Question about JVC Televison & Video
My jvc tv went to key lock and have no signal how do I unclock?
Jvc tv fat screen 55
Posted by martin on
I have a 55 inch JVC tv,today the screen went black but still have sound, also the buttons on the back wont work, but the channel down button turns it on and off? What is wrong with it?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary..
Jan 15, 2017 | JVC Televison & Video
Tv screen lock jvc remote damage .tv.jvc
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Oct 17, 2016 | JVC Televison & Video
Maylong tablet is locked on one screen
My andriod maylong tablet. Is locked up. I have tried for three-four days to unclock it.. I have no clue what my password is what do I do to unclock it?
Dec 26, 2012 | Maylong Tablets & eReaders
How to turn off clock on jvc tv
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
Sep 06, 2012 | JVC AV-32260 32" TV
55 inch led tv will not recognize my hdmi cable?
on you r remote there should be three hdmi settings just try each one it will likely work with one of them
Apr 16, 2012 | LG Televison & Video
Parental Lock
Try unplugging the tv for a few minutes. This reset the front panel lock on my JVC tv. I got it from the manual, which I found at the JVC site by Googling the specific model of the tv along with JVC and manual. I found the manual right away.
Jan 12, 2008 | Televison & Video
Jvc tv on button flashing on av 48wp34
Use remote, sounds like Tv is in child lock
Dec 21, 2007 | JVC AV-48WP30 48" Rear Projection...
HDMI input failure
Hey guys, had the same problem. Found this solution on the web. Worked for me.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is reenabled.
Here’s how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
simultaneously.
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
This should work.
Oct 06, 2007 | JVC HD-52Z575 52" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
