Question about Refrigerators
I have an mxsr-49fd Refrigerator which works, but the temerature gauge ready 96F when it's frozen inside. Why is it doing this?
Posted by William Davis on
1 Related Answer
Ted Schore
  • 7353 Answers
SOURCE: Check Gauges light lit on. Temerature gauge rise
is the cooling fan running?
Posted on Jul 24, 2010
Hi, i have a fridge freezer and both dont seem to
Its a broken Thermostat. Its behind the temerature control dial. Pop up the dial, remove the plastic cover and you can see it. Remove the thermostat and bring to your local electronic shop and ask for a replacement, the same as you have if they have. Put it back together. make sure you remember where all the wires/plug goes. hope this helps
Nov 19, 2009 | Electrolux ERN2820 Bottom Freezer...
Water dispenser does not dispense water. the ice will dispense But any ideas would be appreciated and i am not the best fix-er-upper but can understand easy and simple steps. Model number of fridge is (GE...
Several possibilities. Clogged water filter (can be eliminated if you dump the ice bucket..if it makes two more batches of ice it's not the filter). Frozen water container (behind lower refrigerator drawers) or bad fill valve behind the refrigerator where the water line goes in. Likeliest is water valve.
Final possibility is a frozen water line inside freezer door. This would NOT be desired nor would you be fixing it yourself. Good Luck.
Aug 24, 2009 | Refrigerators
Our produce are spoiling within 2 to 3 days. Do
First I need you to unplug the refrigerator. Remove the rear panel in the back of the freezer and tell me if the coils are clear, frozen or blocked with ice. Make sure both fans were working before unplugging. Below the bottom and the fan inside the freezer. This will let me know if there is a problem with your defrost system. If frozen over use a hair dryer to defrost coils and let me know. We will need to check the defrost heater and defrost thermostat. Let me know when you are ready or if this is helpful, Thanks Sea Breeze
Jul 14, 2009 | Amana Easy Reach Plus ABL2227FES Stainless...
Water will not dispense, the ice is working fine. The filter is installed fine, and checked everything. What else to try
only 3 things could be wrong 1 frozen line inside door 2 water valve not working 3 frozen reservour inside refrigerator section
Oct 31, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridge frozen solid
Usually on refrigerators, the highest setting makes it coldest and the lower settings are warmer, relatively. "6" on my dial says "coldest" - Perhaps this is the case for yours? Let's hope it is that simple
Aug 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
