Question about Water Filters & Coolers
My water cooler dispenser ( hot & cold )hamilton and beach model bl-5-2 does not get hot, help.
5 Related Answers
Anonymous
SOURCE: Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Posted on Nov 05, 2008
Anonymous
SOURCE: Cold Water not squirting out cold water
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
Posted on Aug 09, 2009
sherrianne75
SOURCE: How to clean/repair water cooler
I have a hamilton beach water cooler with storage cabinet # 87330. The cold water is not cold and the cooling light stays on. What is the problem and how can I fix it? Thanks!
Posted on Dec 20, 2009
Anonymous
SOURCE: Hamilton Beach 87330 hot water problem.
The two round "devices" on the tank are the operational thermostat, and the "safety" overtemp thermostat. It is usually the "operational" thermostat that fails, since it has to cycle a lot and arc internally. It is usually about 120-140 degrees F., and the safety thermostat significantly higher.
Posted on Feb 23, 2010
Anonymous
SOURCE: Hamilton Beach 87330 water dispenser: no auto shut off
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
Posted on Jun 10, 2010
Water dispenser BL-5-2 need to replace pump or get new part that connects to pump?
Fixya is unable to suggest sources for Hamilton Beach products other than Hamilton Beach
Aug 22, 2018 | Water Filters & Coolers
Feb 23, 2010 | Hamilton Beach Water Cooler with Storage...
Why is hot dispensing cold water
try to check the heat filament or thermostat heater, maybe it is busted that why it cannot dispense hot water, there water source is came only to one tab and it interconnected inside
Nov 04, 2009 | Hamilton Beach Water Cooler with Storage...
No hot or cold water will come out of the dispenser
you may need to clean the dispenser unit thoroughly.Try vinegar and a long q-tip.
Feb 22, 2009 | Hamilton Beach Water Cooler with Storage...
Nov 07, 2008 | Hamilton Beach Water Cooler with Storage...
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
Water Filters & Coolers Logo
186 people viewed this question
Top Water Filters & Coolers Experts
john h
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
