Question about Facebook Social Network
Cannot login to Facebook because cookies are not enabled
I have changed the privacy setting to accepts all cookies and even added Facebook to the listing of sites to allow all cookies...however, I still get the message that says "Cookies are not enabled on your browser. Please adjust this in your security preferences before continuing"
Posted by jlabwalters on
  • jlabwalters Sep 20, 2009
    I was using Internet Explorer 8, which I had just recently upgraded. I tried to uninstall it and go back to version 7, but that didn't work either.
  • Anonymous May 11, 2010
    Which browser are you using + version ?
Linda Chase
    New Friend:
I had the "Cookies Required" message every time I tried to get into FB using Internet Explorer for a month before I finally fixed it. In the meantime, I worked around it by using FireFox. I also found if I created a new user on my laptop and logged in as that user, I could get right in.
Things I tried. First I tried several variations on the IE -> Tools -> Internet Settings -> Privacy Tab (lots of forums suggest changes to make there). Then, I manually deleted content.ie5, and all my cookies folders. No joy.
Then I read what Gaara said on this forum: http://en.kioskea.net/forum/affich-159094-facebook-cant-open He/she nailed it!! I'll never know how Facebook got into my Domains key in my registry, but I sure am happy to have it gone!!!!!!
I'll paste Gaara's instructions here, slightly edited to give them a G rating:
Press "start"
(if u're on Vista) Type "run" then press enter.
(if u're on XP) just click on "run".
Type "regedit" and press "Enter"
Navigate till you get to Domain in :
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains
Right click on Domains, and delete the whole folder.
Close IE. Reopen. Login. Problem solved!
Only problem is, all your other restricted sites will now be gone from the restriction list. If you're using SpyBot, just open SpyBot and re-immunize, and they'll all come back. If you've added them manually and deleted the Domains folder before reading THIS, then u r in for a repeat job. You'll have to add them manually, so if SpyBot didn't create that restriction list, u'll have to re-add them manually from the IE's Tools > Internet Options > Security > Restricted Sites (select it, then click on "Sites" right below it) then add whatever u want to add.
Good luck
Posted on Mar 29, 2010
Anonymous
  • 375 Answers
This is a browser problem. Try any other browser like the best is Google Chrome or Opera. They are obtained free in internet.
Posted on Sep 17, 2009
Anonymous
    New Friend:
Posted on Sep 25, 2010
How to get gmail to accept cookies
When you visit a website, the server may place a cookie on your hard drive. These very small files (which got their nickname from the trail of cookie crumbs you might leave behind you) contain information unique to you, which the web server will "read" to recognize you when you revisit the site. Cookies must be enabled on your computer to view certain websites. Follow these steps to enable cookies on the browser version you are using.
Internet Explorer 6.0 Click "Internet Options" on the Tools menu. Select the "Privacy" tab. Make sure the privacy level is no higher than "Medium High." Click the "OK" button. b> FireFox 1.5 b> Select "Options" on the Tools menu. Click on the "Cookies" tab. Make sure the box to "Allow sites to accept Cookies" is checked. Click "OK." b> Netscape versions 6 and 7.1 b> Select "Preferences" on the Edit menu. Click the "Privacy & Security" tab. Then click "Cookies." Click on the box to "Enable All Cookies." Click "OK."
Enable Cookies in Browser b> Web browsers store cookies from websites you visit on your computer. Cookies can store a website's preferences, your login state on the site or track your browsing activity across a website. Many websites, particularly ones that require you log in, need cookies enabled in your browser before you can log in. Cookies are enabled by default on all major browsers, but you can also enable them if they've been disabled from your browser's options window.
Click the gear icon at the top right corner of the Internet Explorer window and select "Internet Options." Click the "Tools" menu if you don't see a gear icon. Click the "Privacy" tab at the top of the Internet Options dialog. Drag the Settings slider to the bottom to enable all cookies. You can also set the slider to medium or low to allow most cookies, except certain types of cookies that can be used to track you. Most websites should work properly at medium. Click "OK." Mozilla Firefox b> Click the "Firefox" menu button and select "Options." Click the "Tools" menu if you don't see the Firefox menu button. Click the "Privacy" panel icon at the top of the options window. Click the drop-down box to the right of Firefox Will and select "Use Custom Settings for History." Enable the "Accept Cookies From Sites" and "Accept Third Party Cookies" check boxes by clicking them if they're disabled. Most websites should work properly without the "Accept Third Party Cookies" check box checked. Click "OK." b> Google Chrome b> Click the wrench icon at the top right corner of the Google Chrome window and select "Options." Click the "Under the Hood" tab at the left side of the options page. Click the "Content Settings" button to the right of Privacy. Click the "Allow Local Data To Be Set (Recommended)" option and uncheck the "Ignore Exceptions and Block Third Party Cookies From Being Set" check box if you want to allow third party cookies. Most websites should work properly with third party cookies disabled. Close the options tab. Hope this helps.
Jan 09, 2013 | Microsoft Internet Explorer 7
How to enable cookies on my hauwei m860
Not sure what a hauwei m860 is car truck bike or computer
Enable Cookies b> When you visit a website, the server may place a cookie on your hard drive. These very small files (which got their nickname from the trail of cookie crumbs you might leave behind you) contain information unique to you, which the web server will "read" to recognize you when you revisit the site. Cookies must be enabled on your computer to view certain websites. Follow these steps to enable cookies on the browser version you are using.
b>
Jan 05, 2013 | Computers & Internet
I need to know how to enable cookies...it is on firefox...thanks!
Cookies are enabled in Firefox by default - so if you haven't changed the settings, they should still be enabled.
Here's how to check:
(1) In the Firefox browser, go to: Tools > Options > Privacy
(2) On the Privacy tab, In the "History" section, use the pull-down menu and select "Use custom settings"
(3) The boxes for "Accept cookies" and "Accept cookies from third-party sites" should be checked. (If not, then check those boxes, and click on "OK")
See also this Firefox help file:
http://support.mozilla.com/en-US/kb/Enabling%20and%20disabling%20cookies
Dec 24, 2011 | Mozilla Firefox
How do i enable cookies on my web browser?
Internet Explorer 6 for Windows
  1. Within Internet Explorer, click the "Tools" menu and choose "Internet Options."
  2. Click the tab labeled "Privacy."
  3. Click the button labeled "Advanced."
  4. Check the option labeled "Override automatic cookie handling." To enable cookies:
    Set "First-party Cookies" (and "Third-party Cookies, if you wish) to "Accept."To receive a prompt to accept or decline cookies on a site-by-site basis:Set "First-party Cookies" (and "Third-party Cookies, if you wish) to "Prompt."
  5. Click "OK" to save changes and close the dialog box.
Firefox for Windows and Mac OS X
  1. Open Options dialog box: WindowsWithin Firefox, click the "Tools" menu, then click "Options."Mac OS XClick the "Firefox" menu, then click "Preferences."
  2. In the left-hand column, click the icon labeled "Privacy."
  3. Click "Cookies," then click the option labeled "Allow sites to set cookies.
  4. Click "OK" to save changes and close the dialog box.
Safari for Macintosh OS X
  1. Within Safari, click the "Safari" menu and choose "Preferences."
  2. Click the icon labeled "Security." To enable cookies:Set the option labeled "Accept Cookies" to "Always."
  3. Click "OK" to save changes and close the dialog box.
Internet Explorer 5 for Windows
  2. Click the tab labeled "Security."
  3. Click the button labeled "Custom Level."
  4. Scroll down to the section labeled "Cookies." To enable cookies:Set "Allow cookie that are stored on your computer" to "Enable."Set "Allow per-session cookies" to "Enable."To receive a prompt to accept or decline cookies on a site-by-site basis:Set "Allow cookie that are stored on your computer" to "Prompt."Set "Allow per-session cookies" to "Prompt."
Internet Explorer 5 for Macintosh
  1. Within Internet Explorer, click the "Edit" menu and choose "Preferences." (In OS X, click the "Explorer" menu and choose "Preferences.")
  2. In the left-hand column, click "Cookies." It is is listed in the "Receiving Files" group.
  3. Click the button labeled "Custom Level." To enable cookies:Set option labeled "When receiving cookies:" to "Never Ask."To receive a prompt to accept or decline cookies on a site-by-site basis:Set option labeled "When receiving cookies:" to "Ask for each site."
Internet Explorer 4 for Windows
  1. Within Internet Explorer, click the "View" menu and choose "Internet Options."
  3. Select "Custom" and click "Settings."
  4. Scroll down to section labeled "Security." To enable cookies:Select "Always accept cookies."To receive a prompt to accept or decline cookies on a site-by-site basis:Select "Prompt before accepting cookies."
Opera 7 for Windows or Macintosh
  1. Within Opera, click the "File" menu and choose "Preferences."
  2. In the left-hand column, select "Privacy."
  3. Select the option labeled "Enable cookies."
Netscape Navigator 6 and Higher for Windows and Macintosh
  1. Within Netscape Navigator, click the "Edit" menu and choose "Preferences." (In OS X, click the "Netscape" menu and choose "Preferences.")
  2. In the left-hand Category column, click "Cookies." It's listed in the "Privacy and Security" group. To enable cookies:Select "Accept all cookies" or "Accept only cookies that get sent back to the originating server." To receive a prompt to accept or decline cookies on a site-by-site basis:Check the option labeled "Warn me before storing a cookie" and select "Accept all cookies" or "Accept only cookies that get sent back to the originating server."
Aug 28, 2011 | HP Computers & Internet
How to enable cookies for facebook. when ever I try to log in message comes that cookieds are not enable in your browser
You can configure your privacy settings in Internet Explorer 6 by clicking Internet Options on the Tools menu, and then clicking the Privacy tab.
NOTE: An administrator can customize your privacy settings and remove the Privacy tab from the interface in the Internet Options dialog box. If the Privacy tab is not available, contact your administrator, or see the "Information for Advanced Users and IT Professionals" section.
These settings replace the cookies settings on the Security tab in Internet Explorer 4 and 5 (and the Advanced tab in Internet Explorer 3). The Privacy settings slider has six settings: Block All Cookies, High, Medium High, Medium (default level), Low, and Accept All Cookies.
The following Privacy settings are available with the slider:
Block All Cookies: Cookies from all Web sites will be blocked, and existing cookies on your computer cannot be read by the Web sites that created them. Per-site privacy actions do not override these settings.
High: Blocks cookies that do not have a compact privacy policy or that have a compact privacy policy which specifies that personally identifiable information is used without your explicit consent. Cookies that were already on your computer before you installed Internet Explorer 6 are leashed (restricted so that they can only be read in the first-party context). Per-site privacy actions override these settings.
Medium High: Blocks third-party cookies that do not have a compact privacy policy or that use personally identifiable information without your explicit consent. Blocks first-party cookies that have a compact privacy policy which specifies that personally identifiable information is used without your implicit consent. First-party cookies that do not have a compact privacy policy and cookies that were already on your computer before you installed Internet Explorer 6 are leashed (restricted so that they can only be read in the first-party context). Per-site privacy actions override these settings.
Medium (default level): Blocks third-party cookies that do not have a compact privacy policy or that have a compact privacy policy which specifies that personally identifiable information is used without your implicit consent. First-party cookies that have a compact privacy policy which specifies that personally identifiable information is used without your implicit consent are downgraded (deleted when you close Internet Explorer). First-party cookies that do not have a compact privacy policy are leashed (restricted so that they can only be read in the first-party context). Cookies that were already on your computer before you installed Internet Explorer 6 are also leashed. Per-site privacy actions override these settings.
Low: First-party cookies that do not have a compact privacy policy are leashed (restricted so that they can only be read in the first-party context). Cookies that were already on your computer before you installed Internet Explorer 6 are also leashed. Third-party cookies that do not have a compact privacy policy or that have a compact privacy policy which specifies that personally identifiable information is used without your implicit consent are downgraded (deleted when you close Internet Explorer). Per-site privacy actions override these settings.
Accept All Cookies: All cookies will be saved on your computer, and existing cookies on your computer can be read by the Web sites that created them. Per-site privacy actions do not override these settings.
NOTE: Changing your privacy preferences does not affect the cookie acceptance policy for cookies that have already been set unless you move the slider to Accept All Cookies or Block All Cookies.
Internet Explorer displays a Privacy dialog box the first time that a cookie is restricted based on your privacy preferences. This dialog box appears only one time, unless you clear the Don't show this message again check box. The Privacy dialog box explains that a new status icon (the Privacy Report icon) is added to the status bar when you visit a Web site that does not meet your privacy preferences. You can double-click this icon to view a privacy report that explains how the Web site either has privacy practices that conflict with your preferences or has no published privacy policy. You can also view a privacy report for any site by clicking Privacy Report on the View menu.
NOTE: The Privacy slider works only in the Internet zone. All cookies are automatically accepted from Web sites in both the Local Intranet and Trusted zones, and all cookies are automatically blocked from Web sites in the Restricted zone.
Jun 03, 2011 | Facebook Social Network
Can't login o fb because of cookies something i'm trying to figure out how to do to enable cookies
To enable cookies in Mozilla Firefox 3.x (PC):
  1. Click Tools > Options.
  2. Click Privacy in the top panel.
  3. Set 'Firefox will': to Use custom settings for history.
  4. Check the box next to Accept cookies from sites to enable cookies, or uncheck it to disable them.
  5. Click OK.
To enable cookies in Mozilla Firefox 2.x (PC):
  3. Select the checkbox labeled 'Accept cookies from sites.'
  4. Click OK.
To enable cookies in Mozilla Firefox (Mac):
  1. Go to the Firefox drop-down menu.
  2. Select Preferences.
  3. Click Privacy.
  4. Set 'Firefox will': to Use custom settings for history.
  5. Check the box next to Accept cookies from sites to enable cookies, or uncheck it to disable them.
  6. Click OK.
To enable cookies in Internet Explorer 7 or 8:
  1. Click Start > Control Panel. (Note: with Windows XP Classic View, click the Windows Start button > Settings > Control Panel).
  2. Double-click the Internet Options icon.
  3. Click the Privacy tab.
  4. Click the Advanced button.
  5. Select the option 'Override automatic cookie handling' under the Cookies section in the Advanced Privacy Settings window.
  6. Select the 'Accept' or 'Prompt' option under 'First-party Cookies.'
  7. Select the 'Accept' or 'Prompt' option under 'Third-party Cookies.' (Note: if you select the 'Prompt' option, you'll be prompted to click OK every time a website attempts to send you a cookie.)
  8. In the Internet Options window, click OK to exit.
To enable cookies in Internet Explorer 6:
  2. Click the Advanced button.
  3. Select the option 'Override Automatic Cookie Handling.'
  4. Select the 'Accept' or 'Prompt' option under 'First-party Cookies.'
  5. Select the 'Accept' or 'Prompt' option under 'Third-party Cookies.' (Note: if you select the 'Prompt' option, you'll be prompted to click OK every time a website attempts to send you a cookie.)
  6. In the Internet Options window, click OK to exit.
To enable cookies in Chrome (PC):
  1. Click the Tools menu.
  2. Select Options.
  3. Click the Under the Hood tab.
  4. Click Content settings in the 'Privacy' section.
  5. Make sure Allow local data to be set is selected to allow both first-party and third-party cookies. For any given webpage, first-party cookies are cookies that are set by the site domain listed in the address bar. Third-party cookies come from other domain sources that have items, such as ads or images, embedded on the page. If you only want to accept first-party cookies, check the box next to Block all third-party cookies without exception.
To enable cookies in Chrome (Mac):
  1. Select Chrome > Preferences on the menu bar.
  2. Click the Under the Hood tab.
  3. Click Content settings in the 'Privacy' section.
  4. Make sure Allow local data to be set is selected to allow both first-party and third-party cookies. For any given webpage, first-party cookies are cookies that are set by the site domain listed in the address bar. Third-party cookies come from other domain sources that have items, such as ads or images, embedded on the page. If you only want to accept first-party cookies, check the box next to Block all third-party cookies without exception.
To enable cookies in Safari:
  1. Go to the Safari drop-down menu.
  3. Click Security in the top panel.
  4. Under 'Accept Cookies' select the option 'Only from sites you navigate to.'
If you've already checked that your cookies are enabled and you're still seeing an error message that your browser's cookie functionality is turned off, try opening a new window in your browser. Sometimes using tabs in a single browser instance can cause your cookies to stick.
Sep 15, 2010 | Compaq Presario 5000 PC Desktop
I cannot access any site as it is telling me i need to enable cookies how would i do this please
To enable cookies in IE 7 or IE 8:
  4. Click OK.
To enable cookies in Mozilla Firefox 1.x (PC):
  3. Click the Cookies tab.
  4. Select the checkbox labeled 'Allow sites to set cookies.'
  5. Click OK.
Regards.
Jan 26, 2010 | Microsoft Windows Vista Ultimate Edition
How do i enable cookies?
hi friend,
How to Enable Cookies To enable cookies, follow the instructions below for the browser version you are using. Mozilla Firefox (1.0 final release and earlier) * Go to the "Tools" menu. * Select "Options". * Select the "Privacy" icon in the left panel. * Check the box corresponding to "Allow sites to set cookies". * Click "OK" to save changes. Netscape 7.1/Mozilla 5.0 * Select "Preferences" from the Edit menu. * Click on the arrow next to "Privacy & Security" in the scrolling window to expand. * Under "Privacy & Security", select "Cookies." * Select "Enable all cookies". * Click "OK". Microsoft Internet Explorer 6.0+ * Select "Internet Options" from the Tools menu. * Click on the "Privacy" tab. * Click the "Default" button (or manually slide the bar down to "Medium") under "Settings". * Click "OK". Microsoft Internet Explorer 5.x * Select "Internet Options" from the Tools menu. * Click on the "Security" tab. * Click the "Custom Level" button. * Scroll down to the "Cookies" section. * To enable: o Set "Allow cookies that are stored on your computer" to "Enable". o Set "Allow per-session cookies" to "Enable". * Click "OK". Microsoft Internet Explorer 4.x * Select "Internet Options" from the View menu. * Click on the "Advanced" tab. * Scroll down to find "Cookies" within the "Security" section. * To enable: o Select "Always accept cookies". * Click "OK". Netscape Communicator 4.x * Select "Preferences" from the Edit menu. * Find the "Cookies" section in the "Advanced" category. * To enable: o Select "Accept all cookies" (or "Enable all cookies"). * Click "OK".
hope this helps u
please rate me.........................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Dell Computers & Internet
I guess my problem is i just can't login to the right place to
If you're having trouble logging in to your Facebook account, you might assume that you forgot your password. But maybe the Caps Lock key is tripping you up. Facebook passwords are case-sensitive, so "QWERTY7" is not treated the same as "qwerty7". Turn off the Caps Lock, and try again.
Still no joy? It might be a cookies problem. If cookies are disabled in your browser, you'll be returned to the login page even after entering the correct password. If you use Internet Explorermag-glass_10x10.gif, click on Tools / Internet Options / Privacy and change the setting to Medium to allow cookies. Firefox users, go toTools / Options / Privacy and check the "Accept cookies from sites" box.
Restart your browser and try to log in again. It's also possible that cookies are being blocked by some over-zealous firewall, anti-virus or anti-spyware software, so check your settings there if problems persist. If you have heard stories that browser cookies are evil, read Eat Your Cookies for more information.
Okay, if none of that helped, you probably DID forget your password. No problem... just click the handyForgot Password? link under the Facebook Login button. You'll see the "Trouble Accessing Your Account?" screen that's pictured here. Enter your email address (the one you used to sign up for your Facebook account) and Facebook will send you an email describing how to reset your password. You won't actually get your old password back, but you will get to pick a new one and regain access to your account.
So what if you forgot your password AND your email address? Or what if you can't login to that email account for some reason? Some sites have an automated way to regain access to your account by asking you to answer one or more security questions, but unfortunately Facebook doesn't. You can contact Facebook by email at [email protected], explain your situation, and hope for the best. Your Facebook profile does have a security question, so I recommend that you include that question and answer when you grovel. But with millions of members, I would not expect a speedy response. I'd even suggest that you repeat your request if you haven't heard back in a day or two.
Aug 05, 2009 | Facebook Social Network
Enable cookies
Follow these simple steps to enable “Cookies” in Internet Explorer 7 for all web sites.
Open your browser, and select Internet Options from the Tools menu at the top.
Now on the option screen select the Privacy tab.
Make sure the slider is not set to “Block All Cookies”.
The best setting is to set the option to “Medium,” then click Apply and then ok to save the changes.
If you are still having problems getting Internet Explorer 7 to remember your login information, you may need to add your favorite web sites to your list of sites that can use cookies.
To set it for just certain web sites do the following
Open your browser, select Internet Options, from the Tools menu at the top.
From the option screen Click the Privacy tab.
Click on the Sites” button for web sites.
Enter “the web site address that you wish to provide permissions to into the “Address of website:” field.
Next click on the “Allow” button.
Click on the OK to close the “Per Site Privacy Options” window.
Next click on the “Advanced” button.
If “Override automatic cookie handling” is checked, make sure “Accept” is selected for both “First-party cookies” and “Third-party cookies”.
Now click on the OK to close the “Advanced Privacy Options” window.
Finally click on the OK to close the “Internet Options” window.
Now Internet Explorer 7 will remember the permissions set for your favorite websites and accept cookies!
For other browsers you can find here
http://www.google.com/cookies.html
Good Luck.
Live, Love, Laugh.
May 09, 2008 | Compaq Cluster Enabling Kit (SWDKT-DD) for...
Facebook Social Network Logo
6,672 people viewed this question
Top Facebook Computers & Internet Experts
Daniel Dollive
Daniel Dollive
Mike
ADMIN Canada
ADMIN Canada
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
