Question about Paradigm PS1000 Speaker
How do I remove the driver from box in paradigm ps 1000
Posted by Earl Rellinger on
How do I hook up the receiver to the subwoofer to the tv
Here's the Owner's manual -> https://docs.google.com/viewer?url=https%3A%2F%2Fwww.paradigm.com%2Fdownloads%2FOM-100.pdf.
There are many ways to connect the system depending on your receiver's outputs and the speakers. Usually, the TV L/R output connects to one of the receiver's inputs. The receiver's preamp sub output goes to the powered subwoofer. The receiver's FL/C/FR/SL/SR/RL/RR speaker outputs go to the respective speakers.
What is the impedance of the 12" driver in this subwoofer
PS-1200 Specifications
Design
Single driver, DCBS™ system with high velocity resistive ports and built-in amplifier Amplifier High current, hybrid output, 130 watts RMS
Amplifier Features Powersaver auto-on/off, soft clipping, thermal protection Low Pass Filter Frequency Variable 50Hz-150Hz Low Frequency Driver 310 mm, carbon-fiber-reinforced composite cone, Apical™ former Low Frequency Extension 23 Hz (DIN) Sub / Sat Phase Alignment 0 - 180 Finishes Black Ash Inputs From A/V receiver/processor or Paradigm X-Series Control Unit or preamp left/right output; From receiver/amplifier speaker terminals or main/satellite speaker terminals Weight 68 lbs. (31 kg) Dimensions HxWxD 19.75" × 17" × 21"
(50cm × 43cm × 53cm)
Specifications are subject to change without notice.
© 2016 Paradigm Electronics Inc. Conditions of Use Privacy Policy Unauthorized Dealers WARNINGSouth Africa
How to Replace a paradigm monitor 9 v6 driver
Are you having trouble removing the driver? Just remove it and replace, keeping track of where the positive (red) terminal is and what cable is connected there. The part number should be printed on the back of the magnet.
Paradigm Pw 2100 Speaker
the amplicator is stop after 5 second play
1helpful
I have a paradigm ps 1000.it powers on fine when i plug in the rca cable into thoe back of the sub into the low level input it humms supper loud. i tested my cable and used another one same thing. could...
It sounds like it has bad ground on the RCA input assembly, you should Ohm out the ground of the RCA jacks to see if they are all connected.
How about the sender side (the amplifier) ground?
3helpful
Our ten year old paradigm ps 1200 subwoofer does not power up, although it is plugged in and properly connected to the receiver. Why is this? Is it a lost cause?
Disconnect the power, pull the amplifier out by undoing the screws that hold it in.
When you pull it out, look closely towards the top there is a little 1.8A fuse. It probably has blown.
Replace that and you should be back in business.
2helpful
2answers
PAradigm ps-1000 subwoofer
It turns out its most likely one of the resistors on the PCB on the amplifier plate.
My uncle has had the same problem and managed to replace the resistor and its working as normal now.
Power source
I have PS-1000 and same problem. It looks like power transformer got partially shot (reads 11 V AC instead of 56)
I just don't know if it's all the problem or there is something else. And where I can find replacement transformer?
Paradigm PS1000 Speaker Logo
Top Paradigm Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
