Question about Apple iPod touch
My ipod touch screen doesnt unlock after i entered my password
Posted by rayjr559 on
frindlyfixa
  • 27 Answers
Well if it is done syncing and the software has been installed in it then you might just need to restart it by holding the sleep button on top of the ipod until the power slider appears on the screen...if that doesnt happen...
then you need to hold the sleep and home buttons at the same time and hold them until the ipod restarts but when you see the apple logo reappear on the screen let go so you dont put your ipod into restore mode (trust me it wont hurt it if you do it right)
if none of these work then use itunes to restore your ipod to factory settings and re-sync and install the software again. if your problems consist contact the apple support center
Posted on Sep 16, 2009
How to enter my password when my screen is black
Try to Restart iPod touch by until Sleep/Wake button until a red slider appears.Next, turn iPod touch on. If iPod touch not responding reset iPod touch, press and hold the Sleep/Wake button and the Home button with same time least 10 seconds, until the Apple logo appears.
If still screen not appear than Recharge iPod touch or try To restore your iPod touch, first make sure you are using the latest version of iTunes(by http://support.apple.com/kb/HT1414). If still not able to solve than take some help with Apple Support Number .
Jul 20, 2014 | Apple iPod touch
Tip
How can I go on Wi-Fi on my iPod Touch without a computer?
<p>Apple iPod touch Wi-Fi reception without using a computer. The device has a built-in 802.11 Wi-Fi receiver, which means that access to the Internet via a WiFi router that is in range. When connected to a WiFi signal on your iPod touch, you may be prompted for a password if you must know the password or ask the Wi-Fi to the administrator. Unsecured Wi-Fi does not require a password. <br /> <p><br /> <p>1. Press the "Home" button of your iPod touch and move the cursor to the right on the device. Enter the unlock code if you have programmed. <br /> <p><br /> <p>2. Touch the "Settings" icon on the home screen of the iPod touch Settings menu. <br /> <p><br /> <p>3. Play the "Wi-Fi" Network access to the names of all upcoming Wi-Fi to see. <br /> <p><br /> <p>4. Tap the name of a Wi-Fi to connect. If the network requires a password, you will be prompted to enter the password. <br /> <p><br /> <p>5. Touch "Join" to complete the connection. Now you can use any Internet-related programs on your iPod touch. <br />
on Aug 05, 2011 | Apple iPod touch
Tip
How to unlock the iPod Touch, if you forget the password
<p>The screen lock is available on the iPod Touch, as well as recent models of the iPod and iPod Nano, giving you a 4-digit password to set the screen. This is to prevent others from using your iPod, but it is not a safety device impregnable. If you forget the password, you can quickly and easily unlock the iPod by connecting it to the computer you normally use to sync your iPod with iTunes. You can then open the iPod and reset the lock to a more memorable password. <br /> <p><br /> <p>1. Connect the iPod Touch to your computer via the USB cable. <br /> <p><br /> <p>2. Wait for iTunes to access and synchronize with your computer. <br /> <p><br /> <p>3. Take your iPod Touch from your computer, clicking on the "Eject" to the input side of the iPod under "Devices" in iTunes. <br /> <p><br /> <p>4. Disconnect the iPod Touch from the USB cable. IPod touch will turn on and will be available. <br /> <p><br /> <p>5. Tap the menu "General" on the iPod Touch. Tap "Passcode Lock and tap either" Turn off access "or" Change. "When you click" Change Password ", you can create a new password. <br />
on Jul 21, 2011 | Computers & Internet
Itouch disabled
When your iPod Touch displays a message telling you to connect it to iTunes, it may be in recovery mode, or have been disconnected in the middle of an update.
To get rid of the screen, you must reset your device. If in passcode mode, an iPod Touch must be manually unlocked or fully restored to get back to the home screen.Forcing a Reboot
When your iPod Touch is stuck on a screen that is instructing you to connect with iTunes, a normal restart will probably not work, as the hard drive has become frozen.
You can still, however force the iPod to reboot using a process called resetting.
To reset an iPod Touch, hold down the "Sleep/Wake" and "Home" buttons at the same time until an Apple logo appears, indicating that the device is rebooting.
When an iPod Touch reboots, it always goes back to the lock screen. Passcode mode will still be enabled.
Unlocking With the Passcode
If you know the passcode for your iPod Touch, slide the "Slide to Unlock" arrow and then enter your code on the next screen.
Upon entering your password, you will be directed to the device's home screen. If you enter the wrong password too many times, it will become disabled temporarily.
The iPod Touch can also be set to erase all content after 10 incorrect passcode attempts if you previously enabled this feature, don't attempt more than 9 entries.
Unlocking Without Passcode If you have forgotten the passcode to your iPod Touch, the only way to unlock the device is by restoring it.
Restoring an iPod Touch returns it to the factory settings, meaning that any settings, applications or music you added to the iPod are removed.
Once the device is restored, you can re-add your downloads and other information using the backup copies in your computer iTunes program.
The passcode setting will be disabled unless you manually enable it again.
Consideration
If you don't have a backup of your music and applications in iTunes on your computer, you can also download another copy from the iTunes Store or App Store on your device after a restore.
Any photos that are deleted during restore, however, will be lost forever if a backup does not exist.
Always back up your information via sync on a regular basis to avoid this problem.
Nov 05, 2013 | Audio Players & Recorders
Unlock screen
Is it locked by a password? Or something more terrible occurred to it? To unlock screen password, you can enter your iPod touch into DFU mode:
1. Plug in your iPod touch and turn it off. Hold down the "Home" and "Sleep/Wake" buttons for about twelve seconds.
You'll briefly see the silver Apple logo and then your touch will appear to turn back off.
2. Release the "Sleep/Wake" button but continue to hold the "Home" button until you see a message in iTunes stating that it has detected an iPod in recovery mode.
More about unlocking iPod screen password.
Jul 11, 2013 | Nokia C7 (8 GB) Smartphone
How to unlock an ipod
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
Mar 04, 2013 | Apple iPod touch
How can I unlock a disabled ipod touch?
Step 1:
The iPod Touch is a type of iPod that features a touch screen and can function as both a portable media player and as a pocket computer. It is possible to password protect your iPod Touch so that you will have to enter a password every time you want to unlock the iPod Touch screen. If you repeatedly enter the incorrect passcode, your iPod Touch will become disabled. To unlock a disabled iPod Touch, you need to sync your iPod Touch device with iTunes on your computer.
Attach the iPod Touch data cable to the bottom of your iPod Touch device and attach the other end of the data cable to an available USB port on your computer. Open iTunes on your computer and then select your iPod Touch device from the list of available devices on the left side of the iTouch window. Click the "Restore" button. If you have previously backed up your iPod Touch, you can choose to restore the device to the last back up or any saved backup. If you have never backed up your iPod Touch, this process will restore your iPod Touch's factory settings. Wait while iTunes syncs with your iPod Touch and restores the device. iTunes will prompt you when this process is complete.
Feb 10, 2013 | Apple iPod touch
How do i unlock my ipod touch
Hope it helps
Jan 23, 2013 | Apple iPod Touch Fifth-Generation
My ipod touch is disabled due to entered wrong password so many times.how to enable it??
You can unlock your IPOD Touch passcode or password by following these simple steps.
  • Connect your IPOD Touch to iTunes
  • Press or Hold the power and home keys 10 seconds.
  • Screen goes black, now release the power button
  • Make sure you do not release the Home key until your iTunes says "We have detected an itouch in recovery mode."
  • After this its simple all you got to do is a simple restore using your iTunes
Dec 19, 2010 | Apple iPod touch
I cant get internet on my iPod touch 4GB.
Have you tried to forget network and go back in and reset up the network on the ipod touch under wifi?
Jul 21, 2009 | Apple iPod touch
Apple iPod touch Logo
124 people viewed this question
Top Apple Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Geoff
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
