Question about Camping, Backpacking & Hiking
How do I shut my nexstar flashlight I tried twisting it
Posted by Tricia Harnage on
UK4AA-AN2 Xenon Flashlight w/Twist Bezel Safety
McMaster- Carr sells replacement bulb assemblies.
Jan 23, 2013 | Underwater Kinetics UK4AA-AN2 Xenon...
How to open maglite flashlight to change batteries?
At the bottom of the Flashlight where the hole for a keychain ring is, or yours may have already came with the ring attached, although it may seem to be so perfectly welded or casted that thrrs no seam, if you twist the end by the ring attached or can grip it, the end twists off to allow you to switch the AA battery. Hope this helps
Aug 23, 2011 | MagLite Mag-Lite& Flashlight
Where do the batteries go in my stanley tripod flashlight?
Hello, The batteries are located inside each leg of the flashlight. Just remove the end cap on each leg by twisting it off. Inside each leg is 3 AA batteries.
Good Luck! Rich L.
Nov 28, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
I have been given a stanley 95 111 flashlight. dont know how to replace batteries did not get a manual with it
You can remove either the cap or the end and replace the batteries that way. They twist counter clockwise.
Jul 19, 2010 | Stanley The Work Bostitch Security Pocket...
We changed the battery pack and the bulb and it wont come on so the switch is prolly defective where do we find how to repair the flash light
Alot of maglites are problematic with symptoms like this... I have found that the culprit many times is the screw cap on the bottom of the flashlight.
The elecrtrical connection needed between the spring in the end cap, the threads on the cap and the threads in the barrel of the flashlight...
Make sure you twist your spring a bit..the dissimilar metals can actually corrode between the spring and the cap... Then spin the threads a little... Then try the flashlight again...
This procedure may save yourself replacing a switch..
Apr 29, 2010 | MagLite Rechargeable Flashlight System
I have a celestron nexstar 5 the begins to move on it own
Many times a bad cable will cause this. Also low batteries can cause this.
Contact Celestron and order a new cable. Use an external 12 volt power pack.
http://www.celestron.com/c3/page.php?PageID=37
Nov 05, 2009 | Celestron NexStar 5 SE (300 x 44.45mm)...
MINIMAGLITE 2AA LED WILL NOT STAY ON
Try twisting the head of the flashlight (left/right). Also could be a bad bulb or corroded batteries not making a good connection
Sep 17, 2008 | Camping, Backpacking & Hiking
Camping, Backpacking & Hiking Logo
154 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
Kardoc
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
