Question about Tools & Hardware - Others
Lenk LPT-200 butane torch
A little spring fell out of my Lenk LPT-200 Butane torch, where does it go?
Posted by Anna Marie Melo on
2 Related Answers
kenny_econom
kenny economy
  • 58 Answers
SOURCE: butane leaks out at fill valve of butane micro torch
turn the screw to the right.
Posted on Nov 26, 2012
johntunney
John Tunney
  • 887 Answers
SOURCE: my Ronson butane torch won't light
probably has bad fuel in it. get new stuff. cheep fuel sucks.
Posted on Mar 06, 2013
I have a model 35002 triple torch Colibri gear lighter and I need instructions on how to refill it with butane.
There is a small nipple on the bottom of the lighter. That is where you put the canister on to refill.
Dec 12, 2015 | Colibri Watches
Micro torch
to little air - air holes blocked up
Feb 23, 2014 | Omega Bernzomatic Corporation ST2200T...
Butane torch
Could be due to the fine gauze in the nozzle becoming clogged due to maybe not using good quality gas refills?.
May 08, 2013 | Blazer GB2001 Self-Igniting Butane...
My Ronson butane torch won't light
Mar 06, 2013 | Cars & Trucks
LSP-60 i have filled it with butane and no gas is coming out now....it was working just a minute ago.
Hello, if does work and leaking fuel. Take it back to Sears for a replace. Do mess with. If does work right the first time then it is faulty. GB...stewbison
Jul 17, 2011 | Sears Lenk LSP-60 4-In-1 SolderProTM...
The Blazer micro torch does not ignite (no hissing sound for the gas either) and we did fill it with butane? Any suggestions - have had it for awhile - maybe it needs new flint? or whatever ignites it....
Hi. Get a piece of very fine wire, hardware store is a good source, and run it into the nozzle. Chances are that the nozzle is clogged. Once it is hissing again it will ignite unless you also need a new flint. J.
Jul 08, 2010 | Omega Blazer Self - Igniting Butane Micro...
Brand new Weller Mcm Magna Lite butane torch does not light
If this is an itty ***** torch, The fuel is very sensitive . Too much screws up the air fuel ratio so try turning it way down and after the tip has heated up, you can increase your flame. Good Luck, Ned
Aug 27, 2009 | Weller Mcm Magna Lite Butane Table To
Tools & Hardware - Others Logo
126 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Andrew Taylor
Andrew Taylor
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
