What sort of a preamp are u using this needs to be plugged into the lo impedance XLR input (this is a lo output dynamic mic 1.85Mv out)
The XLR should be input pin 2 return (gnd) pin 3.This mic does not NOT use phantom power (48v) if it is a dual input (pin 1 48v) source make sure the phantom power is turned of.
If this is being done then there maybe a problem with the mic.
You can check this by plugging a source in to the input to check that it is working line out from cd player midi or some other source.
biinary 6
