Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
Blackspur ES100I have tried every code I may have used on the
I have a Blackspur ES100I have tried every code I may have used on the box!! I can open it with a key, but need to change the code to one I remember.
Posted by veronicatrue on
Norman Al-Anbar
  • 630 Answers
Try to remove the battries for about 3 min. then put new ones and try it may work...let me know
Please do not forget to rate my service for the site to continue helping everyone and improve on it.
Posted on Sep 17, 2009
Blackspur BB- ES100 electronic safe, batteries dead, lost key. Any suggestions?
You're going to have to cut your way into it, I'm afraid.
If you leave it for a week or so, the batteries MAY just have enough charge to open the safe once more.
Feb 14, 2015 | Locks & Locksmithing
We don't remember the code please help with the axample
You must be having the manual override keys. Just open the safe with those keys and reset the passcode.
Jul 14, 2014 | Safe International Digital Electronic Safe...
I have a supra touch pad key lock but the code accidently got changed and no one can remember it how do we open it now
Well there are may ways,,, I cant really post them here as this is public and a lot of BAD people use the net too.
I once forgot my combination but I used this basically it will generate every possible combination for you, a 5 digit sequence will take about 20 minutes to go through..
Also I remember once a friend left for vacation. While he was out a clever Thief used battery acid to melt away the plastic coating and then used a chisel and hammer or something abound that thereof to break the rest open.
and as another friend told me, When all else fails a Huge Hammer works.
Please remember these locks are Advanced and you should call a locksmith as it will be wrong of us to tell you how to bypass.
Dec 28, 2012 | Supra 001004 Push Button Lock Box Key Safe
I cannot open my Noble safe with the code I had. It seems that my code is gone and I don't find the key to open the safe. What can I do ? songa
I cannot open my Noble safe. I havent used it for 1 year, it has no battery and cant open it with my key. I cant remember the code, but i wont be able ti use it with no batteries.
What can i do
Feb 23, 2011 | Safe International Digital Electronic Safe...
Need to change password from previously changed password
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Once you open the set up page of the router , you will find the place to change the wireless settings of the router. In case of Linksys wireless router , you will see the Wireless Tab at the top.
SSID : It is the name of the wireless network. This name will be shown on your wireless computer or the wireless device so that you can identify your own wireless network. All the routers come with their factory default settings. For example , the Linksys router will come with the Linksys network name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP. This security type is supported by all the operating system. When change the security mode to WEP, you will find the Network key box to type the network key. Do not type anything in the Passphrase box. Type your network key in the Key 1 Box. If you set the encryption to 65 bits, your network key will be 10 digit hexadecimal number. that means you can use the combination of 0,1,2,3,4,5,6,7,8,9 and letters a,b,c,d,e,f only. remember it should be exactly 10.
If you set the Encryption to 128 bit, your network key will be the combination of 26 digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box. in this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box.In this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network
Click Here for more info
Dec 19, 2009 | 2wire 1800HG Router (RG1800HG00)
Ntel(R) Wireless WiFi Link 4965AGN i want to
Wireless Security
WPA
WPA2
Once you change the wireless settings on the router , try to connect to the new wireless network .
Dec 16, 2009 | Computers & Internet
Blackspur ES100. I don't know how to reset the pin code
Check batteries and replace, also make sure contacts for batteries in the safe are clean and not correded with rust, if so rub with sandpaper and clean up.
Sep 17, 2009 | Safe International Digital Electronic Safe...
Change door code on 98 explorer
You will have to find the program code which is located on the processor either in the right front glove box area by the kick panel or in the left rear compartment when the hatch is open...you will see the 6-8 digit security key numbers and enter them on the key pad wait for thebeeps to begin and put your code in quickly befor the beeps end. I would be more specific but as I remember It varied for different models also I worked at Japanese dealerships along with Ford.
Mar 30, 2009 | 1998 Ford Explorer
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
588 people viewed this question
Top Safe International Locks & Locksmithing Experts
Marvin
Marvin
john h
Sheldon Dedek
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
