Question about Garden
Cc rt65 tiller are tines suppose to move on the mounting plate? Named articulating tines & they mount with 2 washers and one of bolt holes is oblong makes me believe that they are suppose to pivot.
Cub cadet RT 65 rear tine tiller
Posted by Aaron Bova on
5 Related Answers
bluegreenash
Gareth Cockram
  • 661 Answers
SOURCE: Cannot find VESA holes...Samsung Syncmaster 970p
I have looked at the specification for this, and although it does show as being VESA compatible (This is a display standard) There is no mention of any "wall mounting" capabilities at all, which would lead me to believe that this is not designed to be put on a mount. also the "Magic Rotation" Technology which is part of this device may rely on it using the proprietory stand, it may well be possible to remove the stand however, but it would require some significant dissasembly as the power connector is on the signal box, and this would need to be seperated from the stand itself. The mounting bolts look to be hidden behind the round pivot cover on the back, and it may be possible to see if mounting is possible simply by removing this, however I would seek information from the manufacturer about this as removing any of the covers would most likely invalidate your warranty, it is possible that this was missold to you and you should be able to take it back as not being fit for purpose.
Posted on Sep 15, 2007
Anonymous
  • 243 Answers
SOURCE: install front motor mount
Probably you have to loosen the rear mounting as well so that you can get a little bit more play in the movement to fir the bolt in.
Cheers
Posted on Oct 28, 2008
Anonymous
  • 138 Answers
SOURCE: Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Posted on Aug 21, 2009
Anonymous
  • 205 Answers
SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Posted on Oct 13, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: I have an Olevia 332 b11 LCD tv. I want to mount
There should be at least 4 mounting holes (VESA mount), and they should be used.
Posted on Dec 17, 2009
Cub Cadet RT 65 rototiller wheels aren't engaging
It's possible you have snapped the shear pin in the transmission shaft.
Jan 25, 2018 | Cub Cadet Garden
I need to know what brand and type of oil to put in my cub cadet rt 65 tiller
As 1st option,It would be best to call the manufacturer Cub Cadet,or their Authorized Repair Center,and ask them directly.
Refer to the manual that came with the tiller.
As 2nd option, a general small engine repair shop can be helpful too.
Have a nice day.
Apr 23, 2016 | Horizontal Ohc Engine 190cc,gc...
I have a cub cadet rt65 tiller. Had a new honda gc 190 engine installed and now there is no power getting to the tines. Tried a new belt and that did not help.
Check and see if the safety pin in the shaft on your drive pulley or your tine shaft is broken. Does every thing turn up to your tines if so that could be the problem. There is a pin that breaks instead of doing damage if you hit something. After a while they just wear out.
Feb 09, 2015 | Cub Cadet Garden
How to fix broken chain on a 65 ortt rear tine husqvarna tiller
If you are in a hurray a cutting torch , hammer and chisel method might work. other wise flip the thing over remove the tines split the housing and remove the chain
Aug 26, 2014 | Garden
Oil drain location on cub cadet rt65
How old is it? Lots of newer small engines don't have a drain plug. You tilt it on its side and let the oil run out the oil filler hole after removing the dip stick. I put a piece of plastic shopping bag over the gas tank hole and put gas cap back on to help keep gas from coming out. Good luck.
Jul 26, 2014 | Cub Cadet RT65E - RT65E 18" 208cc Dual...
Cannot engage the gears for RT tiller
I have spent time researching this as mine just did this. It seems you will need to take apart the gearbox and find the issue there, most say some part has bearings inside it that have no grease, and no way for grease to get in there...then it causes something else to break and get stuck.
Trying to decide whether I should try to fix it or take to service tech or ditch it all together.
Jan 30, 2013 | Cub Cadet Rt 65es Tiller 2011 Model
Cub Cadet RT65. Cannot shift into gear so the tiller will till. will go frrom nuetral to reverse and forward but not reverse till or forward till.
Hi I'm Peter. I realize this is an old post but I will answer it anyway for anyone that has the same question. I just finished rebuilding a Cub Cadet RT 65 Transmission. There are a couple of problems you may be facing. First the shifting shaft that goes down into the transmission is not sealed verywell so my understanding is that water from rain or washing the unit may run down into transmission. and may rust up some parts. You can try spraying penetrating oil and moving it back and forth and you may free it up. I am doubtful though but it's worth a try. The shaft has an arm with a little shaft on it that slides in the grove of a shifting yoke. The shift yoke is mounted on a shaft that has detent groves in it. The yoke has a stiff spring and ball in it that when you shift the transmission it slides up and down to the various groves of which each is either neutral or one of the drive or drive and tiller engagement positions. If your unit is like a few I've seen they have been packed with grease and the little ball and spring cannot get lubrication so they wind up freazing up makeing it near or impossible to move the yoke up and down which fits around the shaft of the primary shift gears that move up and down with the yoke. As they move up and down they will engage the transmission the the various modes of travel and operation. There are other problems also as several of the gears in the transmission have needle bearings so if your unit has only grease in it and not a type of gear oil the needle bearings have no way for the grease to get to them so they destroy themselves which may lead to a catistrphic failure which may include gear teeth being broken off and locking up the transmission. Needless to say the transmission case will have to be split and all new bearings installed plus replacing any other damaged gears, chains, , etc. You can order the bearings from multiple places Cub Cadet of course or you may do as I did and go to Mader bearing or what ever local bearing supply shop in your area and buy new ones. Remember take the old ones with you so they can match up the ones for your particular unit. I can tell you some of the parts/gears are used in most of the same size tillers of nearly all of the major brands. Yep Troybilt, Cub Cadet, Ryobi, Craftsman so there may be minor differences but I'm beginning to suspect as with a lot of appliances today that there is one company that builds them and sells them to the different Name Brands to put their logos on or either they just get their parts from the same place. LOL. There are a couple of videos on you tube that a fellow has taken his apart and filled it with grease. I haven't found it yet in my manuals but from all my years as a mechanic most transmissions have some type of gear oil in them and not grease hence the needle bearing getting destroyed.. I have read refeerences that say that the Cub Cadets at Tractor Supply come with oil in then then people have said they read to put grease in the transmissions when they get low on oil because a seal leakeed. What ever ! I say replace the seal and make the necessary changes if any need to be made so that you can run gear oil in them. The oil can reach the needle bearings and give them a longer life as the grease is unable to rech them. There are several sources I believe even Cub Cadet offers a free download of the Ownes Manual and a parts manual with a breakdown of the transmission including parts numbers.I replaced all the seals and bearings in mine for maybe $60 and a gear that is universal to all of the tillers for around $80. Prices can vary a lot so shop around. The same gear can be had from $ 79.99 - $ 129.00. They even all use the same parts number between the major brands. The drawing in the parts Manual is very confusing so to help everyone out I put a video on you tube Cub Cadet RT 65 Tiller where I have a cleaned transmission with all the gears in the case and I take the out, show you their positions, explain the operation of the transmission and then show how to assemble the gears in their proper place. I also explain and show the dentent shaft and shifting yoke operation. The link is https://www.youtube.com/watch?v=GVgOPCRpc5o&t=1s Please like and subscribe so I can put some more videos up to help more people. Comments and questions are always welcome. Hope this helps Peter Cub Cadet RT 65 Tiller
May 08, 2011 | Cub Cadet 1 Rotary Tiller Operator ...
I have a cub cadet model 21ab455c756 tiller. Worked fine when put away 3mos ago. Today... tines appear locked up. Wont turn. Gear selector lever clicks freely thru the different speeds/options. When trying...
Hi, I'm Peter I would first tilt the tiller up and put some kind of blocking up it to hold the rear end up so you can access the tines. It sounds like you may have debris, vines, string, wire, etc wraped up around and in your tines. This is very common and the best way I have found to remove this mess is with a good pair of side cutters, ( Dikes ) and a pair of needle nose and pliers to grab the bits and pieces as you cut them out. Becareful not to let the tiller fall on you or your hand slip hitting the tines or other sharp metal and wire that may be in the mess. If once all that is cleared and you still are having problems then I will post this from one of my previous post. I hope it isn't this serious as it sounds like you have a new tiller. If not and it's second hand then this added information may be helpful.
Hi I'm Peter. I realize this is an old post but I will answer it anyway for anyone that has the same question. I just finished rebuilding a Cub Cadet RT 65 Transmission. There are a couple of problems you may be facing. First the shifting shaft that goes down into the transmission is not sealed verywell so my understanding is that water from rain or washing the unit may run down into transmission. and may rust up some parts. You can try spraying penetrating oil and moving it back and forth and you may free it up. I am doubtful though but it's worth a try. The shaft has an arm with a little shaft on it that slides in the grove of a shifting yoke. The shift yoke is mounted on a shaft that has detent groves in it. The yoke has a stiff spring and ball in it that when you shift the transmission it slides up and down to the various groves of which each is either neutral or one of the drive or drive and tiller engagement positions. If your unit is like a few I've seen they have been packed with grease and the little ball and spring cannot get lubrication so they wind up freazing up makeing it near or impossible to move the yoke up and down which fits around the shaft of the primary shift gears that move up and down with the yoke. As they move up and down they will engage the transmission the the various modes of travel and operation. There are other problems also as several of the gears in the transmission have needle bearings so if your unit has only grease in it and not a type of gear oil the needle bearings have no way for the grease to get to them so they destroy themselves which may lead to a catistrphic failure which may include gear teeth being broken off and locking up the transmission. Needless to say the transmission case will have to be split and all new bearings installed plus replacing any other damaged gears, chains, , etc. You can order the bearings from multiple places Cub Cadet of course or you may do as I did and go to Mader bearing or what ever local bearing supply shop in your area and buy new ones. Remember take the old ones with you so they can match up the ones for your particular unit. I can tell you some of the parts/gears are used in most of the same size tillers of nearly all of the major brands. Yep Troybilt, Cub Cadet, Ryobi, Craftsman so there may be minor differences but I'm beginning to suspect as with a lot of appliances today that there is one company that builds them and sells them to the different Name Brands to put their logos on or either they just get their parts from the same place. LOL. There are a couple of videos on you tube that a fellow has taken his apart and filled it with grease. I haven't found it yet in my manuals but from all my years as a mechanic most transmissions have some type of gear oil in them and not grease hence the needle bearing getting destroyed.. I have read references that say that the Cub Cadets at Tractor Supply come with oil in them then people have said they read to put grease in the transmissions when they get low on oil because a seal leaked. What ever ! I say replace the seal and make the necessary changes if any need to be made so that you can run gear oil in them. The oil can reach the needle bearings and give them a longer life as the grease is unable to reach them. There are several sources I believe even Cub Cadet offers a free download of the Owners Manual and a parts manual with a breakdown of the transmission including parts numbers.I replaced all the seals and bearings in mine for maybe $60 and a gear that is universal to all of the tillers for around $80. Prices can vary a lot so shop around. The same gear can be had from $ 79.99 - $ 129.00. They even all use the same parts number between the major brands. The drawing in the parts Manual is very confusing so to help everyone out I put a video on you tube Cub Cadet RT 65 Tiller where I have a cleaned transmission with all the gears in the case and I take the out, show you their positions, explain the operation of the transmission and then show how to assemble the gears in their proper place. I also explain and show the detent shaft and shifting yoke operation. The link ishttps://www.youtube.com/watch?v=GVgOPCRpc5o&t=1sPlease like and subscribe so I can put some more videos up to help more people. Comments and questions are always welcome. Hope this helps Peter
Nov 03, 2010 | Cub Cadet 1 Rotary Tiller Operator ...
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
