 1 for you
May 20, 2009 | Kenwood Excelon KDC-X789 CD Player
Ste the Time
Below is an excerpt from the User's Manual:
In Standby mode, Manual Clock Adjustment (this adjustment can be done when the <Synchronize Clock> is set as OFF).
1. Select Clock Adjustment mode, Push the Control **** to [FM] or [AM]. Select the "Clock Adjust" display.
2. Enter Clock Adjust mode, Press the Control **** for at least 1 second. The clock display blinks.
3. Adjust the hours, Push the Control **** to [FM] or [AM].
Adjust the minutes, Push the Control **** to [4] or [¢].
4. Exit Clock adjustment mode, Press the [MENU] button.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 10, 2008 | Kenwood Excelon KDC-X789 CD Player
Power problems with my kdc-x789
It should be taken back to the installer.
Oct 06, 2007 | Kenwood Excelon KDC-X789 CD Player
Need help unlocking code on kdc-x789
Make sure you're entering the code correctly; use the control knob's 4-way controls to select the numbers, and when you're done press and hold the control knob for at least 3 seconds.
Mar 06, 2007 | Kenwood Excelon KDC-X789 CD Player
Car Audio & Video Logo
132 people viewed this question
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
