Question about Denon Audio Players & Recorders
Denon avr 800 protect error - Denon Audio Players & Recorders
Posted by Georgee Thomas on
5 Related Answers
Anonymous
SOURCE: when you turn on the avr 600 the display says "protect"
The Control IC broken
Posted on May 31, 2008
Anonymous
SOURCE: Denon avr-5600 protection circuit.
My AVR 5600 has worked flawlessly for nearly 9 years!
Suddenly, when trying to play music (DVD or CD) through my LS32's (JBLPro), once I achieve higher volume, the receiver cuts off.... Using a Symetrex mixer, NO OVERLOAD light on the Denon, it simply cuts off!
Re-cut all the wire connectors... TV movies (5.1) work great at normal listening volumes.... but tonight, when cranking up music, the receiver simply cut off. Blinking light...
HELP
[email protected]
Posted on Jul 26, 2008
Anonymous
  • 119 Answers
SOURCE: AVR-600
The problem is past that point once the protect continues to activate the amp is in need of service
Posted on Feb 26, 2009
Anonymous
  • 3 Answers
SOURCE: amp comes on and goes
Do you still have the AVR1500? I have one with a bad tuner--and would be interested in purchasing your for parts. Let me know if you still have it and if you'd be willing to sell it.
Posted on Apr 29, 2009
Anonymous
  • 458 Answers
SOURCE: I have a denon AVR-2000 that has gone into protect
power output short....or spk or spk wire short check and .need service...
Posted on Jan 07, 2010
I have a Denon AVR-1600 receiver and just installed a DirectTV receiver, RC66RX remote. How do I program the DirectTV remote to run my Denon receiver?
I don't think the codes are available online?
although if you call the directTV 1 800 # they can give you the program code, really hope this helps?
Feb 27, 2015 | Denon AVR-1601 Receiver
I need a manual for an avr 800
I'm glad to provide the manual for the Denon AVR 800 Receiver. Please click hear to download the same.
Please let me know if you require any additional help.
Jun 18, 2011 | Denon Audio Players & Recorders
What type of the remote control have avr-2400 and how i found this?
Hello. call 1-800 remotes
tell them your brand and model and they will ship you a denon remote for your avr. Joe
thanks for choosing Fixya!
Feb 10, 2011 | Denon AVR-2400 Receiver
How do you get a denon avr-2000 out of "protect" mode?
How diid i get a denin avr 2000 out off protect mode?
Sep 12, 2010 | Denon Audio Players & Recorders
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
Protection error in denon avr-3000
Do you know what caused the protection shut down in the first place? Did you short your speaker wires even briefly?
You could try to Unplug the Unit for Few Minutes, say 30 minutes and then turn it back ON.Usually that would fix the issue.
If you are going into protect mode with no speaker attached,chances are that your output Ic is in need of replacement .This is the most likely cause of a protection error that you are experiencing.I am having a bit of difficulty in locating specific part numbers but feel confident that replacing outputs will remedy your concern.For further info and parts or authorized service locations in your area I suggest to contact mfg at www.usa.denon.com/ .Click on support or call(201)762-6500.I believe that they have a flat rate service and will give you an estimate.
Still, on the remote possibility that it is just a glitch caused by momentary power interruption or fluctuation, try to re-initialize the microprocessor, a hard reset (not unless this is what you were referring to as rebooted). The reset should force the AVR-3300 to revert back to factory defaults removing glitches, errors in settings & configurations, memory & presets as well as user preferences.
* turn OFF the unit using the POWER button;
* press and hold both SPEAKER A and SPEAKER B;
* without releasing the 2 buttons, press the POWER button;
* release the 2 buttons only when the display starts to flash;
* in the event of no display flashing, repeat the process.
Should the above be not corrective, then it would be a hardware fault and not just a glitch.
Let me know, if needed further assistance.
Hoe i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 13, 2010 | Denon AVR-3300 Receiver
AVR-600
Feb 25, 2009 | Denon AVR-600 Receiver
Denon AVR-1100 receiver "PROTECT" mode
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Dec 25, 2008 | Denon AVR-1100 Receiver
What failed component causes protection error message to display right at power up.
well, i just got this thing from a friend. its a Denon AVR-800. when powered up it displays the stops, just before finishing a -protect- shows up. There's a little red light standby light that blinks off and on also. i think that has to do with the internal problem. any suggestions?
Apr 03, 2008 | Audio Players & Recorders
94 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
