Question about NorStar T7316E Telephone
Hi ..once the answer machine is activated it will not let a person leave a message, continues to say there is not enough space to leave a message, yet all 4 lines have been cleared of messages...help!!! we can not do business this way. and the phones are not even 5 months old.
Posted by shelly_tavr on
  • shelly_tavr Sep 18, 2009
    no, this did not work. I am still very confused. I can not find even find a general mailbox, we do not have one. All our lines go directly to someone..so I still need help????? Thank you for trying. Anyone else????
george peters
    President:
  • NorStar Master
  • 860 Answers
The general delivery mailbox could be the one thats full. try feature 981 press the othr soft key the display should say log:enter in 1000000 (the general delivery mailbox is 100, and defaulted password is 0000.) Hopfully the password wasn't changed
Posted on Sep 18, 2009
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
Jun 15, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
A man answers my phone with "The answering machine is off. Please leave a message" Sometimes it leaves a message and sometimes it doesn't. The menu options I get will not restore it to my...
"The answering machine is off. Please leave a message" (sic) This doesn't make sense.... how can one leave a message if the answering machine is OFF! Unless it goes to a voicemail etc? It's just not possible?
I suggest that you use your manual, and reset up your system again, perform a Factory Reset and then set up what you need to do again, this will clear any erroneous data that maybe causing any problems.
Whats seems to be happening is that the default "Voice" is being activated instead of the recorded message? I think you need to do it again.
After you have done this, record your message and set the answering machine to ON. Then test it from another phone.
NOTE sometimes with answering machines, if they ring more than a certain number of times, without being answered, the AP may switch OFF, ON or indeed do "Other" functions" that may be assigned, so ensure that this "Feature' isn't active or enabled or whatever.
May 16, 2011 | Uniden Cordless Phone
When people leave me a message - the answering machine does not show that I have a message. The person calling hears the greeting - leaves a message, but I do not receive the message.
It may be similar to the problem I had on wireless home phone with answering machine not taking messages when had the answering machine set to 12 rings before answering. Found the sim card (my wireless system) auto response would answer first. Fixed it by reducing time to 6 rings and answering machine now comes on first.
Oct 12, 2010 | Uniden Cordless Phone
The machine won't allow messages to record.
Your system is set to "Announce" mode. Follow the instructions on pages 25-26 of this manual to switch to "Answer" mode.
Apr 16, 2010 | Vtech IP5850 Answering Machine
Red light flashing continuously on answer machine as a result callers cannot leave messages
Hi Len,
A flashing light is usually indicative of unheard messages on the machine.
The inability of callers to leave messages could mean that the the machine is full.
I'm sorry that I cannot be more absolute with the diagnosis in the absence of a make and model.
Best regards
Mike
Feb 19, 2010 | British Telecom Lands Phones
Creating an Outgoing message that tells a caller to leave a messa
To Create Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
Aug 13, 2009 | NorStar Flash Voicemail Power Supply Only...
How do you remove a recorded answering machine message
Settings:
In Settings dialog you can set the following options for Best Answering Machine:
* Greetings - allows setting up the greetings played on pick-up;
* Active in profiles - defines in which profiles the application will pick-up the phone and record messages;
* Storage - allows selecting on which disk the records will be saved;
* Pick up after - sets the time after which the call will be answered;
* Record time - maximum amount of time the message is being recorded;
* Format - message file format (amr,wav);
* Icon - configures the visibility of the icon displaying application activity and presence of new messages; depending on this parameter, can be shown in standby screen only (Phone application) or in any application;
* Play volume - play volume for the greeting;
* Records lifetime - automatically removes old messages;
In this view you can listen to new and old messages, delete unnecessary messages, send the recorded messages and call the person directly from this view.
During the call:
When Answering Machine is processing an incoming call, you will see a dialog showing the application's progress with the ability to stop it:
* Answer - when this command is chosen during a call, it stops greeting playback or message record and you can continue talking to the caller;
* Hang up - stops greeting playback or message recording and terminates the call; hope this will be helpful...
Jun 23, 2009 | Nokia Cell Phones
Can not send mail to others
i have yahoo personals and this person i am trying to contact liveshere in my town he sent me a note yesterday stating he is sending me messages and im not getting them and he is not getting mine i sent 4 yesterday without an answer from him he says they are going into cyber space i want help as this is what im paying for here thank you [email protected]
Dec 22, 2008 | Yahoo Mail
NorStar T7316E Telephone Logo
270 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
