Question about Refrigerators
There is at least a cup of water a day in the evaporation tray. is this normal?
Posted by cynthia dean on
2 Related Answers
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: 532 sub zero evaporation tray is filling up with a
This is only normal in an environment of high humidity. My question is the condenser fan blowing over the condensate pan and is the air hot enough to evaporate the water that is in the pan? Has covers been removed on the rear of the refrigerator that may cause a different flow of air. Are all covers in there correct place and not missing panels that could change the flow of air over the pan? Let me know, Thanks, Sea Breeze
Posted on Aug 26, 2009
Anonymous
  • 103 Answers
SOURCE: What is the normal amount of water accumulation in the drain tray
No, it's not normal for it to be over flowing. Check to make sure you have the temps set correctly. Timer/electronic control on these units have been known to "run" too long, causing the evap to build up too much frost before going into defrost mode. Check to make surre to that you don't have signs of "moisture" around the doors, if you do then you have a door gasket leaking air into the frig or freezer causing excessive moisture within the evap coils.
Posted on Oct 09, 2009
Why does drain pan overflow? How is water in pan suppose to go away before overflowing?
Are you sure it is the drain pan overflowing? If water is appearing on the floor every few days, it may not be getting to the drain pan (evaporator tray), due to a blocked drain channel. The evaporator tray will normally cope with the daily amount of de iced water of a frost free fridge/freezer.
Mar 07, 2015 | Refrigerators
How do I get water out of fabric softener cup
This is normal to have left over standing water in the softener dispenser cup. That being said, some units can have more standing water than others because the machine isn't level (try leveling the unit).
Note: Softener is a "wax" and can clog up the water inlet openings. You can remove the whole dispenser assembly by pulling all the way out and depressing a button while pulling on dispenser tray. (button located middle-back)
For future parts or diagrams visit us here. Appliance Parts
Feb 05, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water from back on to floor
This could be that the drain tank at thebottom of the fridge is overflowing. Normally the drain water will evaporate off with the heat from the compressor but if possible it is good to clean and drain the collecting tray in the bottom of the fridge. You must have access to the backside of the fridge and remove the tray which is normally a pulllout. Drain , clean and put it back-- slide it in. Hope you do thei. Also make sure that the freezer setings are normal and not set high. During cold season this can condense more water to overflow the drain. Hope you try., Good day
Aug 10, 2010 | Refrigerators
It has a nasty smell like diesel fuel in the freezer but it works fine.
Your cooling unit may have a leak, and you are smelling the coolant, though normally this would be ammonia.
You may have food that is spoiling as well. Check the condensate / drip tray at the back of the fridge (inside). Look for water building up (likely green as well). If water is not draining, clean the hose that leads from the drip tray to the exterior back of the fridge. There will be a small evaporator cup / tray that the hose empties into. Check the end of the hose for insect activity. Note that it is normal for the end to be crimped, or it may have a plastic plug (perforated) inserted as well.
May 31, 2010 | Thetford Norcold RV Cooler/Freezer
Cooks coffee maker brews about 2 fewer cups than the amount of water poured in. It does seem to steam excessively. What's going on?
This is called evaporation :P
No but seriously, try to not fill it up more than is needed for the amount of cups you are making at the time, because otherwise you waste electricity anyways.
The more water you put in, the more power it takes to boil it. If you don't use some of the water, you have to re boil it again later, hence wasting water.
If it holds a lot of water, then you could loose up to 2 cups anyway, just from evaporation, it's completely normal
Mar 06, 2010 | Cook's Essentials Cooks Essentials Arome...
Kenmore 52552100 Side by Side ice in bottom of freezer
I had the same problem. And after some research I went at it yesterday. I unplugged the refrigerator and removed the bottom two racks in the freezer. The tray at the bottom of the defrost assembly was caked with ice. I didn't know where the drain plug was. I started melting the ice using a hair dryer. I also carefully broke up the ice using a knife. After the ice was removed I could locate the drain hole. I used a copper wire shaped like an "L" and tried chipping away at it with no luck. I then poured a 1/3 of a cup of very hot water in the tray and let it sit. After a few minutes I used the hair drier again and soaked up the water with a paper towel. I added another 1/3 cup of hot water. I noticed the ice in the drain hole was beginning to melt and used the wire again. Finally, I got my compressed air gun and blew out the hole. I wanted to just blow the water out of there but it must have shot the ice out into the evaporator tray. I poured more hot water in the tray and it disappeared immediately into the evaporator tray (checked the tray and could see water). I then blew out the hole with compressed air and dried the area with the hair drier. Plugged in the refrigerator, replaced the baskets and was done. Whole thing took 30-45 minutes. No idea why it clogged up in the first place but if it happens again I should be able to cut 10 minutes off the time.
Feb 01, 2010 | Kenmore Refrigerators
Aug 26, 2009 | Refrigerators
My Whirlpool top freezer refrigerator model ET8WTMXK007 keeps filling up with water in the crisper basket on the right side. Don't know how to fix it? It ends up being about 2 cups of water every 3 days...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 24, 2009 | Refrigerators
GE side by side refrigerator smells on the outside!
Mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section . Too much bleach and the smell of bleach would be circulated by the fan to the room , so be sure to add water .
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in bottom of refrigerator
there should be a tray that guides water from freezer to a drain located in the fridge section normally held with one screw . take it off and unclog drain ( use a vacuum to **** out sludge) clean tray/guide and mount back on. make sure all moisture is cleaned out after drain is cleared.
Jul 07, 2009 | Refrigerators
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
