Question about Nordic Track NordicTrack Treadmill, A2550
Our belt is slipping on our nordic track c1900 treadmill, how do i fix it?
Posted by robynhood231 on
  • Electro Med Services
    Electro Med Services Mar 07, 2016
    If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.http://electro-medical.blogspot.com/
peddler88
    New Friend:
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Posted on Jan 03, 2011
  • H C Park Dec 13, 2011
    Hey, it worked! Thanks for the valuable tip.
  • Nordic Track Master
  • 6,694 Answers
Posted on Mar 07, 2016
Treadmill Repairs Brisbane
    New Friend:
  • 338 Answers
You may have a slipping motor belt. This is connected to the front roller.
The belt tightening 7 turns tells me the belt may now be damaged anyway .
Posted on May 15, 2015
Anonymous
    New Friend:
Have a c1900 series , belt is slipping, how to fix??
Danielle
Posted on Mar 24, 2010
1 Related Answer
Anonymous
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
I have a nordic track c1900 treadmill. It blows the 315mA fuse when I turn on the machine.
Mar 09, 2016 | Nordic Track Exercise & Fitness
Stopped in Belt had been slipping smelled hot but motor was barely warm. Was 30 minutes into workout and machine stopped. Electric panel works but motor won't run.tilt works
time to lube the DECK belt, use WD-40 or grease. do it by each weeks. Try to loose the deck belt. in the way that you lift the belt by 2" with your finger. Otherwise, you must replace the belt+deck. See if the belt drive is to tight. And take time for maintenance the motor, replace the carbon brush+and lube the bearing.
Feb 08, 2015 | Nordic Track Nordictrack C1900 Treadmill...
Squeaky Nordictrack C1900
see the video attached. lube the rollers bearing front+back . Test the drive belt motor for to loose or faulty belt, and fix it.
However if the problem persist, TIME to replace the old board deck.
God bless you
Oct 20, 2013 | Nordic Track Nordictrack C 1900 Treadmill...
Nordic track c1900 how do I remove the hood ?
Dear Sir:
I will help you right now with this Video:
http://www.youtube.com/watch?v=H_ieEByRp34&feature=relmfu
If you need additional Help, please reach me.
Thank you in advance, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Oct 04, 2011 | Nordic Track NordicTrack Treadmill, A2550
My Nordic Track A 2050 is slipping. At first I noticed it slip from time to time in my 45 minute workout, but at the end, it was like I was on ice. I love this treadmill, is there a way to fix it?
Have you tried adjusting the rear roller bolts with an allen wrench? That usually works for me.
Unfortunately now I have a slipping problem that tightening the belt via the roller bolts doesn't fix. In fact, I feel as if the belt is too tight as it only lifts about 2" instead of the recommended 3-4". Hope we get some other ideas here!
Dec 21, 2010 | Nordic Track NordicTrack Treadmill, A2550
Feb 05, 2010 | NordicTrack Exercise & Fitness
Nordic Track NordicTrack Treadmill, A2550 Logo
4,724 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
Jesse Garza
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
