Question about PfaFF Sewing Machines
After replacing the 2 batteries in PFAFF Creative 7562 plus the menu memory disappeared. On the display screen only bright stripes. Nothing works. Is there a way and how to restore performance?
Posted by Vladimr K on
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: threading a pfaff creative 7570
Always thread the machine with the presser foot up. This keeps the tension disks open while you are threading. Open the lid on top. Put thread on spool holder. Go directly to your left and down the path on the farthest left. Go all the way to the bottom and bring the thread up on the path closer to the spool. Hook the thread through the metal piece that moves up and down while sewing. It should be in the highest position when threading. Run the thread down and clip into the small metal holder above the needle. Pull down needle threader, draw thread across front of it from left to right and pull through needle.
Posted on Feb 14, 2008
dupina
Theo du Preez
  • 110 Answers
SOURCE: Pfaff 7570 display screen info is very faint & difficult to read
Hi Carolyn,
Look for a small turning wheel, just below the green and pink selection knobs, on the front right of your machine. Turn it anticlock wise for a darker image and clockwise for a lighter image. Enjoy!
Posted on Dec 24, 2008
Anonymous
  • 14 Answers
SOURCE: How to replace light bulb at Pfaff Creative 2124?
On these machines you cannot open the left side to remove the bulb. Your machine accessory kit should have come with a rubber tool that is ribbed with a cup-shaped opening on either end. This is a tool for removing the bulb. Tilt the machine with the base facing up so you can see where the bulb is and use this tool to twist the bulb gently. It sould come out with no problem! Hope this helps!
Posted on Sep 12, 2009
Testimonial: "Thank you"
SOURCE: i have just purchased this pfaff 7570 creative as a second hand unit and have never used it. it has been in storage for period of time. when i plug in the ac220V and switch the machine on the display
it's possible that the motherboard could have gone out, taking the machine in for service will tell for sure
Posted on Mar 10, 2012
SOURCE: BATTERY WENT FLAT NOW SCREEN LIGHTS UP BUT THE DISPLAY IS BLANK ON PFAFF 7570 CREATIVE
it show a part of the problem says a battery went flat,,was there any corrosion in the place you put the battery. if there was corrision it could have shorted something in the machine
it's very posssible that something has gone wrong with the computer part of the machine
Posted on Mar 22, 2012
Hard Drive Memory
Greetings,
Ask this tech kimbo322
An ex- PfaFF employee
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 08, 2008 | PfaFF Creative 7570
I have a 7550 and the screen lights up but the menu does not come up - I have replaced the batteries. It was working when my sister gave it to me a couple of months ago.
Okay....I don't know if this will help, but this is one thing I learned about my Pfaff 7550. Sometimes it will look like the screen is lit up but there is no menu or anything and I have found that the "display lucidity control" dial is the problem. If you look just below the buttons that are in a semi-circular shape, you can see a really tiny little dial. It can be easily missed if you don't know where to look. What I have found is that sometimes the screen lights up but there are no words/menu and if you turn the "display lucidity control" dial, the words/menu will appear. As my machine has gotten older, it seems I need to do this more often. The first time it happened to me, I freaked because I thought the display (even though it was lit up) had blanked. THAT was when I discovered that teeny little dial that solved my problem. I don't know if this is your problem, but give it a try and see if works for you like it did for me. And by the way, if you need to see a diagram of the buttons on the Pfaff 7550, here is one. The "display lucidity control" dial is marked #23 http://www.manualowl.com/m/Pfaff/creative-7550/Manual/333556
Apr 05, 2014 | PfaFF Sewing Machines
Pfaff 7570 sewing machine screen lights up, but nothing to read on the screen.
look 3 inch down from left of screen there is a small wheel for adjusting brightness
Oct 22, 2010 | PfaFF Creative 7570
Start up on pfaff 7560
A lot of people don't know this, but there is a dimmer dial on the front of your machine, located just under the display. Often it gets bumped and the display disappears. If not then you need a fuse in the base plate or worst case a new circuit board.
Jan 29, 2009 | PfaFF Creative 7570
Hi Carolyn,
Dec 23, 2008 | PfaFF Creative 7570
Resetting the code
The 7550 has a battery backup (little door on bottom of machine - 2 AA batteries). Remove batteries for a couple of days and the code should disappear. Removing the batteries WILL NOT effect the main memory of the machine - they are just for the backup of any personally designed stitches and memory combinations - not the hard memory of the machine. Periodically these batteries will need to be changed - a message will pop up on the screen to let you know.
Hope this helps (ex-Pfaff employee - GREAT MACHINE!)
Mar 21, 2008 | PfaFF Creative 7570
Sewing Machines Logo
117 people viewed this question
Top PfaFF Sewing Machines Experts
Irene Tulloch
Asmodius
Level 1 Expert
Chris Wetmore
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
