Question about Health & Beauty
Permobil C 400 joystick showing JSM Module error and code 8111 how to correct?
Posted by Mr Balbhim Sankpal on
My daughters wheelchair which is a permobil c400 will not switch back to drive mode out of the seat adjusting mode?
That mode button is defective replace it or the entire control stick is more likely what needs to be done.
Feb 23, 2017 | Drive Health & Beauty
I have quantum pride 610 chair when l power on it show me an error . The errorcode#36 release joystick .please l want some help
i think you will have to ring your support team and carers asap
get someone to test the power control module under the seat or the joystick controller
the batteries must be charged to get the error message
this the quantum pride 610 user manuals
http://www.pridemobility.com.au/default/assets/pdf/Owners_Manuals/US_Q610_Aug13.pdf
Apr 30, 2016 | Pride Health & Beauty
How do I check power module and joystick module connections and wiring on my wheelchair?
hi Kathy, sadly there isn't a easy way to do this and you really need someone skilled in working with the powerchairs. This can be a joystick fault however make sure all connections are a tight fit ...
If you're based in the UK please give me a ring as I carry out free testing ...
Regards
Rob.
Feb 16, 2016 | Pride Jazzy Select Elite
Permobil C 300 joystick showing joystick error and code 0E00 how to correct?
0E00 Joystick Error Joystick Error Right System fault Joystick Error
that is the info from permobil documents, it may be an error of the right motor / wiring "check all connections, unplug and plug in again all connectors, if still persists then it would seem to be an error with the controller its self, this maybe the pcb or the joystick its self, some times if you give the joystick a good workout (moving it to its limits over and over again for a couple of mins and then turn on and see if error clears) if that fails then it looks like a new joystick or the whole controller might need replacing, if you know some one with the same controller on there chair see if they will let you plug it in to your chair just to confirm it is that.
hope that helps, and if so please click "Helpful" to let others know
have a great xmas all
Dec 01, 2014 | Health & Beauty
Com fault codes
This flash error code of 9 indicates a communication fault. With this model the problem is usually the connecting cable between the joystick and the computer module in the base. Check the connectors and wiring and cover on this cable for loose,broken , or disconnected terminals and wires. I usually replace the cable with a known good one to test. The second component that may have failed is the joystick assembly. A local dealer may be able to lend you these parts to test or you can purchase them on-line. There are several different models and joysticks that are similar looking but have subtle differences. If you post your joystick model I can be more specific.
Hope this helps.
Apr 04, 2014 | Invacare Pronto M51 Power Wheelchair
Battery on permobil will not charge
First off, a Permobil C500 is not a PC laptop. Next time, please put this in the correct category.
Try charging up the battery/batteries with a auto car charger. Make sure the voltage is set correctly, and charge it on slow or low, 2Amps. Leave it on there for about 4 hours and see if the chair will run and for how long.
This should tell you if its the batteries or charger that's bad.
Sep 25, 2012 | Computers & Internet
I have a Pride Jazzy 615HD electric wheelchair. When I turn it on, ,it will not move. The bottom flashes 8 times in a row. The speed lights go from red to green, one at a time, as well. The thing is...
Eight, pause, eight Power Module Fault - Check connections to the power module and batteries. The power module is located near the front of the chair under the base cover you will have to unplug the joystick then remove the seat and the cover. The wiring for your motors, batteries and joystick all plug into the power module. Check each connection to make sure they are in good and solid if you can pull it out easily then the wire was not in there locked push in each connector to make sure they are seated in the module. now you can plug the joystick back into the cable coming from the module without replacing the cover and seat. Turn on the joystick to check if you are still getting the error if you are then the power module will have to be replaced If the error is gone then unplug the joystick replace the cover and seat plug the joystick back in and power up then go for a ride Hope this helps
Apr 16, 2011 | Pride Health & Beauty
I have invacare pronto m51 with surestep the spjis flashing 9 times what is the problem
The 9 flash error code indicates a communications fault. The communication fault relates to the communication between the joystick and the control module. The joystick on the arm mount is connected to the control module in the base. When there is a break in the wiring of this wiring harness, also called a bus cable, a fault occurs. This trips the computer and the computer sends out a flash code to the joystick. Simply stated there is a broken or pinched wire between the joystick and controller. Look physically at the wire and check for cuts, breaks or pinches. The best short term repair is to repair the broken wire with solder and heat shrink or tape. You can also use **** splice connectors and tape. The best long term repair is to replace the harness with a part available from Invacare. The most definitive way to diagnose this problem is to read the fault log of the controller using a hand held programmer available to dealers and certified technicians. The number and type of fault codes logged in the controller is another indicator of which
component(s) has failed. Hope this helps.
Nov 19, 2010 | Invacare Pronto M51 Power Wheelchair
PSP joystick won´t work
It should work fine without it. Make sure you keep that little clear rubber part safe. It's what fills the gap between the analog stick and the motherboard on the PSP
Jun 16, 2009 | Sony PSP (Piano Black)
Health & Beauty Logo
261 people viewed this question
Top Health & Beauty Experts
ray gallant
ADMIN Canada
ADMIN Canada
Bill Boyd
Are you a Health and Beauty Expert? Answer questions, earn points and help others
