This isn't any help. Do you not have an 800 # that I can call?
Posted by Susan McCallum on
My psp keeps turning off
Assuming the power cord/charger is working and that the battery isn't dying. Contact someone at customer service at the number below...
Phone: 800-345-7669
How to reach a live person:
Just press 0
Hours of Operation:
Monday - Saturday 6am-8pm PT
Sunday 7am-6:30pm PT
Jun 24, 2012 | Sony Video Game Consoles & Games
My garmin 205 nuvi screen shows up as though it is shattered when you turn it on. The outside screen isn't damaged but the internal lcd part of the screen is can this be fixed?
Yes it can be fixed. Garmin charges $69 flat rate fee to fix this unit and they will update it while they have it. Contact garmin customer service at 1-800-800-1012 to set up an RMA to get your device repaired.
Sep 24, 2011 | Garmin nuvi 205 GPS Receiver
My screen is very dim. I turned brightness as high as it will go, but still dim.
Part of your LCD is not lighting up. This tends to happen as the nuvi 200 series units age. Garmin can repair this at $69 flat rate. In my opinion it isn't worth it because you can go out and buy a newer better model for that price. But if you want it repaired give garmin a call at 800-800-1012.
It turns on only when I remove and insert the batteries. Now appears Line 1111 Emulator. Does this calc have salvation?
That sounds pretty bad.... you can try to take out all batteries, including the back up, leave it sit for a minute or so. If that doesn't fix your problem you can try calling TI-cares (800-842-2737), they may be able to help. I hope it isn't lost
Aug 02, 2011 | Texas Instruments TI-89 Calculator
I have a Bissell ProHeat Turbo 2x, it isn't mixing the water & cleaning solution and isn't spraying. What do I do?
Isn't Spraying:
Possible Problems->Solutions
-Water Tank may be empty-> Fill Heavy duty bladder with hot tap water.
-Formula Tank might be empty-> Fill with Bissell fiber cleansing formula for cleaning.
-Tanks may not be seated completely-> Turn power off and reset the tanks.
-Pump may have lost prime-> Turn power off, then on again, wait one minute then depress the trigger
You can also contact Bissell at: 1-800-237-7691 begin_of_the_skype_highlighting 1-800-237-7691 end_of_the_skype_highlightingto help you out on why the cleaning solution and water aren't mixing, but first try fixing the first problem, you never know, it might cure the first one. :)
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Bissell Vacuums
When I press the buton on/of ,I see the message SERVICE REQUIRED CALL 800-9357763 and than when I press the buton - at CH.4 I see the message RETRYS EXCEEDED CALL 800-9357763 can you help me with this...
The best advice that anyone can offered to you, is to do what the error message tells you to do. Follow the instructions and call the number. It's the Customer Care Dept of RS Medical, the manufacturer of your product, which oddly enough isn't a Blood Pressure Monitor. Since it's a toll free number, it won't cost you anything.
Apr 15, 2011 | Health & Beauty
Computers & Internet Logo
27 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
