Question about Retail Supplies
How do I customise a Z1 report? - Retail Supplies
Posted by Stephen Blanch on
Sharp Xe 203 cash register is printing all 99 departments when doing a z1 reset at end of day, we only have 16 department, how do we print only the dept we use
Firstly, make sure there is a Z or Z1 at the top of the report. If it is X or X1, you are not resetting and that's your problem.
The register is set by default to ignore all zero balance PLUs and depts so someone may have turned printing of all depts on Z reports. Check your programming manual for a setting which details depts with zero printing or all printing in Z reports. It will normally be in the printing settings but it can vary between models.
Aug 13, 2018 | Retail Supplies
GELLAR SX-680. What do I do to re print yesterday's end of day cash/transactions report - Z1 ? Can I find the report on the roll that stays in the till?
Yes. The reports will print on the receipt and journal paper so you have two copies. Once printed, a Z report will clear so you will have to check the printout for the last report.
Mar 28, 2018 | Retail Supplies
How do i get product report te2400
Hi Cahla. Turn the key to Z1 mode then type 14 CASH. This will print a PLU report. Remember, the first one will have huge figures if you haven't used this report before. The figures will reset after print so the next report will be correct.
For those who asked about a Casio TE-2400 programming manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
May 07, 2014 | Casio Parts Cash Register PC Desktop
Z 2 key will not give nights end readout
It depends upon the programming of the reports section, but the Z2 mode is usually reserved for periodic reports such as monthly. Z1 is for daily reports
Apr 01, 2012 | Casio Parts Cash Register PC Desktop
Reprint x1/z1 on EX-A22H
if you have printed a Z report, it has already been cleared. You may be able to get it from the electronic journal though.Try this:
Turn key to X1/Z1 mode.Make sure you have lots of paper left on your roll. If you are not sure, place a fresh roll in the machine since you don't want to run out during this print.Type 700 @/FOR CASH.On euro models, it is 700 X TL or 700 X CASH.This will print the journal which contains all of the last few thousand lines and reports.Good luck.
If anyone needs a manual for a Sharp XE-A22, try here:http://the-checkout-tech.com/manuals/cashregisters/Sharp11.php
Oct 15, 2011 | Casio Parts Cash Register PC Desktop
HOw do I print out a daily, only, report of sales.. not the total monthly sales.
It depends which brand and model. Most have a Z1 and Z2 position. If you want a daily, turn to Z or Z1, not Z2. If you want more info, let me know the brand and model
Nov 12, 2009 | Casio Parts Cash Register PC Desktop
I can't print the end of day reports.The screen is just blank when key is in z1 position
This is usually caused by a dirty or damaged mode lock. Take the key out and squirt a small amount of de-watering fluid such as DW-40 or CRC down it, then turn the key a few times and see if the display comes back in Z1 again. If not, you probably need a new mode lock.
Mark
Aug 17, 2009 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
159 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Marvin
Marvin
Are you a Retail Supply Expert? Answer questions, earn points and help others
