Question about Radio Communications
Bluetooth Speak First. How can I tell whether it is fully charged?
One light is red and second one is blinking blue
Posted by Natasha Goodwin on
Gil Shultz
  • Radio Commun... Master
  • 3,462 Answers
What does the manual tell us. Here is a link to try. If my memory is correct the RED LED turns off when it is charged about 4 hours.
https://manuals.plus/target/heyday-portable-bluetooth-speaker-manual
Posted on Oct 25, 2021
2 Related Answers
Anonymous
  • 7 Answers
SOURCE: old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
Posted on Sep 22, 2009
Anonymous
SOURCE: Bluedio T9 Bluetooth won't charge
Well... I've got the n65, and this is the third time I've gone to charge it. Solid red, won't turn on no matter how long its been plugged in, can't find the manual, this fixya page is the best result online...so my solution is to stop by the local cell-phone accessory shop to buy something new.*
*Results may vary. :^s
Posted on Feb 24, 2011
When charging the red light will cycle 7 seconds on then 2 seconds off and constantly repeat this cycle. However, the instructions state when charging the red might will stay on until fully charged. What...
Sounds like battery is no good There should be symbols on charger. Normally solid light charged. Blinking. Charging. Lights back and Foward battery. No Good won't accept charge
How do i pair my hs-bt102-bk to my lg p705g
First make sure that the phone and the headset are fully charged. Turn on the P705F and enable Bluetooth for the phone. Touch the Apps button and look for the Apps tab. Go to Settings and then find the Wireless and Networks section. Set Bluetooth to On. With the headset off, press and hold the answer button (on the back) for 7+ seconds and the red and blue lights blink alternately. Set your phone to look for available Bluetooth devices by tapping the Bluetooth menu. If needed, click on Search for devices. Find the headphones in the list. Type in the code 0000. If the blue light blinks 3 times and then once every 7seconds, it's paired correctly. If that fails, try again from pressing the Answer button.
I hope this helps.
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
1helpful
Alternating red and white blinking light on earpiece for afterglow pl-6360 then shuts off. Unit should be fully charged. Help!
Alternating red and white LED colors indicates that it is not detecting an active bluetooth connection. Use the PS3 bluetooth settings to find and reconnect the signal.
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
2helpful
My vivitar will not come on a blue msdc screen and blinking red light
I just called the help desk. MSDC and a blinking red light means that it is charging. It takes 6 hours to charge and you are not to take disconnect it from the USB until it is fully charged. Once it is charged the blinking light will turn green.... not sure whether it will still be blinking or not. This is what the lady on the phone told me so I haven't been able to try it out yet, but I will update if I call again.
2answers
151helpful
7answers
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 • Cell Phones
Still froze
Does the light blink blue other wise and show red when charging ?
Make sure ear set is fully charged overnite?
Turn off and turn on.
Only then when turning on, DONT REMOVE YOUR FINGERS AND KEEP PRESSED for about 10-30 Seconds,, Watch for SOLID BLUE... Remove and proceed to pair..
If it still does not work, I would suggest that you keep trying .. Since I assume that the phone is charging well and then discharging over a time..
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
