Question about Furuno Boating
Have lost all wayponts on my GP31 Navigator, is there some way of retrieving them?
Furuno
Posted by Dave McGinlay on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: Furuno GP31 - PC wiring instructions
try
http://furuno.inforce.dk/graphics/14_Softwares/09_gps/FURUNO_GP-32_pc_connect.pdf
Posted on Aug 28, 2008
Anonymous
  • 34 Answers
SOURCE: can we connct furuno gp31 to pc
Hello!
Yes, the GP31 can connect to a PC.  With the wiring harness, it has an RS-232 port, which allows it to connect to most PCs, laptops, and even most palmtop systems.
Hope this helps you out,
Ken
Posted on Jan 07, 2009
Anonymous
SOURCE: LCD furuno GP31
Even Im facing the same problem, when I gave it for repairs, they says that the screen is moulded with Body, hence it cannot be repaired.
Posted on Sep 22, 2009
TechnoMarine
John Barry
  • 132 Answers
SOURCE: radar install problem
the GP31 has an NMEA in/out in the power cord - out is yellow green in blue(or black) and white on the 1833 you will use data 4 typically which has an in and out also, same colors hook out to in and in to out, program and done
Posted on Jan 16, 2010
Anonymous
  • 111 Answers
SOURCE: What do I do to download my GPS Furuno GP31 to my
Go to www.furunousa.com and download the installation manual
Posted on Jan 22, 2010
How do I can change language on furuno gp31 from German to English ?
The GP31 manual doesn't mention language change
Furuno GP 31 Operator Manual
whereas the GP33 does
Furuno GP 33 User Manual Language Setting Input output Data
Try doing a Factory Reset and see if you are offered language at first Start Up?
https://www.manualslib.com/manual/256035/Furuno-Gp-33.html?page=68&term=reset&selected=4
There is a Foruno Forum
Furuno USA Community View topic Wiring Help GP 31 FCV 620
Feb 11, 2018 | Furuno GPS
Hello, I have a GPS FURUNO GP31 and his screen is out of service and I want to retrieve the data. You can do this ? because I am on vacation until Saturday, August 2 sydney.or i go to melbourne until...
I have posted the Operator Manual at
http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf
Use this to check out section 7-10 to make up a cable to connect to a PC to allow download of data. Then, using the manual as a reference figure out the sequence of buttons to press to get the GP31 to download the waypoint and route data to the PC. Just press the buttons and assume the display is showing the next prompt. If you know someone you has a working GP31 get them to do the sequence and write down the buttons they press. You just copy the same sequence. You will need some software on the PC to capture the data,
Jul 30, 2014 | Furuno GP31 GPS Receiver
Navigator manual
Is this a request for a GP31 Manual? I have posted
http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf which is basically the same beast.
Jan 08, 2014 | Furuno GP31 GPS Receiver
I would like to know what coloured wires connect to where in a Furuno Gps navigator 31
Thyere are onlyb two wires red and black red is power black is return and the green earth should not be earthed anywhere on the case. If you need the manual contact me [email protected]
Please nrate my help++++Thanks for using FIXYA
dont rate if you have more questions as it locks me out, use email
Oct 17, 2009 | Furuno GP31 GPS Receiver
Can I use my furuno gps navigator to supply position data to my rdp-139 chartplotter and if so which wires need to be connected
Yes the output forom the Furuno GPS (like a GP31) will be yellow and green, hook these to theinput on the plotter blue (or black) and white. Use Data1 on potter as the input and select a nav source of "ALL" in setup menu.
Jun 05, 2009 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
LCD furuno GP31
Contact your local West Marine, Boater's World or contact Furuno directly.
http://www.furuno.com/
Mar 12, 2009 | Furuno GP31 GPS Receiver
Can we connct furuno gp31 to pc
Hello!
Ken
Sep 19, 2008 | Furuno GP31 GPS Receiver
try
Jun 27, 2008 | Furuno GP31 GPS Receiver
Boating Logo
147 people viewed this question
Top Furuno Boating Experts
Colin Stickland
Colin Stickland
jws1013
Bilral
Level 1 Expert
Are you a Furuno Boating Expert? Answer questions, earn points and help others
