Question about Vizio Televison & Video
Model E24-C1. Why no picture, no sound?
Powers on, screen lights, no picture, no sound. Replaced Main Board but problem persists.
Posted by Lawrence Brown on
5 Related Answers
Jaime Hernandez
  • 2337 Answers
SOURCE: powers on but no sound & no picture
If you power the TV set ON, count how many times the light on the front blinks?
Is very unlikely you have to replace the whole main board.
Posted on Feb 07, 2008
bestdarngood
Benjamin Patri
  • 3037 Answers
SOURCE: vizio model L37
here, try the trouble shooting guide and let me know start with page 56, here is the link
Let me know when you have tried the trouble shooting for picture and sound even though this may not help, Also, since replacing the board didn't work, I will suggest going right to the manufacturer on this since the board was the only thing that really made sense for both to be out. Otherwise there might be a loose connection somewhere, anyway call them and let me know what they tell you and if they can't help, then you might have to take it in somewhere to have it checked, but the main board is the only thing that really makes sense
Main support number 714-668-0588
Email support[email protected]
Posted on Mar 24, 2008
Anonymous
  • 98 Answers
SOURCE: Samsung LNR408DX/XAA Powers on with sound but no picture
I think you need to exchange the Main Board.
Posted on Feb 06, 2009
Anonymous
  • 4 Answers
SOURCE: plasma tv has no picture but green led is on
Try unplugging the TV for a few minutes (discharges the ballast/ps) then plug in and attempt to power on. I have the 42P Vizio over two years old and ran into the same problem a few times. First thought was a power supply issue, but the unplugging trick worked. Good luck.
Posted on Apr 17, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
I have an M50-C1 model Visio LCD tv and being told I need to replace my T-Con board. Do I?
The T-con board is inexpensive. Try replacing it. You will find one online for cheap price with a google search.
1helpful
Why did my Vizio LED TV go black?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Have a Emerson LED tv model LF501EM5F that wont power on completely Starts to pwr on then after 3 sec shuts off I have replced the power brd, main brd and the IR sensor and still does the same thing.
Try removing the LVDS cable that goes to the Tcon board and see if the set stays on, you won't have picture but does the sound stay on...if it does then replace the Tcon board, the only one you haven't replaced it sounds like
Samsung UN32EH5000FXZA sound no picture issue. I have replaced the tcon board, issue persist. Whats next ?
1helpful
Hi. I have a Samsung LED 46" model #UN46EH5000FXZA, with no picture but has sound.I replaced the power supply board & T-Con board & still no picture but have sound. What can I do next??
Do flashlight test to see if y0ou can see an image - if so replace the inverter board that powers backlights. If no image then go for the main board.
Need help troubleshooting no video on an LG 47LN5700 Television
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Rca tv powers up has backlight no sound or picture replaced main board and inverter
I would check the input board for correct power supply input
check the blue 15pf 6kv caps near the output from the PSU to the inverter.
Thomson 27lcdb03b picture upside down
I would suspect main board more than one you replaced--not likely to get help as Thompson is not known for that--possible firmware upgrade seems likely.
On every set I have seen with upside down/inverted or reversed screen etc it has been either a firmware issue or a main board.
Lct3201ad powers on screen lights up nothing else no pic, etc
Hi
Your TV has Main board problem.I have that board,but we do
only exchange and coast with shipping $130.00 for you.
Please look at our policy:
ATTENTION:
WE CHANGE YOUR BAD MAIN TO GOOD ONE.
OUR POLICY
1.YOU HAVE TO SHIP AN OLD Main BOARD TO US
WE WILL SHIP NEW ONE TO YOU BY USPS IN 2-3 BUSINESS DAYS.
2. PLEASE PAY TO PAY PAL BUY FOLLOWING EMIL ADDRESS:
[email protected] 3. PLEASE SHIP YOUR OLD Main BOARD TO FOLLOWING ADDRESS:
GEORGES ELECTRONIC
769 GLADYS AVE
LOS ANGELES CA, 90021
PHONE: 213 627 4071
FAX: 213 627 3944
THANKS
GEORGE
Televison & Video Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
