Question about Tylo Pool & Spa
My tylo 2018 deluxe 11 just stopped heating up today, I’ve only had it for 10 months
Posted by Kasey Lewis on
Wiring diagram for tylo ts30 single phase
Swell... Anonamous,
Take your "patience" issues to the
company (Tylo)
where they might be considered constructive...
It's just a 'TUDE here ...!!
(not helpful)
Control Panel TS (USA)
Carnac the Magnificent
Aug 23, 2014 | Tylo Deluxe 11kW Sauna Heater, w/ TS30-01...
Where is the safety shutoff on a Tylo super sport 7
On top of the unit/sauna, you will need to remove the roof or wood covering. It is held down with screws, usually. If your unit in fact does have a reset it will be located on the side of the control box which is located on top of the sauna.
Jan 15, 2013 | Tylo Super Sport 7 Sauna Heater
My tylo supersport 8 sauna no longer produces heat. The timer works but there is no heat. I have checked the circuit breaker but that doesn't appear to be the problem. Any thoughts??
Remove the unit bottom panel (2 small screws) and look at the quick disconnect terminals on the heater rods ( 6 heating rods - 3 on each side of the unit). If you have any corrosion on these terminals, the wires will overheat and fail, preventing the heating rods from working. If the wires did overheat, you should see melted wire insulation. Replace bad wire and quick disconnect terminals with new. Should cost less than $20.
Nov 23, 2010 | Tylo SUPER SPORT-U8 Sauna Heater 8 kW
My name is Andy Smith i am Electrical Engineer on
Hi Andy, I am Kelly and wish to at least make an attempt to help you out. I have done quite a bit of research and like you have come up with little nothing positive.
You may have to buy your own 3 phase 24DC controlled contactor and control that with a yet another relay.
At this point you may want to call Tylo direct or email them and explain your needs to see if they can help you.
Page 8 of their installtion manual shows several 3 Phase connections
http://superiorsaunas.com/storeimages/products/heaters/tylo/tylo_elec_install.pdf
Tylo contct info:
TYLö AB, Svarvaregatan 6, S-30250 Halmstad, Sweden.
Tel +46 35 10 00 80, Fax +46 35 102580. E-mail: [email protected] Internet: www.tylo.se
Here is the controller you may need with a 5 meter capillary tube. it does not say if it is 3 Phase and it is mecanical.
Seriously I would contact Typo directly via the contact info above and solve your problem quickly.
The link.... for the TS-30-012
http://www.saunahaus.com/Sauna-Control-Units/Sauna-control-TYLOe/TYLOe-Control-panel-TS-30-012::218.html
I do wish you the best.
Jan 26, 2010 | Tylo TS30-01 Control Panel
Heater only gets mild warm Tylo sport 4 heater
more than likley installation problem not enough voltage top operate heating element
Jan 23, 2010 | Tylo SPORT-U2 Sauna Heater 2 kW
Pool & Spa Logo
124 people viewed this question
Top Tylo Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Tylo Pool and Spa Expert? Answer questions, earn points and help others
