Question about Cell Phones
My stylus pen stopped working on my iPads
I used it 20 mins prior to it not working . It turns in and is fully charged
Posted by Stephanie mikler on
5 Related Answers
Anonymous
SOURCE: c pen 20
I found a solution before asking help from c-pen support.
1. Uninstall C-Pen software
2. Remove C Technologies entries from registry. They appear in HKEY_CURRENT_USER\Software and HKEY_LOCAL_MACHINE\Software
3. Reinstall C-Pen software (remove the pen from USB before reinstalling)
This worked in my system(Vista 32-bit).
Posted on Jun 27, 2008
wayneard
Wayne Mineard
  • 1901 Answers
SOURCE: I need a stylus pen for a Leapfrog interactive globe
Simply call Consumer Services at 1-800-701-5327 to order a new pen.
Posted on Dec 30, 2008
Anonymous
  • 64 Answers
SOURCE: olymp c-5000 won't turn on red/ yellow lights blink/ beep 20 time
Furrybutts (hehehe, like the name), This could be a lot of things and I'm sure there's a service guide out there that will tell us what 20 beeps and flashing lights mean, as I don't have one, let's figure it out.
Firstly, digi-cams and rechargables, eerrrrrgggg (Mr Burn's shudder) yeah they 'work', but for trouble shooting and iffy times, lets look at some half desent NEW alkaline batteries - for about $3-$4, it's worth it for this troubleshoot.
OK, did they work?, No?, lets look at the memory card. The cards are supporsed to be only put in one way, but ... lets take out the card, clean the contacts with a clean cloth/tissue, and put the card back in being sure it's in the right way. Still no go?
Take the card out again and try and turn the camera on without the card. Any changes?
This camera uses an XD memory card. I can't remember if it has an internal memory - what we're looking for is whether the memory is damaged and the camera is happy using it's internal memory or still erronous with no memory. Do you have access to another XD card to try it (this camera will take a MAXimum of 512mb, so don't try and card bigger).
Lets leave it at this for now and you let me know how things are going?
**.The best way to acknowledge contribution is to rate it's relevance.**
Posted on Feb 02, 2009
Stephen Yanowich
  • 396 Answers
SOURCE: Intuos 3 Pen/Stylus suddenly stopped working (as in dead).
Will the tablet work with the mouse? If it does not, is not working is the blue LED light on. If the LED is not working try another usb port. If the mouse works go into the Wacom tablet properties from the start menu. Select the grip pen from the tools. Click on the default button to restore the stylus to factory settings. When you press the pen you should see the pressure scale rise. You can also test the eraser pressure. You could also replace the stylus tip to see if that works. From the Wacom site you can order a new stylus or tips if it is found defective.
Posted on Sep 08, 2009
Rick Kasper
  • 2072 Answers
SOURCE: My monitor is stop working after 20 min workintg,
That sounds like somekind of overheating issue with whatever supplies the power to the monitor.
Posted on Feb 17, 2010
I have a 787HD, and am having problems deleting vidieos. The delete button does not respond most of the time, when it does it still won't delete when you hit the yes prompt,
I have encountered the same problem with mine.
This is what I do.
!. Tap rapidly on the confirm button (yes @ no) do not soft tap.
2. Use a stylus pen it's working for Me.
3. Make sure it's fully charge or plugged in.
4. With the stylus pen tap slightly left or right of the choice button you are going to use.
Hope this helps out.
Sep 19, 2014 | Vivitar ViviCam Cameras
Kindle Fire Factory Reset My kindle fire has a
Press and hold the reset button 40 seconds and then press again and see if it helps.
Jun 19, 2017 | Kensington Amazon Kindle Fire / 2nd...
The gyropter will not charge when I plug it in
Check the charger adaptor if it has any output power. If no power comes out replace the adaptor.
Check also the battery terminal, it might already corrode and needs clean up.
If all does not work, the battery in the helicopter is already malfunctioning.
hope that helps you out!
Aug 14, 2011 | JCPenney Gyropter RC Helicopter
New Bigfoot toy for XMAS buzzes three times and stops working. Reset with power switch and does the same thing repeatedly. Made sure battery was fully charged.
There is a pen hole beside power switch........with the power off press and hold this button (with a safety pen or something)....while holding the button turn it on and hold the button for at least 3 seconds. Then push every button on the remote, then charge the battery until the indicator is "green". That will fully reset your Bigfoot.
Jan 02, 2011 | Mattel Fisher-Price Imaginext Big Foot
My toshiba satellite lapto keeps turning itsel off every 20 min, what can i do?
that is a indiaction that its protecting other peripherals from failure and destruction -- Toshiba notebooks do that to tell you taht the fan is not working or the ehatsink portion that helps the CPU has stopped working
what OS are you suing
what is the model and S/N of the computer ?
is your battery fully charged ? and are you using the AC adapter
Oct 16, 2010 | Computers & Internet
Tablet Pen moves very slowly across the screen. It used to work fine, but the last few times I've tried, the mouse ends up moving faster. I used to be able to move the pen across the tablet and the mouse...
This may be a processor issue, as mine does this too.
As for others, most issues surrounding the stylus are battery related.
I will help anybody with a broken, or inoperative stylus/pen get their pen operating again. I have started a business around this issue because so many people's pens are malfunctioning (including mine originally which drove me to do this). This was fueled by Gateway's lack of caring around the issue, and their attempts to charge ridiculous fees for customer service. I charge $20 to switch out the battery to get your stylus working again, plus shipping and handling both ways, about $25 total.
Email me at: kevin teman AT hotmail DOT com
Or,
See my website at:
[url=http://www.kevinteman.com/stylusrepair]Stylus Repair and Battery Replacement[/url]
Thank you, Kevin Teman kevinteman.com/stylusrepair
Feb 25, 2010 | Wacom (EP130EPE) Digital Pen
Hit Navigator key, takes a very long time 20+ min to find location.
There is a problem with your battery level. Make sure its fully charged. if it does not hold a charge when off the power for at least 2 hours then change it. 99.9% of the time low power delays connection to satellites. the max timke is about 9mins but average 1-2mins .....20 mins is not acceptable. I would suspect the battery.
DO NOT power the unit prior to starting the engine when using DC plug of car This will burn off the IC CHIP and damage your units battery.
Sep 02, 2009 | GPS
Cell Phones Logo
Top Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
