Question about Maytag MZD2766GES Side by Side Refrigerator
Freezer works great, but fridg. will not get below 50
The freezer gets down to -15 degrees and adjusts great.
The fridg. will not adjust at all and stays about 50 degrees.
Posted by rchancello on
Charles T Nevin
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Posted on Sep 17, 2009
Anonymous
  • 46 Answers
The fridge should be right at 50 thats normal operating temp.. if you want the frisge colder turn the freezer setting to warmer and the fridge to colder setting and give it 24 hours to adjust
5 Related Answers
Anonymous
  • 878 Answers
SOURCE: Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Posted on Sep 04, 2006
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: warm fridge
Can you check to see if dust has accumulated under the refrigerator and the fan under the refrigerator is blowing warm air?
If the fan is blowing correctly and you find dust blocking the condenser area beneath the fridge try to blow it out or vacuum it away from the fins or metal grid. Just a small amount of dust there or a leaking door gasket will make it hard for the refrigerator to cool properly. Also check that nothing has blocked the entrance or the exit of the condenser warm air area. Hope I have helped you today, Thanks Sea Breeze
Posted on Oct 29, 2007
docjohn174
john gagnon
  • 943 Answers
SOURCE: Fridge not cold
HI thanks for your question. check to see if the fan motor is running in the freezer. that could be the problem. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 09, 2008
Anonymous
SOURCE: fridge does not get cold
I had the same problem. The problem was my freezer was not defrosting itself and for a while i opened up the back and manually defrosted the freezer with a hair dryer (to make it defrost faster) and lots of towels (to soak up all the water). I replaced the defrost heater in the freezer and no more problem. Go to searspartsdirect.com and put in your model # then look for the part. Hope this helps.
Posted on Nov 15, 2008
Anonymous
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
Why does Siemens KF57U56/16 Freezer works fine, but not fridge?
Check the thermostat adjustment in the fridge section if right up replace the thermostat.
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Hi, I have the psc25msta side by side GE. The fridge temp will not go below 45 degrees. The Freezer section is around 0 degrees. Checked the circ fan on the fridge side by opening door and holding...
Check damper between freezer and fridge. If it's mechanical, adjust so it let's more into fridge side. If it's electrical, damper may need replacing
Fridgidaire Mini Fridge not cooling
pulled off back panel on inside of freezer, to find it was a solid block of ice. thawed, and plugged back in... working properly
Freezer gets 10 below 0 and fridge is 60 degrees
Check and clean the condensor coils. Make sure the air ducts are free f frost and not blocked by anything. Make sure the light is turning off when the door is closed.
Eric
Brand new refrigerator not working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp and that the fan in the freezer is running when the compressor runs.
1helpful
My freezer works great but the refrigerator wont go below 60 gegrees any ideas
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
My freezer works fine, but fridge doesn't cool down below 55 degrees. Could it be the adjustment dial in the fridge.(i have cleaned the dust and dirt out of the back/bottom.
It sounds like the circulating fan is wearing out. The fan circulates air thru the freezer as well as the refrigerator. When it starts to wear out the force is reduce to a point that the freezer will get cold but the refrigerator will not get cool.The minimum cost of the assemble is around $300.00
1helpful
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
MSD2454GR Side by Side refrigerator- freezer side fine, refrigerator side will not cool below 50 degrees; lots of condensation
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat.
Maytag MZD2766GES Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Pierre Laplante
Dale Copeland
Dale Copeland
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
