How to fix dism error 87 windows 7 ? - Computers & Internet
Posted by GeorgeMartin1408 on
How do I Fix Windows Update Error 0x800F081F?
.NET Framework 3.5 installation error: 0x800F0906, 0x800F081F, 0x800F0907 Error code 0x800F0906
Error code 0x800F081F
Error code 0x800F0907 Resolution for Windows 10 0" style="box-sizing: border-box; outline: none;"> Error code 0x800F0906, 0x800F081F, or 0x800F0907
Error code 0x800F0922 More Information 0" style="box-sizing: border-box; outline: none;"> These errors may occur when you use an installation wizard, the Deployment Image Servicing and Management (DISM) tool, or Windows PowerShell commands to enable the .NET Framework 3.5.
In Windows 10, Windows 8.1, Windows 8, Windows Server 2012 R2, and Windows Server 2012, the .Net Framework 3.5 is a Feature on Demand. The metadata for Features on Demand is included. However, the binaries and other files associated with the feature are not included. When you enable a feature, Windows tries to contact Windows Update to download the missing information to install the feature. The network configuration and how computers are configured to install updates in the environment can affect this process. Therefore, you may encounter errors when you first install these features.
Error messages that are associated with these error codes
Error code Error messages 0x800F0906 The source files could not be downloaded.
Use the "source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see http://go.microsoft.com/fwlink/?LinkId=243077.
The DISM log file can be found at C:\Windows\Logs\DISM\dism.log
Windows couldn't complete the requested changes.
Windows couldn't connect to the Internet to download necessary files. Make sure that you're connected to the Internet, and click "Retry" to try again.
Installation of one or more roles, role services, or features failed.
The source files could not be found. Try installing the roles, role services, or features again in a new Add Roles and Features Wizard session, and on the Confirmation page of the wizard, click "Specify an alternate source path" to specify a valid location of the source files that are required for the installation. The location must be accessible by the computer account of the destination server.
0x800F0906 - CBS_E_DOWNLOAD_FAILURE
Error code: 0x800F0906
Error: 0x800f0906 0x800F081F The source files could not be found.
Use the "Source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see http://go.microsoft.com/fwlink/?LinkId=243077.
0x800F081F - CBS_E_SOURCE_MISSING
Error code: 0x800F081F
Error: 0x800F081F 0x800F0907 DISM failed. No operation was performed.
For more information, review the log file.
Because of network policy settings, Windows couldn't connect to the Internet to download files that are required to complete the requested changes. Contact your network administrator for more information.
0x800F0907 - CBS_E_GROUPPOLICY_DISALLOWED
Error code: 0x800F0907
Error: 0x800F0907
How to download the .NET Framework 3.5 outside of the Windows Update requirement
The .NET Framework 3.5 is available for customers with Volume Licensing or MSDN Subscription, as Feature on Demand Media is available.
Error codes are not listed when you install .NET Framework 3.5
When you install .NET Framework 3.5, you may encounter other error codes that are not listed in this KB, for more information, go to the following articles:
Dec 27, 2017 | Computers & Internet
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Feb 21, 2013 | Computers & Internet
Toshiba laptop frozen pointer mouse
  • If you're having problems with Windows Update, make sure you're connected to the Internet, and then download and run the Windows Update Troubleshooter for your version of Windows.
  • Download troubleshooter for Windows 10
  • Download troubleshooter for Windows 7 and Windows 8
  • After the troubleshooter finishes, try running Windows Update again and install any available updates.
  • Or,
  • https://support.microsoft.com/en-us/help/947821/fix-windows-update-errors-by-using-the-dism-or-system-update-readiness-tool
  • Mar 15, 2017 | Computers & Internet
    Cant install windows 7? i put the cd in and go to auto boot but it gives me a code 5 error.
    To resolve Windows 7 Error Code 5, all you need to do is start the installer through a different installer. Either find an old Windows XP boot disk and then direct it over to the Windows 7 installation DVD and run Setup.exe. This should kick off the installer normally and allow you to install the operating system.
    Jan 10, 2010 | Asrock K7VM3 Motherboard
    System Error. Code : 87. Parameter is Incorrect.". Please give me solution for this
    When I want to connect a software ,which connect to Database through ODBC display the messageV"System Error. Code : 87. Parameter is Incorrect.". Please advice solution
    Mar 29, 2008 | Microsoft Windows 98 for PC
    Http 400 bad request
    Unable to fix Gmail Bad Request error 400 in Google chrome, visit our website to find easy to implement steps through which you can fix Gmail Bad Request error 400 very easily.
    Jan 24, 2008 | Sony SNC-RZ30N Network Camera
    System Code Error 87
    Sounds like the application you are running may not be compatible with Windows 98. Probably can't do much as Windows 98 is so old.
    Although it may be a missing file, DLL, or driver on your Windows 98 system, hard to tell.
    Jan 11, 2008 | Microsoft Windows 98 for PC
    Computers & Internet Logo
    Muntejaya Ginting
    Muntejaya Ginting
    Marvin
    Marvin
