Question about Home
What is the best types of coffee beans packaging? Standing pouch, flat bottom or gusset types?
I build website addressed at https://kemasanpedia.net in Indonesia language. The main content of this website is about packaging - coffee packaging. I need your advise to provide the best tutorial of coffee packaging types. Thank you
Posted by Kemasan Pedia on
  • The Spaminator
    The Spaminator Oct 10, 2019
    Hi Kemasan Pedia, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    who is your target market ? Indonesians or further abroad like English speaking USA or Australia. A flash player video seems to me to be a common way a lot of web sites do tutorials or promote their services .
5 Related Answers
bunnydawg
Roberta Smith
  • 5158 Answers
SOURCE: NAVMAN S45 GPS SET UP
i doubt you can delete the safety agreement and to get back to metric should be settings in the main menu... for adding spaces look for a ___ thing on the keyboard...
Robert
Posted on Dec 17, 2008
Anonymous
SOURCE: DeLongi coffee mill #DCG-4TB
DeLonghi PARTS AND ACCESSORIES
1 (800) 865-6330.
8:30 a.m. – 5:00 p.m. (EST) Monday through Friday.
Posted on Feb 11, 2009
bansheracer
  • 1089 Answers
SOURCE: gaggia titanium coffee beans empty
Hi
If the big knob in the bean hopper is on a small #, that could be your problem. try opening the knob to the largest # and try again. If it clears and makes a cup, then on the next cup, while the grinder is operating turn the knob down again, but to a larger # than you had before. Grounds can get compacted in the chamber and prevent new grounds from entering. That is why it grinds but doesn't make a coffee. If that doesn't help, try opening the door above the brew unit funnel when the brew units is out. It should pull down on a hinge. This is the clicking you hear when you make a coffee.
Posted on Oct 20, 2009
bansheracer
  • 1089 Answers
SOURCE: The dregs drawer seems to have water in it.
Hi
That is a stripped thumbscrew. You need a new one. When it starts to brew, the stripped thumbscrew pushes up and allows the coffee to fill the head and dredge drawer.
The plastic rod that has 2 small hooks on the end and has ribs around the opposite end is your thumbscrew. It holds the filter screen in place. There is suppose to be a small round nut that is molded into the position between the legs with the hooks. If you use the key to tighten the thumbscrew you will pull the nut out and then the thumbscrew will pop out of the brew head. Check the stem of the filter screen. If you have an item that is about 3/8 of an inch long and has a grove in the middle and small bumps on it, that’s the nut. You need a new thumbscrew. Remove the old nut on the stem before putting it in the new thumbscrew. Remember it’s a thumbscrew, so it only needs to be finger tight. The key is for removing only.
Posted on Jul 06, 2010
Testimonial: "Thank you so much for your help, now will contact Saeco to find where I can buy a thumbscrew."
Anonymous
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
make sure you use very dry non-oily coffee beans
Posted on Jan 31, 2011
Coffee beans setting too small
* Brand and model needed for specific solutions.
* Check your warranty. Call for support
*** Following is for information only.***
* Bean grinders have a dial in front or a dial near the bottom of the been funnel (or bean bin.)
* Dials usually have size settings and may even be marked for the style of coffee to brew.
* Some of the smaller grinders have a dial around the collar of the bean container that have numbers or arrows pointing to coarse or fine grind. Some use a whole bean icon then smaller sand grind icon. Others may use numbers like 1-10 etc.
* For the super automatic coffee/espresso brewers they usually have a program enabled grind setting where a mini motor will adjust the grind for you depending on your coffee choice.
* The lesser "home" or office brewers may only have one setting and needs to be calibrated each time you change beans. (This is usually an adjustment knob or screw) Coffee needs to be brewed and tasted for each change of grind setting.
* Note that often changing the grind setting will also affect the ground coffee volume. (changing the size of dregs 'puck'). This also changes the flavor profile.
* Volume changes to brew needs to be done from the programing menu of the super automatic brewer.
* Espresso brews using a standard portafilter, it's critical to adjust the grind to the portafilter basket and dose water amount.
* Brewing in the coffee auto drip needs to have larger grind and more coffee to make up for the loss of flavor from large grinds.
* Smaller grinds intensifies the flavor but brings on bitter oils if ground too fine.
* Go slow and make taste tests each step of the way. Understand that it's a multi level balance between; Heat, Water volume, Flow rate, Pre-soak, coffee roast, coffee amount, besides just the size of the coffee grind.
* Calibrating for espresso; https://www.youtube.com/watch?v=FUeCLypvlNU
* Arrows and numbers; https://www.youtube.com/watch?v=n8dJpATLrjw
* Mazzer; https://www.youtube.com/watch?v=mN_To2nv1Fs
* Delongi; https://www.youtube.com/watch?v=WTYhZoncLBk
* Delongi(super); https://www.youtube.com/watch?v=OUSXo0xaHIM
* 890TS (also Bunn); https://www.youtube.com/watch?v=QF-kiFymTQM
* Size to brew; https://www.youtube.com/watch?v=5BCDIas33y0
* Electronic dosers; https://www.youtube.com/watch?v=xMadMBgMcA4
* Hand grinder; https://www.youtube.com/watch?v=zyCHdG25JFU
* Ceado; https://www.youtube.com/watch?v=iwHdm5GtNHI
* Modern hand grinder; https://www.youtube.com/watch?v=oH2s6rQ43us
* Saeco; https://www.youtube.com/watch?v=C7nK9nsFNkQ
* Breville; https://www.youtube.com/watch?v=1lGFJoI77T4
* Gaggia; https://www.youtube.com/watch?v=5U3o9jMvI3g
* Call your vendor for additional advice.
Aloha, ukeboy57
Aug 19, 2018 | Coffee Makers & Espresso Machines
When I brew a pot of coffee all of the grounds do not get wet Why?
Hello, Vicky -
It will help in answering your question to know the make and model of your coffee maker. You can choose Comment and add that information in the Comment box.
As a general answer, there could be 2 reasons for all of the coffee grounds not to be wet:
* You may be using a dark roasted coffee, which has a high amount of surface oils , making it difficult for the water to wet all the ground coffee beans during the brewing process. If so, you may need to follow the "hot bloom" method when setting your coffee maker up to brew. Watch the video here:
https://www.bruer.co/blogs/news/113462276-the-hot-bloom-method-eliminating-dry-coffee-grounds
* The spout for the water to dispense in your model of coffee maker may have become positioned off-center
Along with only partially wet coffee grounds does the brew seem weak?
I assume you have already checked the user manual for your coffee machine to find if the partially dry coffee grounds issue is addressed in the Troubleshooting section. You may wish to visit the website of the manufacturer of your coffee machine to find if the problem is covered in FAQs or Troubleshooting for your model of machine.
Best wishes.
Feb 15, 2018 | Coffee Makers & Espresso Machines
My Gaggia Unica won't grind the coffee beans, it just whirs and stops making the drink
More than likely the machine is stuffed with coffee grind. Need to take it apart and clean it. See https://www.youtube.com/watch?v=JQbP2v8C-sA
Sep 20, 2014 | Gaggia Unica Bean To Cup Coffee Machine
Which one is better a coffee bean or ground coffee?
if coffee is prepared with fresh grinder bean then it gives ultimate taste to coofee with perfect aroma. Some top-range bean to cup models have integrated bean grinders to do this for you, or you can buy a separate grinder. If you grind beans yourself, you'll need to choose the extra-fine setting for espresso brewing and make sure you thoroughly clean and maintain your filters, to prevent them getting blocked. Get Complete info about the best coffee best coffee grinder here.
Sep 04, 2014 | Nesco Cr-1010-prr Coffee Bean Roaster, 800...
What is instant coffee?
Instant coffee is basically ground coffee that has been freeze-dried, packaged and sold. It is rehydrated by pouring hot water over top. This type of coffee is ideal for travelers or to anyone without a coffee pot/time to wait for their coffee to brew.
Feb 07, 2013 | Coffee Makers & Espresso Machines
I have a puddle of water that is leaving out of the coffee maker from the bottom. (underneath)
Here's what I discovered about my Keurig B60: The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Aug 28, 2011 | Keurig B60 Coffee Maker
Hi. I have a miele cva4060. The grinder is working but it does not seem to be getting any beans through it and I am only getting water dispensed instead of a coffee shot! It was working fine a few days...
Hi
If you hear its 'grinding' then that's good - problem is where is the ground coffee going or supposed to go??
Check there is no build up of damp/dried coffee grinds in the pathway between grinder and brew unit - this can happen if the machine is not properly cleaned say every 3 mths or more often depending on usage - coffee 'dust' can build up.
Also suggest remove all beans from grinder, vacumn last ones out. clean all around grinder opening. Add a dozen or so beans to the grinder, turn on and try again. If the beans disappear, its grinding properly. If they don't end up in the brew unit, then the hold up is as I said in that pathway - grinder to brew unit. If you cant see an obvious blockage/build up, suggest you have a tech look at it.
Cheers
Mike
Dec 10, 2017 | Miele Coffee System
How many tablespoons of ground coffee are needed per cup of water in the Smart Brew coffee maker?
For ground coffee, use 1-1/2 (one and one-half) tablespoons of beans per 6 ounces of water.
For whole bean coffee, use two tablespoons of beans per 6 ounces of water.
Coffee strength is a very personal preference, so use these numbers as a guideline for middle-of-the-road coffee, and adjust to make the coffee that you like to drink.
Sep 30, 2010 | Black & Decker DLX900 12-Cup Coffee Maker
Home Logo
129 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
