Question about Compaq A3000 All-In-One InkJet Printer
Printing from firefox 3 I get unrecognisable characters...
For alphanumeric characters. Pictures come thru fine. It prints the same webpage fine when viewed with IE6.
There appears to be no updated driver online for the A3000.
Any ideas?
Posted by nhsl on
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
How do you print horizontal and vertical
What you need is a font style. By default it will print horizontaly. To print vertically you will need to select Vertical in the font style.
When you select a style, that style applies to all characters. Styles can be used with alphanumeric characters and some symbols.
Normal
Bold
Italic
Outline
Shadow
Vertical
To set the font style
1. Press FORMAT .
2. Use the up or down arrow keys to select STYLE and press OK.
3. Use the up or down arrow keys to select a font style and press OK .
May 31, 2010 | Dymo LetraTAG Thermal Label Printer
Brother HL-1470N prints pages of a few
No download from brother website driver specific to your printer and install
Apr 24, 2009 | Brother HL 1470N Laser Printer
Web pages print ramdom characters
Try a different version I had it happen to me, so if it did it using 9.0 adobe acrobat reader I would go to 5.0 or 6.0 version instead and then it would solve my problem everytime it's a hassle but don't know any other way around so that's my best advice.
Dec 12, 2008 | Compaq A3000 All-In-One InkJet Printer
Printing AklphaNumberic Barcode using I2of5 Format
Indeed, I2of5 is numeric, use the 3of9 or 128 A or B to encode alphanumeric characters. Roberto Martinez Mexico [email protected]
Nov 13, 2008 | Zebra Z4M Printer
I am trying to print something from a web page on the internet and it will only print from the left to the right, leaving about 2 to 3 inches of info out. How do i get it to print the entire thing?
I would guess you are using Internet Explorer when you try to print this. Internet explorer has a bad habit of not printing the whole page. Go to a search engine and search for "Firefox". That is another browser and it will print the entire page when you use it to print out webpages.
Nov 10, 2008 | HP Office Equipment & Supplies
Prints computer jargon instead of what I see on the screen (on line only)
We need more information...
1.) What is the make / model of the printer?
2.) What is the O/S of the computer
3.) What kind of "jargon" (alphanumeric characters or symbols?)
4.) When was it last working? What changed since?
y'know.. things like that will help us help you with a solution.
Oct 06, 2008 | Lexmark Office Equipment & Supplies
HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Jun 24, 2008 | HP LaserJet 2100 Printer
HL-2070N will not properly print
My guess is the problem is with Firefox trying to print the page and not the printer. Try to go to File > Print Preview and see if it looks normal there. If not, I have 3 suggestions:
  1. Try to change the "Page Options" or "Scale" under the Print Preview
  2. Try to install and use the Firefox Add-On "IE Tab". This gives you the choice to display the page with Internet Explorer, while still using Firefox. You can turn on IE Tab, and then try to print. https://addons.mozilla.org/en-US/firefox/addon/1419
  3. Upgrade to Firefox 3.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jerry_779afc81ec0a7712
Mar 21, 2008 | Brother HL-2070N Laser Printer
Printer is printing code from webpages I am trying to print
Steps:
Start-> Control Panel-> printers and faxes/printers/devices and printer.
Do right-click on printer icon and select properties.
Click on Advanced tab.
Select the option "print directly to printer" and click on Apply and Ok.
Then try to print , hope it works.
Jan 09, 2007 | Brother MFC 420CN All-In-One InkJet...
Compaq A3000 All-In-One InkJet Printer Logo
Top Compaq Office Equipment & Supplies Experts
efs_perpends
efs_perpends
Jax Planet
Jax Planet
Mike
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
