Question about Master Lock 5400d: Portable Select Access Key Storage Lock
I got the master lock speed dial and forgot my combination
Well i just got the master lock soeed dial today. and i got it open then i put in my new combination that i wanted. and then i tryed it and now it won't open. and i even put in the other combination that came with it along with the combination i put in and it still wouldn't open. but i messed up when i had it on reset trying to put in my new combination and now i can't remember wat all i did. i just really need help. :| so do you think you can fix it. please...................................................? :]
Posted by karligro on
  • 2 more comments
  • drobles978
    drobles978 Feb 14, 2012
    idk wat to do i mest up my cambo i put so many crazy cambo and i forgot what i put there no way i cant remember the pattern wat to do is ther a wayh i can mail it to the company and fex it
  • cameronzohou
    cameronzohou Feb 06, 2013
    If you followed the instruction but forgot to squeezed the shackle after you moved the lug (in the back of the lock) to "R" position, you probabaly have now a new long code combined by the original plus your new code. Try it.
  • Carla Smalley
    Carla Smalley Aug 19, 2013
    Cameron, it worked! Thanks so much :)
  • bobt Aug 29, 2013
    cameron, thats what someone on yahoo said. don't copy
Harri_tran20
    New Friend:
Try your old password but push the shackle towards the lock once then put in your old password twice then pull the shackle
Posted on Oct 10, 2011
  • Harri_tran20 Oct 10, 2011
    Or try your new password but put it in twice
  • brotherfox1979
    brotherfox1979 Jan 06, 2017
    I tried this and it doesn't work for me
How do I can unlock dial lock
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock. 25284217-gdc3ufgmlwaqnv2deqjxyac2-5-0.jpg With the Combination Step 1 Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
With the Combination Step 2 Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
With the Combination Step 3 Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination Step 1 Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Forgotten Combination Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Forgotten Combination Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination Step 1 Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Resetting Your Combination Step 2 Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Resetting Your Combination Step 3 Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Resetting Your Combination Step 4 Roll the dials until you have your new combination.
Resetting Your Combination Step 5 Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links
Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals!
www.alibaba.com $0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now!
www.hostgator.com/1Penny Rooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now!
www.airconditionings.cn Download Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now!
www.facebook.com by Taboola
Sponsored Links
Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft Recipes See Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR
Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
  • Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
  • Do not open a lock that does not belong to you. It is against the law.
REFERENCES
RESOURCES
ABOUT THE AUTHOR Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
  • Creatas/Creatas/Getty images
Suggest an Article Correction
How to Open a Combination Lock on a Samsonite Suitcase
  • How to Reset the Combination on an American Tourister
  • Airline Rules on Locked Luggage
  • How to Reset a TSA Lock
  • Reagan Airport & Luggage Storage
  • How to Prevent Lost Luggage
  • Cost of Shipping Luggage Ahead to Destination
  • How to Repair Wheels on Luggage
  • The Odds of Losing Luggage
  • How to Make Inexpensive Luggage Tags
  • Solutions to Lost Luggage in Air Travel
  • How to Measure Luggage
  • How to Expedite Lost Luggage Claims
  • What Are the Dimensions of Hand Luggage for Air France?
  • What Rights Do I Have If My Luggage Is Lost?
  • How to Store Luggage While Traveling in Italy
  • pixel.gifHappy Camper: Test Your Outdoors Knowledge
  • pixel.gifCruisin' Along the PCH: Test Your Knowledge
  • pixel.gifWhich U.S. Landmark Would You Be?
  • pixel.gifCan You Pass for a Proper Brit?
  • Nov 15, 2014 | Lands Phones
    How to reset combination
    To set a new combination:
    The initial combination is set at the
    factory to 0-0-0-0
    1. Open the compartment door
    2. Push the reset lever left and down.
    The lever remains in this position
    3. Rotate dials to your desired combination
    4. Push the reset lever, up and right, back
    to the original position
    5. Close the key storage compartment door
    6. Scramble the combination dials to lock
    the door and conceal your combination
    7. Close the shutter door
    Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
    I lost the combination to my speed dial master lock and it is in the locked position. How do I open it and create a new code?
    It's not easy to fix this problem, because these locks do not shim open and it's not obvious how a person could figure out the old combo. I was able to loosen and remove the security screws, disassemble mine and repair it. They are very tricky to reassemble and it took me hours to find the spring that was out of position. The root problem was the lock did not clear when the shackle was pushed in. Until I figured that out, it would take up to 30 tries to get it open. The security screws are Metric - so you can replace them with regular screws until you get it working. If you do open the case, there are a lot of small parts inside, including a bunch of springs.
    Aug 18, 2014 | Master 1500ID Combination Padlock
    I got the master lock speed dial combination lock but forgot my combination and it won't open. can somebody please tell me if i can reset the password?
    1. Contact Masterlock.com and fill out the form, get it notarized and send it in for the combination to unlock it based on the S/N which is on the lock.(http://www.masterlock.com/faq/LostCombinations/). Good luck on this since Masterlock will end up finding something that will prevent them from giving you the combination. Its quite frustrating and NOT worth the trouble.
    2. Go to home depot. Buy a 24in bolt cutter ($22) cut the stem of the lock. and replace with a new lock that you can buy from home depot for $ 29.00. If you have a key that is inside the lock box that you really need, You will now need to drill out the combinations piece by piece and the door will pop open or send the lock back to Masterlock. They will retrieve the key for you and send it back.
    Aug 27, 2012 | Master Lock 5400d: Portable Select Access...
    I set a code in the master lock speed dial 1500id, and it will not open. I cannot reset the code and do not know how to get this open. I have read the other suggestions and nothing has worked yet. Anyone...
    Try 2 options:
    1. just squeeze the shackle twice and pull it out. This is in case you forgot to enter new combination.
    2, Make the 2 combination together, the old and the new as one sequence. This in case you forgot to squeeze the shackle before enter new combination
    Ity
    Sep 06, 2011 | Office Equipment & Supplies
    I messed up entering a new combo on my master lock speed dial thing, this is the second time I did this, how can I open my lock?
    If you did not clear the lock before entering new code, you probably have a long combination: the old and new together. Squeeze the shackle twice, enter both codes as one new code and open.
    Sep 18, 2010 | Office Equipment & Supplies
    Get the numbers master dial combination lock
    Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
    Please rate. Thanks
    Feb 21, 2009 | Hardware & Accessories
    I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
    Instructions:
    Opening the key storage
    compartment door
    1. Open shutter door to reveal the dials
    and the release button
    2. Rotate dials to the current combination
    (if the lock is new, the combination is set
    at the factory to 0-0-0-0)
    3. Press down on the release button
    to open the door
    4. Pull the door fully open
    5. Add or remove keys
    6. Close compartment door
    7. Scramble the combination dials to lock
    the door and conceal your combination (A)
    8. Close the shutter door (B)
    factory to 0-0-0-0
    (see instructions above)
    7. Close the shutter door (B)
    To hang shackle model
    2. Push the shackle release lever to the left
    to open shackle
    3. Pull the shackle up and out of the lock
    4. Place shackle around door knob or other object
    5. Close shackle to lock
    6. Close the compartment door
    Reminder:
    (A) The release button will open the lock
    until you scramble the dials
    (B) Keep the shutter door closed to increase
    weather resistance and to conceal the
    dials from view
    Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
    Master Lock 5400d: Portable Select Access Key Storage Lock Logo
    16,160 people viewed this question
    Top Master Lock Locks & Locksmithing Experts
    Marvin
    Marvin
    Lawrence Oravetz
    Kelley Hopper
    Are you a Master Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
