Question about Home
How can I replace the jets on my Acer Swirlbath?
Posted by Nita Nigam on
3 Related Answers
snowghost1
chris wheeler
  • 784 Answers
SOURCE: The jets on my aker
could be a few things ---
1. it could be the on/off switch.
2. it could be a loose wire.
3. it could be a bad motor.
4. it could be a blown fuse or a bad breaker at the panel.
c...
Posted on Dec 31, 2010
christine93467
SOURCE: My Acer Swirlbath has a
I had the same problem and I was told to fill bath with hot water and add a bottle of vinegar and allow it to run for 10 mins.
Then empty and redo it with a a fragment oil in hot water and then empty.
It worked for me.
Posted on Jul 21, 2011
Tom Chichester
  • 55976 Answers
SOURCE: Anybody know where to find a replacement electric on/off switch for Aker Swirlbath jetted tub/shower.
Fixya is unable to suggest sources.
Posted on Apr 06, 2018
I want to make my swirlbath a soaker. Where can I find plugs for the jets?
You may not be able to find those but you can get some corks from like a wine bottle and shave to slightly larger on one side like they are made already and push them in tight which works well
Sep 24, 2017 | Home
I have an AKER Swirlbath by Delta and (2) of the jets do not work how or whom can I get to repair/fix the problems
try forcing water down the other jets one at a time to see if this clears the blockage, use a hose or shower hose
Nov 12, 2014 | Baby Gear
The jets on my aker Swirlbath are coming on by themselves in the middle of the night. What is the remedy for this problem?
Some tubs with air jets have a sensor that detects water in the piping and cycles the air pump to blow out the water in the air jets. Make sure the faucet is not dripping as the water leaking into the tub could be causing the pump cycling problem.
Hope this helps.
Bob
Aug 11, 2014 | Home
I want to set up my acer chromebook so i can use my HP Desk jet 4480
your acer chrome book supports only USB 3.0 but this printer accepts only USB 2.0 so need to download hp printer scanner software and install it and the see what it append after run this software almost resolve your issue....
Apr 20, 2014 | HP DeskJet Office Equipment & Supplies
Aker swirlbath manual
Any manuals for the Aker by Maax bathtubs will be available directly from Maax, who makes the Aker brand bathtubs.
Feb 22, 2014 | Home
Need to find out why 2 of the 6 jets on my acer swirl bath tub don't push water out like the other 4, and where can I find replacement jets. We bought the home recently and it was built in 2000. so...
see if the jet faces turn at all. Sometimes the jets are adjustable to allow more pressure from some jets.
turn the face of the jet and see what happens.
Aug 16, 2011 | Home
My Acer Swirlbath has a mildew smell. It is clean but I'm assuming it is coming from the jets and intake. How do I safely clean out the jets?
It worked for me.
Jul 21, 2011 | Home
The jets on my aker swirlbath tub do not work. what do you think the problem is?
c...
Dec 31, 2010 | Home
Home Logo
129 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
