Question about Health & Beauty
I normally have low blood pressure 110/70 all my life. I have had a recent spike 137/89 up and down. Light headed Its still not high , is it dangerous?
Posted by Laurie Crann on
5 Related Answers
junmag
Jun Magno
  • 175 Answers
SOURCE: brake light problem Corolla 97
the tail light and brake lights are working from double contact bulbs. check the grounding, you dont have enough ground from one of the bulbs
Posted on May 30, 2009
John Fourteen Six
  • 2418 Answers
SOURCE: high head pressure, normal suction pressure
Get out there and shut off the power to the Condenser. Pull the shroud off (or all the sheet metal) and clean the fins of the condenser coil inside and out, do this once a year. Use normal water hose pressure, watch that you do not get to close so as to not bent the fins, and be careful of the electrical parts, let it dry before restart.Watch out when you cut grass around it, its best to cut grass with the a/c off, the fan sucks air through the coils, from outside to inside, up out the top. If you call me to do it I will bill you $92.50. Save your money, take your time. Be careful!!!!
Posted on Jun 28, 2009
paul campbell
  • 1071 Answers
SOURCE: High Oil Pressure In My 1991 Chevy S-10 4.7 Blazer
gauge or sender may be faulty
Posted on Aug 05, 2009
Max J
Max jasper
  • 22 Answers
SOURCE: WHAT WOULD BE CONSIDERED LOW BLOOD PRESSURE?
There are standard methods for measuring BP. One should be seated on chair, feet on ground, leaned back, relaxed for at least 5 minutes, at least 2 hrs after a meal, .... then repeating this procedure several times daily, and averaging will provide some ave daily BP value.
Using this procedure for hourly BP measures, one can adjust times and doses of BP medicines taken daily.
Posted on Aug 23, 2009
Anonymous
  • 4 Answers
SOURCE: 92 S-10 check gauges light flashing upon high rpm,
may be a grounding problem or the oil sending unit is bad
Posted on Jan 10, 2010
I am 80 very active for the last week my bp has been 124/52
What is your question.
That is a normal blood pressure.
Is that your question?
6'2" 240 woman vs. 5'2" 140 woman Different BP
Taking Diuretic and Beta Blocker and Ace inhibitor
vs taking only 1 aspirin a day Different BP
There is not one "normal" Blood pressure for everyone
Are you having symptoms of low blood pressure?
Symptoms of high blood pressure?
Are you light-headed when you stand up?
Why are you checking your blood pressure?
Why are you concerned about your blood pressure?
Aug 27, 2018 | Active Health & Beauty
What is the meaning of blood pressure 235/100
Andrew is correct
you should be on the way to a hospital in an ambulance
unless you are one of thousands that have got a home blood pressure testing machine and do not know how to calibrate it or it is faulty in which case junk it and keep going for regular tests at the doctors , pharmacists or chemists
Jul 09, 2017 | The Health & Beauty
What is the symptoms of high blood pressure?
Symptoms of High Blood Pressure -
- High blood pressure is generally a chronic condition and is often associated with few or no symptoms.
- When symptoms do occur, it is usually when blood pressure spikes suddenly and extremely enough to be considered a medical emergency.
- Rare symptoms include dizzy spells, headaches, and nosebleeds.
High blood pressure is often associated with few or no symptoms. Many people have it for years without knowing it. However, just because high blood pressure is often symptomless doesn't mean it is harmless. In fact, uncontrolled high blood pressure, or hypertension, causes damage to your arteries. High blood pressure is also a risk factor for stroke, heart attack, and other cardiovascular problems.
Mar 20, 2017 | The Health & Beauty
Sys 105 normal?
Hi littlegurl74,
the normal Blood pressure is 120 sys(Systolic) over 80 diastolic.
105 sys is low. but if that is your normal sys and your not having any signs of hypotension like dizziness it is fine then. Consult your physician if you have any problems.
thanks.
banaple
Sep 01, 2010 | RTO Blood Pressure Monitor Life Source Ua-...
Blood pressure Question
Measuring your own blood pressure is an important way of monitoring your health. High blood pressure is a major health problem, which can be treated effectively once detected. Measuring your blood pressure between doctor visits on a regular basis in the comfort of your home, and keeping a record of the measurements, will help you to monitor any significant changes in your blood pressure. You should also keep an accurate record of your blood pressure, to help your doctor diagnose and possibly prevent any health problems in the future.
Aug 27, 2008 | American Diagnostic Corporation 700...
Health & Beauty Logo
137 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
ray gallant
Are you a Health and Beauty Expert? Answer questions, earn points and help others
