Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hi why is my hotpoint FDW60 dishwasher flashing fast and prewash lights and not starting the cycke
Posted by Ronan on
5 Related Answers
Anonymous
SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Posted on Feb 23, 2008
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: FDW60 Fast and Delicate Lights Flash
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Posted on May 23, 2008
Testman45
  • 3 Answers
SOURCE: Hotpoint FDW60 dishwasher - flashing lights
check the filter.
Posted on Jun 06, 2008
Anonymous
SOURCE: hotpoint fdw60 eco error code
I had this problem too, but discovered the cause and the remedy.
The flashing eco light signifies that the drain sump has water in it. Before the machine takes on water it checks a float located in the sump. If the float says that there is water in the sump then the machine presumes that there has been a problem when draining and decides not to take on any more water.
In my particular case, the sump collected extra water after the machine has last drained itself because the bottom spray arm has come off and allowed some water to enter the machine. Make sure that you check that!
The simple solution is to empty the sump of water. Do this by tipping the machine onto its right side. Warning! You will get wet feet! There was about a 1/4 pint of water in my dishwasher.
After that you should find that your dishwasher works perfectly again! Why Hotpoint couldn't include this simple task in their manual I'll never know! Health & Safety I guess...
HTH!
Posted on Sep 21, 2008
Anonymous
SOURCE: Hotpoint fdw60
Heater elements on FDW 60 do not last long at all, I am on my 3rd. You are better of buying a heating element and a decent limescale filter, otherwise it will keep happening. The flow through element builds up limescale, causing the element/thermostat to over heat.
Its a shame as they are quite a good dishwasher. Hotpoint 5 year parts warranty a waste of time. £90 call out charge.
The last one lasted 3 moths before delciates & fast light started flashing.
You can get the elements online for £40
Posted on Nov 09, 2008
Please help I have a aquarius FDW60 . The problem
It is likely the flood switch at base of dishwasher has activated due to a leak.
You will have to dry the leak and then try again.
Make sure the mains power is shut when you are working on the dishwasher to avoid electrocution.
Mar 16, 2011 | Hotpoint Dishwashers
I have a hotpoint aquarius sdw60 with the eco 45 light flashing fast and will not reset I have tried turning off the power I have stripped the pump this was clear. then reinstalled it but it is still same
I have a Hotpoint Aquarius SDW 60 The delay 3hr &12hr lights are flashing at the same time. Machine won't start. If the door is slamed shut. It get stuck on the Fast & Prewash 40 degree cycle. and stays there.
Jul 13, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Dishwasher not working - FDW60
unplug it for an hour this normally fixes this problem on my machine
Jul 28, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Problemwith Hotpoint Aquarius FDW60
Eco light flashing, and refuses to do any of the other programs
Oct 15, 2007 | Hotpoint 24 in. FDW60 Free-standing...
FDW60
Tom, If your dishwasher is still under warranty, best thing will be to contact Hotpoint's service center for repair the problem.
Aug 29, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Flashing lights
Not heating, check element and thermal fuse/thermostate. Regards Advisor
May 30, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
153 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
