Question about Breville Refrigerators
I have a breville aqua water fountain, it is 18 months old, the blue light has gone off and it is know longer chilling and is now making a strange noise.I am really dissapointed it has only lasted 18 months, I have phoned customer service and they could not give me any advice on whether this could be repaired or replaced. Please could you give me any idea if this could be repaired or have i got to spend out on another £120 on another, as if they only last 18 months am reluctant to spend out on another. Regards Dorne
Posted by dee600rr on
Eric Ramos
    Habit-Forming:
    New Friend:
  • 103 Answers
Please check if this is the model you have and maybe this can help. good luck. d066f00e-d454-4535-8840-331d35e2a9ef.pdf
Posted on May 09, 2017
5 Related Answers
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: Whirlpool side by side GS6NBEXRS01
If nothing is blocking ager .. sounds like motor bad or something binding it up. If you took in out and cleaned all ice out and still dont work with no ice.. sounds like motor ..if it hums power is to motor
Posted on Aug 29, 2007
the dr
joey shearer
  • 447 Answers
SOURCE: Kenmore 106.53603202 stopped cooling making a clicking sound
The compressor may not have to be changed it could be the relay that is bad, not properly starting the compressor. The relay is attached to the compressor where the wires go to it. Remove it, Shake it, If it sounds like little rocks are inside (it rattles) than it is bad. Let me know what you find
Posted on Jan 05, 2008
Anonymous
  • 290 Answers
It sounds like you have a burned out start relay on the compressor.
Pull the fridge out and remove the cover at the back. You will see the compressor. The relay plugs onto the compressor and the wires plug on to the relay.
Either the relay is burned out or the compressor is locked up. The only way to know for certain is to replace the relay. The relay is the problem on your model about 98% of the time. You can get one from any Whirlpool parts dealer for around $40, it will cost you around $280 for sears to replace it. The part number is 8201786.
Be sure you replace it with the correct replacement part, a fit-all or 3-in-1 start relay will work for a while but will damage your compressor over time.
Post back if you have any questions.
Mike
Anonymous
If the motor is humming, Take the ice bin out, rinse the bottom shaft connection with warm water, it may just have ice build up.
Posted on Jan 11, 2008
22yooper
James Helmer
  • 828 Answers
SOURCE: Freezer working but refigerator not...
Mullion heater is not the problem. If the refrigerator is not cooling look to the freezer compartment for your problem. Air from the freezer is used to cool the refrigerator(s) section. If the freezer coil frosts up it stops air circulation to the rest of the system. Although you may think the freezer is working properly it may have a defrost problem and will show up there also. Look for signs of frost on the back wall of the freezer as a sign of the coil freezing. The mullion heater is designed to put out just enough heat to stop condensation between the outside temperatures and the inner compartmant temperatures. If the inner compartment is warm the heater will seem warmer than normal.
Posted on Jun 26, 2008
Where could i get an instruction manual for a BJE400 Breville Juice fountain
https://www.breville.com.au/media/mediaappearance/2737/BJE410.pdf
Aug 18, 2016 | Breville Juicers
Breville 860 - no longer getting constant pressure as the coffee shot is being produced. The pressure gauge fluctuates and the noise is no longer constant while producing the coffee shot. The machine is...
General with machine that the hot water outlet onto the ground coffee is blocked with very fine grounds. You need to clean this hot water outlet. Often there is a philips head screw in the middle of the perforated outlet that has to be undone.
Aug 25, 2013 | Breville Coffee Makers & Espresso Machines
I bought a pump for my fountain 4 months ago, it stopped working
This sounds like you should check your suction pipeing again and with fish be sure to get a screen for it. Then also check the impeller on the pump to be sure nothing inside it. You will need to open the pump to do this. If it has been working their is probally nothing wrong with the pump itself.
Dec 14, 2009 | Aqua Garden
How do you use a breville wc15xl wine chiller
HOW TO USE
First you place the Wine Cooler on a flat, dry surface, making sure that the timer is in the "off" position.
Remove the chill cells from the freezer and place around the inside of the cooler.
Thirdly, place the bottle inside the cooler and then pour cold tap water inside, until it just covers the top of the chill cells.
You can then plug the unit in, or if it has batteries you don't need to.
Finally, you set the control dial to the desired time. The following are recommendations for different types of beverages:
Sparkling Wine, Champagne and Dessert Wine.....9 minutes
Dry Wines, Sauvignon Blanc, Riesling.....6 minutes
Chardonnay, Rose'....5 minutes
Light Red Wines, Pinot Noir....3.8 minutes
Full Bodied Reds, Shiraz, Grenache, Cab Sauvignon, Merlot....3 minutes
If you choose to chill a beverage without the timer, you just turn the control to the left and when you are done you turn it to the off position.
In addition to wine, the cooler can also chill beer and soft drinks. The only limitation is that the bottle diameter can be no more than 3.75 inches.
Should you wish to chill two or more consecutive bottles, the cells will remain cold enough for you to to do so.
While not in use, the cooler can also be used on the table with ice to keep your beverages cold (much like a regular ice bucket).
The power cord is removable, which makes for an easy clean-up.
The unit comes with a manufacturer's One-Year Limited Warranty.
Apr 10, 2009 | Breville WC15XL Compact Wine Cooler
I have the breville Aqua Fountain AF5 and the red light indicator will not turn on. Can you help as to why the red light will not illuminate.
have you changed the filter ? if its still operating, and you have changed the filter, the (LED) might be burned out, if its a new unit, then take it back where you purchased it and have them replace it, if its an older unit and it still works, then you might have to live with no (LED) , hope that helped
Jan 18, 2009 | Heating & Cooling
Krups FNC3 Espresso Machine
If it's only 18 months old surely it will still be under some sort of manufacturers guarantee, you don't bin 18 month old coffeemakers nor should you be paying to fix them. Put the problem back in their lap.
Aug 01, 2017 | Krups Novo 3000 /FNC3 Espresso Machine
USER MANUAL FOR BREVILLE JUICE FOUNTAIN BJE200XL
Hi - You can download the manual from the link underlined in blue below:
BJE200XL
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 30, 2008 | Breville Juicers
Espresso Machine Stopped Working
Mine stopped heating (pumped only cold water) and when I opened the top of the machine I noticed that the blue electrical cable to the thermal block assembly (probably to the thermal fuse, but I an not sure about that) corroded and was loose. I fixed the connection and since then the machine heats perfect.
May 12, 2008 | Breville ESP8XL Espresso Machine
Refrigerators Logo
117 people viewed this question
Top Breville Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
Are you a Breville Refrigerator Expert? Answer questions, earn points and help others
