Question about PfaFF Sewing Machines
I want to run a bobbin on my Pfaff 360 sewing machine. I can't get the stop motion know to loosen. Help!
Posted by Paula Wagner on
5 Related Answers
Anonymous
SOURCE: Pfaff sewing machine 463
how do you thread a Pfaff sewing machine
Posted on Jun 15, 2008
Anonymous
  • 323 Answers
SOURCE: My pfaff synchromatic 1209 machine--the
You machine has a screw that fits the end of the shaft and the head pof the screw has broken. You can buy a new screw from a sewing machine dealer but if the whole assembly has come off you may need to take it to a dealer to have it reassembled properly. There is a spring inside which is very difficult to install.
sewman7
Posted on Aug 22, 2008
Anonymous
  • 6 Answers
SOURCE: timing my pfaff 332 sewing machine
There are two parts to the sew hook on that machine. The outer part has the hook point that grabs the thread off the needle. Then there is an inner part which has a post in the center of it that the bobbin case fits on to. The inner part should be held in place with an arm that has a bump on it. It keeps the inner part from spinning around. Sometimes this arm slips loose and a notch in the inner part of the hook assembly slips out from under the knob on the arm. If this is what is happening, you need to loosen the screw holding the arm in place and reposition the notch of the inner part of the hook back under the bump on the arm. There needs to be clearance between the notch and the bump for the thread to pass between the two. And the bump should be in line with the needle when it is in its lowest position.
If this doesn't solve the problem you need to take the machine in for repair.
Wayne
Posted on Mar 12, 2009
1mrchris
Christopher O'Clair
  • 15 Answers
SOURCE: Anna had this problem with her Pfaff 332 sewing machine, I do too
I believe that the bobbin case holder has become unlatched, for lack of better terminology. I have one of these machines, and my first experience with one was exactly as you are describing. A friends grandmother brought it to me because it kept breaking needles and wouldn't complete a stitch.Put the bed table in the lowered position, leaving the free arm exposed. Remove your needle, presser foot, and bobbin case, leaving the bobbin door open. Next remove the two screws that hold in the feed plate, and remove the feed plate. Looking down into the bobbin area, manually turn the bobbin case holder. There is a small slot in the top of the bobbin case holder, look for it as you turn. A small latch protruding from the bed plate is supposed to be clipped into that slot, and if the latch is still there, you likely will not be able to rotate the holder into place: This is good news, it means nothing is broken. Loosen the three screws (two silver on the top of the bed plate and one black in the area where the feed plate goes) which hold the bed plate in place, but do not remove them. You should be able to lift the bed enough to get the holder into place, and then set the bed back down and tighten the screws. Reassemble everything, throw in a new needle and see how it goes!
Posted on Mar 24, 2009
paj42
  • 1116 Answers
SOURCE: thread balls up in the bobbin/singer sewing machine, also thread
The balance stitch control on this model is below the stitch patterns; to the far right.
If you need a manual you can download a free one at the Singer Company website.
Posted on Mar 13, 2010
PFAFF 1467 I WAS SEWING ON SOME VELCRO AND MY MACHINE STOPPED WORKING. It turns on and lights work but the needle and hand wheel feel jammed and won't move.
Was it velcro with adhesive? The adhesive has gummed up the needle.
Raise the presser foot, loosen the needle, and see if you can remove the bobbin from the machine. Once you get the bobbin loose, then most everything else can be clipped.
Sep 04, 2018 | PfaFF Sewing Machines
How to thread bobbin 451 Pfaff
Having difficulty even locating a photo of the 451. Assuming this is an older model, perhaps this manual will help. It says its also for the 551, so perhaps the model is close enough that it will help you with your machine:
Pfaff 551 Manual pages 1 viewing
If you are unable to figure out the bobbin winder, you may be able to use a standalone bobbin winder (one brand is called Sidewinder) from the fabric store. They run ~$25-30. Just be sure to bring a bobbin with you to check the fit.
vintage sewing machine bobbin winding Google Search
How to Wind Bobbin and Thread Bobbin Case for Vintage Singer Featherweight...
Jul 14, 2016 | PfaFF Sewing Machines
Release stop motion knob won't move
What are you calling a stop motion knob? Are you trying to stop the needle from moving while winding a bobbin?
Jan 31, 2014 | White Sewing White 3032
When I set the machine up for free motion sewing the bobbin thread snarls
try changing the needle- Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
check to make sure the bobbin is wound correctly & inserted into the bobbin corectly
clean under the needle plate area & in the bobbin area for lint or loose threads
if these suggestion don't help then it would be a good idea to
take the machine in for a check up
Jun 02, 2012 | PfaFF Sewing Machines
I have inherited a Necchi 537FA. When I wind a bobbin I loosen the stop motion wheel, but the sewing mecfhanism doesn't disconnect, it still "sews" through the entire bobbin winding procedure! ...
Its been idle for too long and needs a good service. Try and trickle some oil behind the stop motion wheel. But what it actually needs is to have the wheel removed and then apply oil to the shaft. Careful when you start again as oil will fly out from the wheel so mind your drapes and wall decor.
Dec 12, 2010 | Necchi 3537 Mechanical Sewing Machine
Automatic bobbin winder does not stop when bobbin is full
Simply loosen the screw on the bobbin winder stop, no more than 1 full turn or you will drop the backing nut will fall down into your machine, move the bobbin winder stop slightly to the left then tighten the screw and see if that works. you may have to repeat this step several times until you find the right spot to stop the bobbin at the correct point.
Jun 27, 2009 | PfaFF Creative 7570
Brother sewing machine
I have only a cheap one (VX-1100), but when this is happening on mine, the stop-motion knob isn't fully engaged with the balance wheel. They are held together by one being tightened to the other for sewing, loosened for bobbin winding. Michael
Aug 31, 2008 | Sewing Machines
My pfaff synchromatic 1209 machine--the stop motion know keeps falling off. I have reassembled it but it will not wind a bobbin and only sews for a little while. Does it have a spring in there? I was...
sewman7
Aug 19, 2008 | PfaFF Hobby 4260
I'm trying to do shirring?
My machines has a shirring foot, so I don;t have the same machine. However, I do not think that elastic thread will work in the bobbin. Have you tried it the other way around? Do you have your manual?
Aug 07, 2008 | Sewing Machines
Sewing Machines Logo
95 people viewed this question
Top PfaFF Sewing Machines Experts
Irene Tulloch
Asmodius
Level 1 Expert
Chris Wetmore
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
