Question about Nikon D90 Digital Camera with 18-105mm lens
We just bought d90 nikon camera and we found a small half-round shadow at the bottom of the pictures taken when we dont use the zoom lens, how do we correct this?
Posted by mckalin on
  • mckalin Sep 23, 2009
    yes, we thought it was the hood but when we removed it and took pics, the same small half round shadow at the bottom center of the picture appeared.
  • Anonymous May 11, 2010
    is this while using the flash? Brentwood IT
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Are these pictures taken using the built-in flash and with the hood on the lens? If so, you're seeing the shadow of the lens hood.
Remove the lens hood when using the built-in flash.
Posted on Dec 22, 2009
Anonymous
The reason that this happens is because the lens is so wide (18mm) that when the flase is used the top part of the lens blocks the bottom portion of the flash thus leaving a half moon in your frame. Vinout
Posted on Sep 21, 2009
  • Anonymous Sep 21, 2009
    Sorry, forgot to add a solution. one of a few ways to correct this is to shoot on 50mm, which is equivlent to what the human eye sees. Another way is to shoot with an off camera flash or with a flash mounted to the hot shoe located on top of the camera. hope this helps you. Enjoy...Vinout
Hi there, I am having the same problem. I have this dark round cicrle on each of my photos weather im outside or inside night or specially at night. I have a D90 nikon and it has a hoood on it and iam...
A huge possibility, without actually seeing the picture is that it's a shadow caused by the lens hood. The internal flash units are "generally" good for up to about 80mm then the focal length of the lens starts getting in the flash burst, add a hood and the problem is compounded. With a 105mm lens and it's hood it's a wonder you didn't cut the bottom 1/3 off the picture. How to correct this shadow well I won't say it can't be done cause someone will disagree. Let me say that it would take some time and some pretty impressive photo programing. If you have an external flash why not use it they "normally" sit higher then the on board flash units.
Jan 09, 2011 | Nikon D90 Digital Camera with 18-105mm...
Is Nikon D90 camera compatable to use on below mentioned lens
Yes. The lens will autofocus and meter properly on the D90. Be aware that the D90's DX sensor will give you the same field of view that a 105-315mm lens would give you on a 35mm film camera.
Oct 20, 2010 | Nikon AF 70-210mm f/4-5.6D Zoom-Nikkor...
Brown tint on photos with Nikon D 90
Or more properly, the shadow of your lens hood.
Aug 03, 2009 | Nikon D90 Digital Camera with 18-105mm...
Lense will not work with SLR Nikon D90
This lens is too old for the D90, it has not got the electronics for metering and autofocus.
You can use it manually in M mode but you will have to set the aperture and shutter yourself.
The D90 manual has a section on compatible lenses, page 228 in my version.
This recommends CPU lenses for the D90, type G and D.
Dec 25, 2008 | Nikon Zoom 80-200mm f/4.0 AIS Lens
Nikon d90 - can't take the picture
You just found the Nikon D90 F-- error message solution!
I had the same problem with the Nikon d90 F-- error message which drove me nuts!
I called Nikon, they walked me through a lengthy reset procedure which didn't work. After spending a few hours researching online, I found the answer.
It is not the memory card or nor a defective camera body. The lens does not need to be rechipped.
The F-- error means the camera is unable to communicate with the lens and is caused by a poor connection between the ground contact pin on the lens and the metal mounting ring on the camera. Most people buy the camera, install the lens once and then encounter the error. This one time lens installaiton does not give the contact point a chance to seat itself properly. You will find that if you hold down the lens release button and twist the lens as if to remove and reinstall the lens about 10 times that the problem will disappear. You don't even have to actually pull the lens away from the body, just press the release button and twist on and off and allow the friction to provide a better electrical contact.
Too bad Nikon doesn't tell their customers about this simple fix. Other than that, great camera. Good luck.
Dec 07, 2008 | Nikon D90 Digital Camera with 18-105mm...
Pictures have a round corner shadows when using my wide angle zoom on my camera, what is this ?
Do you have any filters on the lens? If so, you might be seeing the filter rim. (round filter, rectangular picture)
If you're using a DX lens on an FX body, you also might see this.
Aug 13, 2008 | Nikon Cameras
Shadow on image when using built-in Speedlight
The built-in Speedlight on many Nikon cameras is designed to be a convenient way to either light up a dark subject or to add fill light to a daytime scene. The built-in Speedlight cannot replace a full size, external speedlight which should be used when more power or coverage are needed. Because the built-in Speedlight is compact and close to the camera it cannot be used under all conditions. When using a lens that is physically very long, a subject that is very close, or a wide lens hood it is possible that a shadow may be cast upon the subject. Notice, in the sample below, the round shadow in the bottom center of the photo. When the lens is too long or the coverage is too wide with a close subject a shadow of the lens itself is cast. In figure "A" below the lens is casting a shadow. Switching (or zooming) to a shorter lens (figure "B") prevents the shadow and allows even illumination. If your lens, subject, or lens hood choice create a shadow, an external flash (either on the camera's hot-shoe or connected to the camera by a wire or wirelessly) should be used to fully light the subject.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon D90 Digital Camera with 18-105mm lens Logo
Top Nikon Cameras Experts
Steven Wander
Steven Wander
Jax Planet
Jax Planet
Are you a Nikon Camera Expert? Answer questions, earn points and help others
