Question about Mitsubishi WS-55511 55" Rear Projection Television
Mistubishi WS-55511 won't stay on
I have a Mitssubishi WS-55511. I tried holding the menu and device buttons down as suggested. Instead of 2blinks pause 2blinks, I got 2blinks pause 3blinks. Does anyone have a diagnosis for this problem
Posted by brentont6 on
  • 1 more comment
  • brentont6 Sep 17, 2009
    I turned the TV off and on then ran the test again. The code is 2 blinks, then three 3 blinks.
    Thanks for the help.
  • SD Tech
    SD Tech May 11, 2010
    IF code is 2 blinks, then three blinks it is error code : deflection circuit problem---it can mean a problem either in the horizontal or Vertical circuits--most likely it will not be fixed in your home-----set detects no deflection and shuts down instantly for protection of the picture tubes and or the TV power supply.
  • SD Tech
    unplug set and plug it back in. Turn it on and when it shuts off do the self check again--it should repeat the SAME error code about 10 times. if it is 2,pause and 2 I can tell you what the problem most likely is. SD TECH
Anonymous
  • 68 Answers
23 is a horizontal deflection error could be ho transistor flyback or high voltage splitter
Posted on Sep 17, 2009
Power off by itself well not come on.
Do the self check this model has, when green power light comes on and then goes out on the front of the set press and hold both the Menu and Input (device) buttons at the same time for at least 5 seconds, then release both buttons and watch the power light, It will blink a two digit code, a error code.
Most common is 2 blinks, 2 blinks, a pause and then it will repeat the code several times.
Let me know what code you find and I will tell you what it means.
This is a self check meant to narrow down what kind of problem the set has.
Make a comment here so I can help.
SD TECH
Jan 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Bypass Mitsubishi HDTV Lock
Bypass Mitsubishi HDTV Front Button Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
________________________________________
Reset Mitsubishi HDTV VChip Password
Mitsubishi Projection HDTV Manual Download
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Power comes on but goes rite back off
Hello.
you can try to retrieve error code first.
Plug TV into wall outlet. Push power button, let it do whatever it does. After that push BOTH buttons in front of TV named "Menu" and "Input" and hold it for at least 5-6 seconds.
Green LED in front of TV will start blinking error code (when it starts you can let buttons go).
If it clinks like "2 blinks, pause, 2blinks longer pause, repeat" most likely you have convergence issue. Two convergence amps have to be replaced along with couple PICO fuses that already open.
I would strongly recommend to let professional do this repair. As well in case of different error code.
Should cost you in ball park of $250-$300.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi Model WS 55511 was made in March of 2003. I turn it on and it goes right back off again. On the front of this TV I only have an Enter button, a menu button. an A/V Reset Button and a Device...
Device is the same as input--try the self check, when power light goes off press and hold it and menu at same time for five seconds and release.
Device means input.
Let me know error code and I will help you more than anyone else.
SD TECH
Sep 18, 2010 | Mitsubishi WS-55511 55" Rear Projection...
WS-55511 shut itself down while watching TV and won't come back on again. I tried unplugging and reconnecting, it goes through the reset (green light blinking). The convergence went bad and the chip was...
After you turn on and green power light comes on and then goes out:
Press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it 4 more times.
Let me know what error code and I will tell you what it means. If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Powers on for three seconds then goes off
The first thing to do is to try to determine why the set is not turning on. It is equipped with a self diagnostic feature. On the front of the set push the MENU and DEVICE button at the same time and hold until the LED starts flashing a two sequence code. That will narrow things down for us.
Apr 28, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Power up
the error code will be a blink code from the led it should blink a couple times vbriefly pause and then blink again. Count the blinking led in between the slight pause.
Aug 03, 2008 | Mitsubishi WS-55511 55" Rear Projection...
WS-55511
Press in together the menu button and the Device/input button on the set and hold them both in together for 5 seconds and see if the led will blink a two digit error code, then respond to this same post and let me know if it gave a error code and what the two digits were.
Aug 02, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
279 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
