SOURCE: 2001 Chevy Impala Security System
I have a 2001 Impala. My security light will flash and sometimes the car won't start. My dad told me turn the key to the start position, place your foot on the break, put your car in the last gear it was in (D, R, or N). Then shift all the way back into park. Make sure you shift all the way into park. Take your foot off the break. Then turn ignition back to off. Your car should then start right up. He said the sensor still thinks the car is in D, R, or N although it's in park. So it confuses the system and it doesn't start because it doesn't know which function to do. It pretty much locks up. I'm pos. this will work. My car does it every few months. Hope this helps.
SOURCE: 1997 chevy s10 blazerdash wont light up when key
the dash sound's like a fuse, check the fuse box under the hood and in the door jamb on the side of the dash, also check your fuel filter and fuel pump, im betting on the pump because i have a 2001 chevy blazer that has had two replaced and it has 233000km on it!
SOURCE: I have a 2001 Olds
you can not bypass the security in that car, it is built into the main computer, they have problems with the ignition switch screwing up and the only way to start it while the light flashes is to turn the key to ON but don't crank engine, leave on for 10 to 15 minutes until light goes out then start car.
First thing you need to get the trouble code out of the computer.
