Question about Kenmore Refrigerators
Where are the temperature controls for a Kenmore Coldspot?
Posted by Frank B Fowlkes on
1 Related Answer
Anonymous
  • 17 Answers
SOURCE: Kenmore side by side coldspot, model 5687
I'm not trying to be a smart ***,but a lower temperature setting would make it colder.Try using a higher temperature setting.If this was just a poor choice of words you may need to replace your thermostat.
Posted on Jun 18, 2009
I have a model # 955031636 Kenmore coldspot indoor light comes on nothing else,possible causes?
The inside light confirms power is getting to the refrigerator. You may have to operate a control such as the temperature setting to start operation.
Apr 18, 2016 | Kenmore Refrigerators
Kenmore coldspot model 106: top freezer leaks water slowly into botton refrigerator. how do I repair it?
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Dec 19, 2010 | Kenmore Refrigerators
Kenmore coldspot refrigerator model #106 RUMBLING!!!
Does it have automatic ice cube maker not hooked up to water? If you do make sure thin stainless bar isn't straight down. on the side of ice maker.
Nov 15, 2017 | Kenmore Refrigerators
Jun 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Where is timer located
Should be in the control area inside the fresh food section.
Phil
Apr 15, 2009 | Refrigerators
Kenmore coldspot
Behind you crisper drawers is an opening to the freezer compartment for air return from the refrigerator. If it is blocked it can cause the problem you posted. The temperature of the refrigerator section controls the running of the system.
Jun 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
126 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
