Wiring diagram for ignition switch farmall 140 tractor
I need a diagram for the ignition switch, fuse holder and light switch on a international farmall 140 tractor, hope you can help
Posted by rabbitdog4s on
Thomas Stewart
  • 582 Answers
FOUND YOU A WEB SITE FOR WIRING DIAGRAM
CARTER & GRUENEWALD CO. INC.
IF THAT DOSN'T WORK LOOK UNDER FARMALL 140 WIRING DIAGRAMS AND THE SITE WILL BE LISTED THIS SITE WON'T LET ME COPY AND PASTE TO YOU
Posted on Sep 17, 2009
Free 966 international tractor wiring diagram
I don't know where there's a schematic on the web, however, the schematic is in this shop manual:
SMIH203 International Harvester Farmall Shop Manual
Good luck
Nov 03, 2014 | Toys
140 international tractor when turn motor off the motor runs backwards
It is called dieseling. Could be carbon on the plugs or in the combustion chamber. Carbon gets hot enough to cause fuel to keep igniting after ignition is turned off.
Apr 18, 2014 | Farmall International Tractor 140 Radiator
NEED TO KNOW HOW TO TIGHTING STEERING ON 140 tractor
if all tie rods are tight the steering box has a philips screw with a jam nut loose nut turn screw in until it stops, back out a little tighten jam nut. that takes slack out of worm gear. hope this helps
Aug 01, 2010 | Farmall International Tractor 140 Radiator
Battery polarity
yes it is correct it is just the way it is
May 11, 2010 | Farmall IH Tractor 130, 140, w/c123 Eng...
Computers & Internet Logo
3,059 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
