Question about Kenmore Dryers
Initial problem on kenmore elite dryer, elements would stay on until outlet fuse blew. New pcb fixed that but now getting F22 code. Ohms on the outlet thermistor read 10.3. Possible defective pcb?
Posted by Dave Vavrosky on
5 Related Answers
JR JR
Johnny Ramirez
  • 116 Answers
SOURCE: Kenmore He5 dryer, a service code f22
just remember error codes are always going to be stored on every machine ,, shoukd not have a problem ,, but does it work
Posted on Nov 30, 2008
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Kenmore 84152 /94152
probably the heater
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 15, 2009
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Kenmore Dryer Model 110
If all of the components are reading ok then you need a timer. Touch your 2 leads together. 0 ohms rght. That means you have a complete circuit.If you get the 0 reading then the element must be otay. Bad timer. Take that fancy meater of yours and atttach one of them leads to the timer leg marked RH. Yank the wire off the terminal beore you test. Move the timer around. You should get the famous 0 reading along the way. If you don't then that means you have the bad timer.
Posted on Feb 05, 2009
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: Dryer keeps blowing fuse
yes, after years of current going thru the fuse clips they get hi resistance connectiond and cant supply correct pwr to dryer and this results in blowing fuses especially the time delay fuse because this fuse supplies pwr to both the one side of heating element and the motor simutaneously -replace with a breaker sub panel if not enough room for a circuit in your main panel,that should solve your problem
Posted on Jul 26, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: kenmore elite elec dryer, 110.64972300. runs no heat
Pull one wire off the element and start the dryer in a heat cycle . Check power from that wire to the cabinet . Touch the meter to the terminal you pulled that wire off of , and check that voltage . You cannot get correct voltage by checking across the element . Trace the wire NOT getting 120 volts . It will either go to the timer or motor . It will lead you to the problem .
Posted on Apr 28, 2010
My HE2 front loader dryer flashes f22 and stops. A repair man has replaced the thermistor twice, but it is still flashing the same error.
This means the outlet thermistor, the one on the blower housing, is open. But since the thermistor has been replaced twice and the error code still flashes (make sure it is cleared after the replacement by pressing STOP twice), the wire harness (including the connectors) connecting it to the electronic control board is cut open or the electronic control board itself is faulty and not detecting the thermistor connected.
Check the connections and the continuity of the wire harness and replace or repair it if found cut open. Consider a faulty electronic control board if the wire harness and the connectors are intact and the thermistor is known to be 100% good. Normal thermistor resistance is around 8500 ohms to 13500 ohms at room temperature (27-21 degrees centigrade).
Mar 09, 2011 | Kenmore Elite HE4 Electric Dryer
DRYER DISPLAYS CODE F22. What does this mean?
"F22" is a door lock issue Press the "Stop" button twice to cancel the cycle if "F22" shows. Check that the washer door is firmly shut--open it and shut it and try again. Make sure there aren't items blocking the closing of the door. Don't overload the basket. Try the cycle again.
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Hi, I have a Kenmore Elite electric dryer model#
If your fuse is blown could be that your operating thermastat is not shuting off as soon as it should. Try replacing the fuse and the operating thermastat. The fuse would probaly blow before the hi limit.
Jul 16, 2010 | Kenmore 62802 Electric Dryer
Kenmore Elite will run, but won't heat
could be the thermal fuse or the heat element to start with.  also, check to make sure you have 220v at the outlet
Jul 08, 2010 | Kenmore Dryers
Kenmore Elite HE3 electric Dryer Heating coils do not get hot, drum turns, controls work. What can be problem
most probably the thermal fuse or the element itself.  make sure you have 220v at outlet.
Jun 24, 2010 | Kenmore Dryers
My Kenmore Elite dryer just quit heating up...is it the heating element or possibly a fuse? The lint trap had qite a bit of lint in it..maybe it just over heated and blew a fuse?
There is a thermal sensor attached to the housing of the heating element, you can check the thermal sensor by jumpering the two wires to the thermal sensor together, and then run the dryer and see if the heating element is now working, if the dryer is now heating up then replace the thermal sensor.
May 10, 2010 | Dryers
Kenmore elite elec dryer, 110.64972300. runs no heat
Apr 28, 2010 | Kenmore Elite HE4 Electric Dryer
Heating problem with kenmore elite he4 electric dryer. drum turns, lent trap clean, heating element ohms ok, thermo coupler ohms ok, thermostat ohms ok, timer counting down. still no heat.
limit switch stuck open should be behind motor housing is a tight fit to get to but there are two there on the element one on vent tube the other is thermal switch recommend chang the two on the tube ck element limits should all read continuityif not reolace
Jan 26, 2010 | Kenmore Elite HE4 Electric Dryer
Nov 29, 2008 | Kenmore Elite HE4 Electric Dryer
F22 code appears on Kenmore Elite Front Load washing-?
communication error between control board and panel. Make sure both are replaced together. common problem
May 27, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
136 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
