The glass/plastic see through window on door popped out. and when trying to put back in the plastic screws/? boke off. It is on outside of door. it is clear circle and then gray outer circle goes inside it. There appears to be 6 places for screws or whatever and they have a silver clap that holds them in place. cannont seem to find part anywhere. any suggestions, besides buying a whole new door.
SOURCE: washing machine replacement door seal
It is held on by a spring that stretches around the outside of the seal. The seal simply hooks on to a small lip so all you need to do is start in one spot and push it down and away. Then just work it around like removing a bike tire until it is fully removed. Be careful of the spring. It is hooked together so it may unhook once some of the tension is removed and snap around.
SOURCE: PLASTIC WINDOW IN BOSCH WASHER
Hello Greyroom, sorry to be of bad news, however if this is the WFMC model washer, the only part for that window is the entire door assy. It isn't available as parts. Since there is a 2 year part warranty on the US product, you may explain your issue to customer support at the 800 number on the machine and they may help with the part.
SOURCE: Bosch Dryer WTMC3321
Hello Teambrant, the screws are a T-20 torx for the door and T-25 for the hinge. You can use the T-20 for both if you need to. Open the door all the way, remove the screws, then as you close the door it will come off. This kit will have all the parts needed for the kit. You will have to have the kit to reverse this door. The plastic retainers slide down, I use a pop sickle stick to push them down.
SOURCE: Bosch wfm3200 rubber gasket
You need to turn the seal back in on iteself at the front, then starting at the 12-o clock position, start feeding the spring round into the recess you will feel at the rear edge of the seal, it is a goove and that is where the spring fits.
As you progrees round with the spring you will find it harder and harder to get it to stay in the groove, this where you could do with some assistance.
You need to have some one hold the spring in place as you progreeively fit the spring.
You may find you will have to have more than attempt.
As a last resort, you can stretch the spring, which will make it easyier to fit., but do not stretch it too much, or it will not stay on.
Plz leave feed back for this solution.
SOURCE: outer door glass fell off and i can't find my
Ordering parts is very easy online...
Checkout this tip...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
