Xerox One Touch 4800TA Flatbed Scanner Logo
Symon Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Xerox 4800 one touch flatbed scanner
I am using an Acer Aspire 5920 (32-bit.)
When I connect my Xerox 4800 scanner Vista will not find new drivers, so I have downloaded the Xerox Vister drivers plus extra's, (Utilities)follow all instructions to the letter. No good, now done this 5 times, no hair left, has anyone got these drivers to work?
Symbo
Michael Grey
Level 3:
  • Master 365 Answers
  • Posted on Sep 17, 2009
Michael Grey
Master
Level 3:
Answers
365
Questions
Helped
132524
Points
1137
Uninstall drivers and remove usb cable.
re-install drivers without usb attached.
Reboot and attach usb cable
Testimonial: "You are majic.........this time it works, thank you so much Regards Symbo"
Symon
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 18, 2009
 Symon
Contributor
Level 1:
Answers
Questions
Helped
610
Points
Download Windows Installer Package 4800.32.4071218.EN.msi from Xerox. (Make sure you use the correct driver for your system) Now re-install drivers without usb attached.
Reboot and attach usb cable "working"
My thanks to Michael Grey for his help as this worked 1st time.
Symbo
2helpful
Xerox 4800 one touch flatbed scanner My new computer has Widows 7 and the scanner will not work with it. Do I need another drive
Hello.
I am a Support Engineer with Xerox Scanners.
The Xerox 4800 do not have a supported Windows 7 driver. The scanner only supports Vista, XP, 2000, ME, and 98. I recommend trading the Xerox 4800 for a supported windows 7 scanner.
Please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
9helpful
I can't install xerox 2400 one touch scanner in windows 7
You need to use the Windows Vista driver. I used the 32 bit. Here is the link for the driver.
Hope this helps.
http://www.xeroxscanners.com/en/uk/products/X2400/drivers.asp
Hi i have windows 7 how can i install xerox scanner 4800 one touch?
either the vista or xp version should work, a bit of trial and error
http://www.xeroxscanners.com/en/uk/products/X4800/drivers.asp
1helpful
To get driver on Xerox 4800TA One Touch
Xerox 4800 One Touch has message ' The Scanner Optical Module is Locked' was working ok now showing this
One touch doesn't work Xerox 515 on Vista Home Premium
Try this link:
Note: Before following these instructions, check to see if the installation CD that came with your scanner supports Vista. If the CD does support Vista, do not follow these instructions. Instead, use the CD and installation guide that came with your scanner.
Note: Not all scanners have a Vista driver available. To check if your scanner has a Vista driver, select a link below:
https://www.xeroxscanners.com/KnowledgeBase/Articles/VIS1426%20-%20Installing%20Scanner%20On%20Windows%20Vista.asp
1helpful
2answers
Iam trying to scan a document on my flatbed xerox 4800 but it keeps saying please unlock your scanner then it gives me time to do it but i dont know where to unlock it
you might have two program trying to use the scanner at the same time & the scanner is confused.Find out what programs you are using.Hint...even printer programs may use scanner drivers. 2nd.you MUST use the EXACT scanner driver for your scanner. Windows will see the scanner "locked out"
4helpful
2answers
Xerox One Touch Scanner 4800
please, send me the driver for
5helpful
2answers
Xerox One Touch 2400 Flatbed scanner drivers
http://www.xeroxscanners.com/en/uk/products/OT2400/drivers.asp
will get you drivers and manuals in pdf fomat. I had same problem and works fine now. Good luck.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
