HP PSC 2410 All-In-One InkJet Printer Logo
Question about HP PSC 2410 All-In-One InkJet Printer
HP psc 2410 photosmart all-in-one not piking up paper
HP psc 2410 photosmart all-in-one not piking up the paper when asked to print. Instead saying it is out of paper when it isn't
Posted by ahartins on
mukhtar21 shaikh
    President:
  • HP Master
  • 2,022 Answers
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Posted on Sep 17, 2009
2answers
Hp psc 2410 photosmart driver win7
HP no longer provides support for drivers for this printer. The newer Windows OS will support the printer natively, but sometimes it requires a little finesse from the user. Here is a link to an HP forum where folks tell how they worked out the communications issue for the print and scanning functions. Hope this helps!
adding hp psc 2410 printer to windows 7
My HP 2410 photosmart printer has started to print everything crooked. The paper is going through perfect but the printer left margin starts to increase about half way down the page. At the bottom the...
probably a simple alignment problem. Go into your maintenance section and there is an option to align . Run this and it should realign your printing. Hope this helps!
Not scanning hp psc 2410 photosmart. it says 2410 is not connected yet i use it daily to print
uninstall printer and reinstall after rebooting.
Use the latest drivers for your operating system.
Some functionality can disappear when the drivers are not fully installed with the latest ones.
Good luck on this.
A spring fell out in my hp psc 2410 photosmart printer and don't know where it goes. now my printer is saying error cartridge jam during printing
i wouldn't even bother trying to repair it, take the printer and the spring to best buy and they will probably fix it for free.
1helpful
My HP PSC 2410 Photosmart All-in-One Printer is get stuck and is not printing. It is not a problem with the paper. It is more like the printing head jumping. It is starting from the very moment the printer...
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
1helpful
My hp psc 2410 photosmart printer will not print - only copy
Check to make sure your PSC 2410 is in fact the default printer. If it is, make sure your cable is firmly plugged in to your printer and CPU. Clear the print queue. Turn off and restart printer. I have found that your problem is basically a communication problem between the computer and printer. Also check www.hp.com. Good luck.
Not printing text
with a wet paper clean up the head of the cartridge, and let some tint go to the napkin, or paper :) Resulted for me
Ben Johnson
Marvin
Marvin
