Can be seceral things but let me run by the simple ones first.
The MW does not have enough airflow that eill causer the sensor to switch it off. Briing it away from the wall a bit for air flow
The moisture from the defrost caused the sensor to cut in and switch it off. Unplug the MW and leave for a few hours ( tea will be delayed :0)
The Internal fuse blew. The outer cover has to be removed to replace the fuse ( unlug it first)
The fuse may be of the heavy duty ceramic type Do not substitute it)
The throw out to the MW plug went off in h/hold power box. reset it. Test point with another item.
Now those are the simple things you should check. first
The main one is the failure of the magnatron, but you would have lights and turntable activity, so... so far so good.
Please rate our help to keep the FREE service online++++Thank you for using FIXYA
