Question about RCA TruFlat 27F520T 27" TV
I have a rca truflat tv 27F522T how do i change it from mona to stero
Posted by jennyhype on
Anonymous
  • 93 Answers
Go into the setup menu,select basic settings, select audio & change settings. The set will play stereo when it has a stereo source.
Posted on Sep 17, 2009
Mike McWhinney
  • 537 Answers
This is a stereo TV:
From the manual:
Stereo Capability: Includes built-in amplifier twinspeaker
system; allows reception of TV programs
broadcast in stereo.
Use a stereo cable
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
I dont have a remote for tv /27F522T i cant turn it on
They are available on eBay
http://www.ebay.com.au/sch/i.html?_trksid=p2050601.m570.l1313&_nkw=27F522T+tv+remote&_sacat=0&_from=R40
Feb 15, 2014 | RCA F27664 27" TV
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 28, 2012 | Televison & Video
I need operation manual for a rca tv model 27f522t
You can download the operation manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 16, 2010 | RCA TruFlat 27F520T 27" TV
My 27F522T tv turns itself on and changes channels bu itself.
hi
and first of all if u dont want ur tv to turn on by itself when you dont want it to just un plug the cord and when your going to use it just plug it back on.
Sep 16, 2009 | RCA TruFlat 27F520T 27" TV
Unlockint the rca truflat
just had the same problem... found the old RCA remote in my house... put new batteries in it...used RCA remote.... hit menu... arrow down to preferences and hit "ok" on remote.....use arrow again to go down to FPA lock and hit ok to turn it off, hope this helps, hit menu again to remove menu from your screen
Brenda
Dec 29, 2008 | RCA TruFlat 27F520T 27" TV
RCA TruFlat 27F520T 27" TV Reset
Buy a new remote.
Look around the tv and find the menu button.
Generally there is a separate power button.
You can also download the manual:
http://tv.manualsonline.com/manuals/mfg/rca/27f520t.html
Dec 02, 2017 | RCA TruFlat 27F520T 27" TV
Why does my RCA TV cycle through channels on its own?
Hi there!
I think your remote may be at fault. Liquid spill or sweat from the hand accumelates on the inside over some time and then becomes sticky. Some of the buttons may be permanently activated. Then other functions won't work. Have someone check it for you or if familiar yourself. Regards, JUS004
Mar 12, 2008 | RCA TruFlat 27F520T 27" TV
RCA TRUFLAT VOLUME,CHANNELS MOVE ON THERE OWN
i would honestly suggest if you still have the receipt return it back. dont forget your rating thanks.
This is a very common problem for RCA TV. I have one as well. or go to www.tv.rca.com/ there are free manual there
Jan 25, 2008 | RCA TruFlat 27F520T 27" TV
Unlock rca truflat tv with no remote
Buy a universal remote and program it for the TV. That's the only thing that will work.
Sep 19, 2007 | RCA TruFlat 27F520T 27" TV
RCA TruFlat  27F520T 27" TV Logo
332 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
