My Johnny VC JV222 will not charge - Computers & Internet
Posted by Bev Dolgin on
2008 Johnny Pag Spyder 300 wiring diagram
Hi, Pam for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Johnny Pag, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2008 Johnny Pag Spyder 300 wiring diagram Google Search
Johnny Pag Manuals PDF
JohnnyPag Spyder 300 Service Manual
Motorcycle Parts for Johnny Pag Spyder for sale eBay
Alternative Cruisers Johnny Pag Spyder 300 Owners Manual
Oct 01, 2018 | 2008 Johnny Pag Spyder 300
2007 Johnny Pag Spyder 300 remove the spark plug covers
Hi, Chuck for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Johnny Pag, despair not, for a mere zero $0 you can download another one.
Johnny Pag motorcycle remove the spark plug covers Google Search
https://www.youtube.com/watch?v=VPm_Z92FgCw
Motorcycle Parts for Johnny Pag eBay
https://www.ultimatespecs.com/motorcycles-specs/johnny-pag
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 27, 2017 | 2007 Johnny Pag Spyder 300
Why customer can't add new VC-4 in VCTRUNK on EGS4 board, during board configuration limitation?
We check all customers configuration steps, and find that in VCTRUNK#3 in which they add new VC-4 #7 on EGS4 already have several VC-4s #11,13,15,16.
From product manual we know that "VC-4/VC-3 binding: VC-4s are divided into two areas, namely,VC-4-1 to VC-4-8 and VC-4-9 to VC-4-16. the VC-4s/VC-3s in these two areas cannot be bound at one time."
So we ask customer use VC-4s from different areas then they add it in VCTRUNK.
Nov 14, 2017 | Computers & Internet
2008 Johnny Pag Spyder 300 replace starter drive
Hi, Paul for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Johnny Pag, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2008 Johnny Pag Spyder 300 replace starter drive Google Search
2008 Johnny Pag Spyder 300cc Motorcycle
Sep 29, 2017 | 2008 Johnny Pag Spyder 300
1976 Sportster. Why does the battery lose its charge?
Hi Johnny,
No, it would not be an open circuit, as that would cause nothing. Most likely a diode issue.
You did not mention if the bike drains when running, or sitting...Kind of a big thing....
IF not running and the battery drains, isolate the battery by disconnecting all negative cables at the battery. If the problem resolves, the regulator is suspect. It has the diodes that fail.
IF the battery drains while running, look into the charging system. There is a lot of trouble with the plug, where the charging system comes through the engine block. they overheat and fail to function. Not something you can always see, until the plug is pulled out.
If this plug is damaged, it is fairly major to switch out the stator. I have successfully made a soldered connection in this area and filled again with black silicone.
Johnny, there are a ton of other areas that can be suspect, but much more rare for your condition, as stated.
Jul 28, 2015 | Johnny Motorcycles
Hi this is amber I have 2x4 ohm qvc audiobahn abass2012P how would I correctly run them to get best bass n max power efficiency I have a soundstream Picasso 1000watt 4 channel bridge able amp to hook em up...
I assume you are replacing the built-in Audiobahn power amplifier with your 4 channel Soundstream amp. If so, you can set the Soundstream for bridge mode which should net you 2 high power channels of [email protected] or 500Wrms total power (if the speakers are quad VC), or alternatively, non bridged for 4x125Wrms (if the speakers are dual VC). You can see why below.
Next, you need to confirm each subwoofers coil configuration as follows: If each woofer is quad, there will be 8 connectors; if dual VC, then there will be 4 connectors. For dual VC, if each VC is 4ohm, you can choose between 8 or 2 ohms by series or parallel wiring. If each VC is 2 ohm, you can have 4 ohms in series to use. This can be determined with an ohm meter across one set of VC terminals. If you can get 4 ohm for each speaker, this will allow you to use the 2 channel bridged mode with each speaker getting the full 250W. If each VC is 2 ohm, use non bridged mode and run each of the 4 channels to each VC. For this case, use a 2 to 1 RCA jack to sum the two channels for each speaker on the amp's input side to make the signal 2 channel instead of 4 channel. Below are examples of quad and dual VC for reference only, the wiring may not match your setup which will depend on your VC resistance (impedance) measurement. Don't forget to set your HPF(High Pass Filter) as this is a subwoofer setup.
Nov 17, 2017 | Car Audio & Video
Http://www.facebook.com/people/Patricia-Geiss/100002655619425
+4917677424185 Email Transcript [HVD] ====== Start time: 1/5/2012, 2:12:7 [HVD] Module HVD Log Version = 2,12,32,426 [HVD] OS Info 6 0 S 2 0 [VC] ====== Start time: 1/5/2012, 2:12:7 [VC] Module VC Log Version = 1,7,15,426 [VC] OS Info 6 0 S 2 0 [VC] ====== Start time: 1/5/2012, 2:12:7 [VC] Module VC Log Version = 1,7,15,426 [VC] OS Info 6 0 S 2 0 [YP] ====== Start time: 1/5/2012, 2:12:7 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [YP] GetYoutubeURLType() = -1, http://www.facebook.com/people/Patricia-Geiss/100002655619425 [YP] ====== Start time: 1/5/2012, 2:12:7 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [HVD] ====== Start time: 1/5/2012, 2:12:9 [HVD] Module HVD Log Version = 2,12,32,426 [HVD] OS Info 6 0 S 2 0 [YP] GetYoutubeURLType() = -1, [email protected] [YP] GetYoutubeURLType() = -1, [email protected] [YP] ====== Start time: 1/5/2012, 2:12:12 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [YP] InternetCrackUrl() = 12006, [email protected] [YP] WinHttpCrackUrl() = 12006, [email protected] [YP] GetYoutubeURLType() = -1, [email protected] [YP] GetYoutubeURLType() = -1, [email protected] [YP] ====== Start time: 1/5/2012, 2:12:51 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [YP] InternetCrackUrl() = 12006, [email protected] [YP] WinHttpCrackUrl() = 12006, [email protected] [HVD] ====== Start time: 1/5/2012, 2:14:48 [HVD] Module HVD Log Version = 2,12,32,426 [HVD] OS Info 6 0 S 2 0 [VC] ====== Start time: 1/5/2012, 2:14:48 [VC] Module VC Log Version = 1,7,15,426 [VC] OS Info 6 0 S 2 0 [VC] ====== Start time: 1/5/2012, 2:14:48 [VC] Module VC Log Version = 1,7,15,426 [VC] OS Info 6 0 S 2 0 [YP] ====== Start time: 1/5/2012, 2:14:48 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [YP] GetYoutubeURLType() = -1, http://www.facebook.com/people/Patricia-Geiss/100002655619425 [YP] ====== Start time: 1/5/2012, 2:14:48 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [HVD] ====== Start time: 1/5/2012, 2:14:49 [HVD] Module HVD Log Version = 2,12,32,426 [HVD] OS Info 6 0 S 2 0 [YP] GetYoutubeURLType() = -1, snc4/203372_100002655619425_1800818_n.jpg [YP] GetYoutubeURLType() = -1, snc4/203372_100002655619425_1800818_n.jpg [YP] ====== Start time: 1/5/2012, 2:14:51 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [YP] InternetCrackUrl() = 12006, snc4/203372_100002655619425_1800818_n.jpg [YP] WinHttpCrackUrl() = 12006, snc4/203372_100002655619425_1800818_n.jpg [YP] GetYoutubeURLType() = -1, snc4/203372_100002655619425_1800818_n.jpg [YP] GetYoutubeURLType() = -1, snc4/203372_100002655619425_1800818_n.jpg [YP] ====== Start time: 1/5/2012, 2:15:11 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [YP] InternetCrackUrl() = 12006, snc4/203372_100002655619425_1800818_n.jpg [YP] WinHttpCrackUrl() = 12006, snc4/203372_100002655619425_1800818_n.jpg [YP] GetYoutubeURLType() = -1, snc4/203372_100002655619425_1800818_n.jpg [YP] GetYoutubeURLType() = -1, snc4/203372_100002655619425_1800818_n.jpg [YP] ====== Start time: 1/5/2012, 2:15:15 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [YP] InternetCrackUrl() = 12006, snc4/203372_100002655619425_1800818_n.jpg [YP] WinHttpCrackUrl() = 12006, snc4/203372_100002655619425_1800818_n.jpg
Add Your Solution Or Ask For Clarification
Feb 09, 2012 | Health & Beauty
Look to find remote and power supply for vc-c4
The VC-C4 uses a Canon WL-V5 remote control, available at B&H Photo here. They also have a power supply for the VC-C50 here. The VC-C50 is almost identical in specification to the VC-C4, it's just a newer model. The electrical power requirements are the same.
Nov 11, 2009 | Canon VC-C4 Network Camera
Canon VC-C4 vs Logitech webcam
DO you realize that this camera cost around 900 US$? - Might be a little overkill for VOIP.
Apart form that it is an excellent camera. Have look at the manual here.
The camera connects via RS232 (9DSub) or 8pin DSub and you can/have to download the software form Canon's web page.
Jan 27, 2009 | Canon VC-C4 Network Camera
Computers & Internet Logo
14 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
